Old 10-26-2009, 01:19 PM   #1
Jeanius
Jeanius's Avatar
Drives: Blk/Blk 2018 Sierra SLT
Dome light dims when depressing brake pedal
If my dome light is on and I depress the brake it dims pretty significantly.
I have never had a car do this, esp a brand new one
Anyone elses car do this?
And the car was running, not just in the acc position
Jeanius is offline   Reply With Quote
Old 10-26-2009, 02:06 PM   #2
HeavyD
HeavyD's Avatar
Drives: 1SSRS RY L99
Someone else posted a couple months ago with the same phenomena with dome light dimming with the turn light. Unless your local dealer has seen this before, or there is GM bulletin about it, I really wouldn't worry about. Because what will happen is, the mechanic will have to tear your car apart to find the weak connection. Pressing the brake and needing the dome light on at the same time is kind of a rare combination of events. If you can't live with it, then take it in. A lot of these panels can only be removed and reinstalled a few times before the retainer clips start to break off, or weaken, or get bent. Plus, they never seem to go back together again the same way. I would rather not have my car taken apart unless it was absolutely necessary. But it is your car...
HeavyD is offline   Reply With Quote
Old 10-28-2009, 02:40 AM   #3
camaro5's Avatar
Drives: X-15 Velocipede
The technician should use a factory shop manual schematic, and identify the common ground point.
There is something like a ring terminal with paint under it.
Hey GM! Did you fix this one yet?
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 10-31-2009, 08:03 PM   #4
OBSSEST
Drives: 2010 Camaro 2SS RS, Black
Total shot in the dark here, but...
I'd be concerned that there was a problem with the brake system causing too much power consumption, thereby causing the light to dim because of the load. I have no expertise to base this on, but, to me, dimming lights means that something else is sucking power.
Is this impossible?
OBSSEST is offline   Reply With Quote
Old 11-08-2009, 10:48 PM   #5
RickyTheStorm
Drives: '10 Camaro 2SS,04 Colorado,06 ZX6R
My dome lights dim with brakes or turn signal - I think it is just power draw maybe? My Colorado does the same thing - I wouldn't be too worried about it unless it is almost making the lights go out.
Vararam CAI, ARH Headers, Flowmaster Exhaust, Nitto NT555Rs, Custom CAM and Tune - 11.981 @ 116.27
IOM - 2SS/RS - Auto - IAP - Sunroof - Ordered 10/13 (#7 at dealer)
3000(accepted to production ): 4/19/09
3300 (scheduled for prod ): 5/11/09
3400 (broadcast ): 5/16/09
3800 (produced ): 5/22/09
4150 (invoiced ): 6/01/09
4200 (shipped ): 6/01/09
5000 (at dealer ): 6/12/09
6000 (delivery to me ): 6/12/09
RickyTheStorm is offline   Reply With Quote
Old 11-26-2009, 01:26 AM   #6
LT1Jeep
Ecstatic Camaro SS Owner
LT1Jeep's Avatar
Drives: Jeep(s) [1in pieces] and 2010 SS/RS
at idle, esp these camaros cause they seem to idle low,.. an alternator hardly puts out enough amps to run the car let alone supply alot of current for big draw items. and todays ABS systems use very fast and high pressure pumps and electronics so im thinkinh that as soon as you hit hte brake peddel, the additional draw while sitting at idle is causing the dim. .02
LT1Jeep is offline   Reply With Quote
Old 06-05-2011, 10:31 PM   #7
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Old 06-05-2011, 10:57 PM   #8
PQ
Booooosted.
PQ's Avatar
I bumped this thread for a reason. So git your butts out to your cars and idle them and push the brake to see if the dome light dims.
Old 06-05-2011, 11:44 PM   #9
PQ
Booooosted.
PQ's Avatar
Old 06-05-2011, 11:48 PM   #10
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
What do you want to know?
Old 06-05-2011, 11:51 PM   #11
riderguy999
can't wait
Drives: 2lt RS
Check your grounds
riderguy999 is offline   Reply With Quote
Old 06-05-2011, 11:55 PM   #12
PQ
Booooosted.
PQ's Avatar
If your dome light dim when you step on the brake pedal when idling.
Originally Posted by riderguy999 View Post
Check your grounds
All of them?
Old 06-06-2011, 12:00 AM   #13
2SSRS@Gen5diy
Yes some but i have LED light in the dome so there not affected as bad as a incandescent light bulb, PQ you do realize that you have 4 tail lights back there that suck a lot of amp's from the battery ones you step on the brake pedal.
I don't think its that on your car.
Old 06-06-2011, 12:14 AM   #14
PQ
Booooosted.
PQ's Avatar
Lights dim the same amount when the engine surges. Just wondering if it's related. Tails too.
Ok, caryy on. As long as it's normal I'm good.
Hawk Performance Brake Pad "Updated" KILLER74Z28 Suspension / Brakes / Chassis 34 05-04-2016 12:11 PM
Clutch fluid contamination problems on Vette fixed for Camaro??? LDGn63 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 05-28-2012 10:17 PM
Dome light blinks with left turn signal ssdavidw Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 20 08-10-2010 04:16 PM
dome light switch broken! light-my-firebyrd Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 5 10-20-2009 06:03 PM
Some Texas Lighting Laws Mecha USA - Texas 5 10-20-2009 02:49 PM
