Old 04-08-2017, 05:09 PM   #1
padilla3048
Drives: 2012 Summit White SS/RS M6
Changing fluid in our tr6060 manual transmissions
hey guys, i made a how to on changing trans fluid in a 2010-2015 camaro SS with the TR6060 M6. enjoy and let me know if you have any questions!
2012 SS/RS Summit white.
Rotofab-Stainless Works 2" long tubes & 3" "Retro Catback", BTR stage 3, platinum springs and pushrods.
previous power was 428.9, before the cam. awaiting dyno time
padilla3048 is offline   Reply With Quote
Old 04-08-2017, 05:54 PM   #2
JLSuperfly
JLSuperfly's Avatar
Drives: 2014 Red Hot LS3
Nice video. Thanks for sharing.
JLSuperfly is offline   Reply With Quote
Old 04-08-2017, 06:12 PM   #3
Hellfighter
Hellfighter's Avatar
Drives: 2013 Black ZL1
Does Zl1 have same tranny?
Hellfighter is offline   Reply With Quote
Old 04-08-2017, 08:07 PM   #4
Hellfighter
Also, what happens when you mix the two different tranny fluids together? one stuck in lines and new fluid... tried that with break fluid different kind learned it the hard way...
Old 04-08-2017, 08:27 PM   #5
padilla3048
I don't think it will bother anything, both fluids are ATF with dextrin ratings.
I have experienced much smoother shifting with the redline fluid tho, that's a fact.
Old 04-08-2017, 09:10 PM   #6
USMC85
Si Vis Pacem, Para Bellum
USMC85's Avatar
Drives: 2010 Camaro 2SS
You should have used jack stands. There is not a lot of room under there if the jack failed.
"Children should be educated and instructed in the principles of freedom." --John Adams
USMC85 is offline   Reply With Quote
Old 04-08-2017, 09:16 PM   #7
LT1Zob
LT1Zob's Avatar
Drives: 23 LT1 / 19 Z06 / after 6 5th gens
Thank you Padilla, will be doing this after my 2 day track day in May
"Make yourself sheep and the wolves will eat you"
LT1Zob is offline   Reply With Quote
Old 04-08-2017, 10:25 PM   #8
BigMikeTX
BigMikeTX's Avatar
Drives: 2010 2SS
Thanks so much.
BigMikeTX is offline   Reply With Quote
Old 04-08-2017, 10:29 PM   #9
Synner
Drives: cars
So a video on how to die when your jack fails.
Old 04-09-2017, 02:42 AM   #10
miller8907
miller8907's Avatar
Drives: 2014 1SS/RS LS3
Another tip. Crack the fill plug lose before removing the drain plug. It will drain faster. And like mentioned, USE JACK STANDS. Especially if your making a how to vid for other to follow. Safety first!
2014 1SS/RS LS3 AGP TT, Custom TSP Cam, 4L80E Swap 1/4 mile- 9.53 @ 145mph
miller8907 is offline   Reply With Quote
Old 04-09-2017, 09:40 AM   #11
padilla3048
you know, you guys are absolutely right about that. normally i do use jack stands but i didnt this time around, i have a good jack but i should have still used them. i will in the future any time i get under the car
Old 04-09-2017, 11:17 AM   #12
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
Good thought. Eliminate the gurgling.
Slide one under the car even if you don't set the car on it.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 04-09-2017, 11:53 AM   #13
SSMY1LE
SSMY1LE's Avatar
Drives: '14 1LE RS NPP Recaro
I refilled mine from above using some clear PVC tubing and a funnel.
Very easy, let gravity do the work.
'14 1LE, Recaro, Cammed, Headers, Hi Flows, CAI, Tuned, 486 RWHP
https://www.youtube.com/watch?v=H57UfKCO0EY&feature=youtu.be
SSMY1LE is offline   Reply With Quote
Old 04-09-2017, 07:53 PM   #14
LT1Zob
LT1Zob's Avatar
That's a great idea too
