Old 04-28-2017, 10:27 AM   #1
KerseySS
Joey
KerseySS's Avatar
Drives: 2011 Camaro 2SS/RS L99 Cyber Grey
2011 SS engine and lights shut off while driving
I was turning onto the interstate and took the turn fast. I heard a click and the car and headlights just shut off. I put it in neutral coasting down the on ramp and it started back up when I turned the key. I don't think my knee hit the ignition or anything. Has anyone else had this problem? It drove fine the rest of the way to work.
Sent from my VS985 4G using Tapatalk
2011 Cyber Grey L99 SS/RS- 3.91 Gear
MRR 228 Wheels-Hurst shifter/base plate
LT Headers no CATS-Magnaflow 16582 Axle Back
RoboFab intake-Dyno Steve tune
ZL1 Rocker Panels-SLP Splitter
Lowered on Phastek springs
Pray Performance ported TB
KerseySS is offline   Reply With Quote
Old 04-28-2017, 10:29 AM   #2
5thGenOwner
5thGenOwner's Avatar
Drives: 2010 SS
I've not had the problem, but based on what you described it does sound exactly like the key/ignition issue.
5thGenOwner is offline   Reply With Quote
Old 04-28-2017, 11:18 AM   #3
Avenging Orange
Avenging Orange's Avatar
Sounds like a grounding issue. Try tracking down battery leads and starter connections.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 04-29-2017, 02:29 AM   #4
STUNNAH
"BEASTM*DE"
STUNNAH's Avatar
Drives: 2013 ZL1 Black
Does your knee hit the key or come close to it???
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S...
Dual 10" Kicker Comp S Subs 1200w...
STUNNAH is offline   Reply With Quote
Old 04-29-2017, 08:37 AM   #5
KerseySS
Joey
KerseySS's Avatar
No, I don't think so. I wish it was my knee because it would be an easy explanation. I'm going to look at the car today to see if was the battery or a ground.
Old 04-29-2017, 09:42 AM   #6
christianchevell
old school chevy rodder
christianchevell's Avatar
Just a heads up the ground in the trunk for the battery is a POS with it just being a bolt through the trunk that's a painted trunk pan and I thoroughly sanded down cleaning up mine as it also has to hold a plastic wiring harness hold down, and your car is at the age where if you do not have a new battery you should.... A grounding problem can come from many places including grounds on the engine which are in several places some going to the fuel injection too.... Good luck.
