Old 04-13-2017, 10:17 AM   #1
AnthonySS2RS
Drives: 2011 Camaro 2SS RS @Summit_Stinger
Injector Size 600-650rwhp E85 N/A 416ci
I am looking to get my stock injectors oversized for my build and I was wondering if anyone can help recommend a specific size?
Short list of details on the build..
- 2011 SS
- Forged Internals N/A 416ci engine
- Ported Heads
- DSX Flex Fuel Kit
- Aftermarket Cam
- Upgraded Valvetrain
- Intake
- Exhaust
At the end of the day I have been leaning towards 65lb injector sizing to achieve reliable flow for the ballpark of 600rwhp on pump gas and a little north of that with E85. From what I understand E85 puts more duty cycle on the injectors so I am just wondering if 65lb will be enough?
Thanks for your input.
AnthonySS2RS is offline   Reply With Quote
Old 04-13-2017, 10:56 AM   #2
1LEee
Drives: 15' CRT Camaro 2SS/1LE/RS
Id say ID850's - but I'm not an expert with this stuff.
1LEee is offline   Reply With Quote
Old 04-13-2017, 11:28 AM   #3
xXSicSicSicXx
Drives: 14 1LE
Get big injectors. You'll probably want bigger power soon enough. ID1300s
xXSicSicSicXx is offline   Reply With Quote
Old 04-13-2017, 11:37 AM   #4
Bo White
Bo White's Avatar
Nah. Id say 700 or so is all youd need
Old 04-13-2017, 11:46 AM   #5
Bo White
Bo White's Avatar
Ive got CTSV friends that run 1000s under boost on e85
Old 04-13-2017, 12:34 PM   #6
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
I maxed out a set of 850cc running e85 at 640whp on a turbo car slightly richer afr than a n/a car so could make more. Zl1 pump and bap, was loosing fuel pressure
65lbs won't cut it unless you got twin pumps
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 04-13-2017, 03:03 PM   #7
KonigWolf
Drives: 2016 2SS A8
Here some formulas to help you better make a decision.
https://www.rceng.com/technical.aspx
The following are rough guidelines for BSFC based on engine type and fuel.
Naturally Aspirated
Gasoline – .45 to .50
E85 – .63 to .70
Methanol – .9 to 1.0
Boosted
Gasoline – .60 to .65
E85 – .84 to .91
Methanol – 1.80 to 2.0
16 Summit White 2SS-MRC-NPP-A8 :: PrayPorted IM - LT5 TB - Mishimoto Catch Can - RotorFab - E85 - TSP 2" LongTubes - Speed Engineering X/Mid Pipe
DIY Hpt Tune - DR - 1.75-60' - 7.47@95 - 11.56@120 with +2676DA
KonigWolf is offline   Reply With Quote
Old 04-13-2017, 04:14 PM   #8
fif_gen_powa
Also keep in mind the stock SS fuel pump is going to have a hard time keeping up running on e85 regardless injector size
8.3@164
Old 04-13-2017, 06:20 PM   #9
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
I don't think you can use a stock pump to run E85 , can you? Didn't think it was compatible.
HOJO is offline   Reply With Quote
Old 04-13-2017, 08:57 PM   #10
christianchevell
old school chevy rodder
christianchevell's Avatar
For a first post your pushing it....LOL you may want to look up what others have accomplished with N/A power and consider the money that does cost to go into it like 1000 hp axles, better trailing and toes and bushings and that 13 to 1 you will have to run with that .750 lift cam and fly cut pistons..... or go for the low 500s which has been done on here by others without a massive commitment to $$$$
https://www.facebook.com/sagperformanceengines/
Jerry did my short block a 428 for N/A not a 416 which would be a little better for boost, I only spent about 5 grand for a rotating assembly in a new clearanced ls3 block shipped ; no pan no pump etc...... correct seals, best pistons made, forged etc.... Maybe you should talk to him in Indiana close to the blocks...
Old 04-13-2017, 09:14 PM   #11
jc615
jc615's Avatar
Drives: Camaro and Sierra
I did id850 and zl1 pump with sbe NA setup
jc615 is offline   Reply With Quote
Old 04-13-2017, 11:21 PM   #12
Bo White
Bo White's Avatar
Yes. Stock pump will need replaced. For some reason I thought you listed a pump swap.
Old 04-17-2017, 12:59 PM   #13
AnthonySS2RS
Hey everyone. Thanks for your replies. Some more information on the build based on a few questions...
I thought I had listed a pump swap as well. I will be going to a ZL1 pump with the ADM high performance fuel pump control module.
Also, I am hoping to oversize my current injectors. Not buy ID850's.. ETC.. If possible.
I won't be needing to increase size any further because I have a standalone fuel system for my direct port nitrous.
I am looking for the most N/A power possible. Then I'll spray to the extra power I want when needed.
My car is built to be an all around car. But, geared more towards road track racing and reliability. I am going N/A because I do road trips with my car.
In reference to upgrading suspension.. I have every upgrade BMR offers and BC racing Coilovers.
Axles.. I have G-Force 1500hp outlaw axles with a 1 piece driveshaft.
I have upgraded the tail shaft bearing support for this year. Next year I plan on getting a fully built RPM transmission. But, this year I have run out of funds for that piece.
I am constantly on the forums and it has been hard to find anything on N/A E85 since it does not net much gain. I just have the DSX flex fuel unit and would like to achieve as much over 600rwhp N/A as I can. I have seen quite a few builds similar to mine with those numbers and figure the E85 can give me the extra bump if needed.
Thank you for the people that have posted some references. I appreciate it and I will look through them to see what I can come up with.
build advice, e85, engine, injectors, n/a
