![]() Drives: 2013 Camaro Convertible Join Date: Jan 2012
Passenger Seat Won't Recline
My passenger seat will not recline and is stuck all the way forward, i did some research on the and tried the instructions that was on document #PIC5579A by the seat back and forth in hopes of it solving the issue but that didn't work. I took it to the dealership and they diagnosed it as micro switch stuck open due to improper use of the seat and in order to fix it i have to replace the entire seat back frame which is $300(parts) + $200(labor) which sounds INSANE to me just because of a bad switch which is probably $20. The dealership is saying the switch is "built into" the frame so you have to get the entire piece. Has anybody else ran into a similar seat repair problem. Thanks!
[IMG] [/IMG]
Mrt v2 | Colorshift 2.0 | Rx Oil Breather | Rx Catch Can | T-Rex Billet Grille | HID Retrofit | Push Start | Vitesse Motorsports Throttle Controller
![]() Drives: 2014 Camaro SS 1LE 2SS Summit White Join Date: May 2016
What the hell is improper use of seat? You riding around with fat chicks?
SoCal Race Team #13
$300 sounds good (ill have to look up the parts again)...
My drivers seat wont recline/decline, tried the switch first ($30 online) and that wasn't it.. its the motor for me, replacement of the motor assembly (frame) is like $500 because it has all 3 motors, they don't sell them separately... Lucky enough I'm the only person that drives mine and its set for me (and hasn't moved in 3 years).. On a side note, if you want to try and fix it yourself try unplugging the seat (underneath) the motors have built in electronic fuses. once tripped and as long as they have ground they wont reset, unplugging them sometimes 'resets' the motors.
A.K.A - Diarmadhi (old handle) - So much to do.. So little money
Owner : Fast-Stache Industries LLC |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
'Improper use of seat' sounds like the dealer trying to get out of any responsibility.
Then again, no warranty at this point anyhow. That's weird.
lmfao!!! well apparently i think from my understanding is you're not suppose to recline the seat all the way forward and then use the release on the back?? idk thats what really upsets me is that i RARELY use my passenger seat and there is some sort of "improper" use of it that can cost me $500....just unbelievable.
#6 | |
Thanks for this info, if all of the motors are built into the frame then it is what is it, i just dont understand why they made it that way
#7 |
old school chevy rodder
IN 2011 ; I do not believe until the year 2011 they made the passenger seat with a power seat option and it was as in my 2011 2ss rs I owned first a manual seat for moving forward and back as in this the parts break down you should consider when repairing it yourself....... one switch for back that's it.... if it does not reset after unplugging and replugging in the seat just replace the switch... $22.14
http://www.gmpartsdirect.com/auto-pa...omponents-scat
#8 | |
#9 |
well go to gm parts direct if checking the fuses etc do not work...often the harnesses can get messed with being they are just there under the seat.
