Old 04-27-2017, 03:02 PM   #1
wsmith
wsmith's Avatar
Drives: 2011 LS
Manual steering conversion
I'm wondering if there is anyway to convert the standard power steering on a 2011 Camaro to manual steering? I've driven a car before with manual steering and found that I like the feel.
MRT V 1.0, Injen intake, ICE-olator, JVC Stereo, Alpine speakers, 600-w Amp, 10" Subs
wsmith is offline   Reply With Quote
Old 04-27-2017, 03:40 PM   #2
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
It is a safety issue like power disc brakes vs. manual drum brakes. The faster you can react the safer.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 04-27-2017, 05:16 PM   #3
maddoggyusa
maddoggyusa's Avatar
Drives: 2013 Camaro Dusk 2SS/6
it's not a safety issue if done right... Pontiac Fiero had manual steering. The Fiero drove nicely at speed... was a PIA to park.
I'm guessing you'd have to swap out the steering rack with a manual version... I'm sure you'd need some fabrication skills. Then there's the issue with the unused pump... somehow you prolly want to make it a dummy pulley.
Would be lots of work for something nobody will want to buy later.
maddoggyusa is offline   Reply With Quote
Old 04-27-2017, 05:25 PM   #4
Russell James
Russell James's Avatar
A 4000 lb car on foot wide 20s.... you want power steering.
Old 04-27-2017, 05:44 PM   #5
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Manual steering cars have different gearing in the steering than power steering cars, and generally have much narrower tires than modern muscle cars.
Rock-It Man is offline   Reply With Quote
Old 04-27-2017, 05:52 PM   #6
tomlink
tomlink's Avatar
Drives: 2011 Camaro 2LT RS
Send a message via Skype™ to tomlink
^^^^This
tomlink is offline   Reply With Quote
Old 04-27-2017, 05:56 PM   #7
wsmith
wsmith's Avatar
Drives: 2011 LS
Okay, maybe you guys are right! Thanks.
Old 04-27-2017, 06:05 PM   #8
JLSuperfly
JLSuperfly's Avatar
Drives: 2014 Red Hot LS3
I had an MkI MR2 with a manual steering. It was a very light car with the engine behind and it was still a PITA to steer at slow speeds or parallel parking.
On a big car like this, I don't I am strong enough to steer this manually without a 30 inch steering wheel.
JLSuperfly is offline   Reply With Quote
Old 04-28-2017, 12:43 AM   #9
Wizard1183
Wizard1183's Avatar
Drives: ABM SS2/RS M6
Send a message via Yahoo to Wizard1183
Manual steering. What are you? Smoking crack? you WANT power steering.
Life is short, drive it like you stole it!
Wizard1183 is offline   Reply With Quote
Old 04-28-2017, 02:42 AM   #10
STUNNAH
"BEASTM*DE"
STUNNAH's Avatar
Drives: 2013 ZL1 Black
You can't be serious...
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S...
Dual 10" Kicker Comp S Subs 1200w...
STUNNAH is offline   Reply With Quote
Old 04-28-2017, 08:25 AM   #11
Russell James
And if its a more connected to the road steering feel you are looking for... can do that with alignment specs, lowered, and sticky tires. Take a Z28 for a ride on some canyon roads. That's steering sweetness.
