Old 05-30-2017, 11:31 AM   #1
Blackandwhite
Blackandwhite's Avatar
Drives: 2015 Camaro ZL1
Spark Plug Wires
Alright so i have a 2015 ZL1. I'm getting Kooks LT headers with the HI-FLO cats soon. Leave the catback stock for now and getting that mild2wild controller for the NPP exhaust. The guy installing it said to get spark plug sleeves but i feel weird just getting sleeves and plus i feel like getting some from auto zone doesn't feel right for a ZL1. So i might just upgrade and get spark plug wires. I heard MSD is too short for wires so i've been looking at Taylor wires. I called their tech support because i couldn't find which ones fit the 15 ZL1. This is the name and part number. Taylor StreeThunder Spark Plug Wire Sets #51044. These look alright but i'm really torn on what to get. Please help/share your opinions on what i should do/get.
Blackandwhite is offline   Reply With Quote
Old 05-30-2017, 11:59 AM   #2
Blackandwhite
bump
Old 05-30-2017, 01:00 PM   #3
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
I'm running the Taylor 409 10.4mm wires without sleeves, but I may add sleeves later on. You can also check out JBA PowerCables.
SSEssence is offline   Reply With Quote
Old 05-30-2017, 01:01 PM   #4
07-SRT
07-SRT's Avatar
Drives: 2022 Camaro SS 1LE
I have taylor 409 perfect fit and good up to 600°
2022 Camaro SS 1LE
07-SRT is offline   Reply With Quote
Old 05-30-2017, 04:53 PM   #5
Blackandwhite
I was going to go with the taylor 10.4 but according to summit racing, it's not compatible with my 2015 ZL1.
Old 05-30-2017, 06:00 PM   #6
bayarea408
bayarea408's Avatar
Drives: T
i use a set from PCM of NC, really high quality and the fitment is really nice. I have turbo manifolds that have a even tighter clearance then longtube headers and these were perfect along with a DEI heat socks, dont buy the socks in black hard to see burns or if you made contact. picture of the fitment below.
bayarea408 is offline   Reply With Quote
Old 05-30-2017, 06:53 PM   #7
PapaKlutch
PapaKlutch's Avatar
Drives: 2015 Camaro SS/1LE
I have the JDP Motorsports Spec'ed Taylor Thundervolt 8.2mm Spark Plug Wires with the boot made for header clearance and the thermal socks.
Been on for 1 year/5000 miles with no issues.
2015 2SS/1LE/RECARO/NPP/RS/NAV
PapaKlutch is offline   Reply With Quote
Old 05-30-2017, 10:38 PM   #8
davidscamaro
davidscamaro's Avatar
Drives: 2010 SS/RS M6 BIG cam
Unless your coil packs are in different location from a SS they will work fine. I'm using the Taylor 409 too with zero complain
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
davidscamaro is offline   Reply With Quote
Old 05-30-2017, 10:49 PM   #9
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
I just replaced my jba power cables with a set of the MSD. I read they were short but they fit fine...i like the fact the spark plug boot is very narrow and is a good distance away from the header. Plus you can bend them a bit as well. Heres a pic of them.
https://www.google.ca/search?q=pictu...a_LYhqjpinfRM:
rontammy0 is offline   Reply With Quote
Old 05-30-2017, 10:55 PM   #10
rontammy0
3 years of JBA power cables on my summer only driven SS......the are dried right out and cracked. Thats why I had to replace them. No sleeves used.
Old 05-30-2017, 11:10 PM   #11
Camaro Dude
Camaro Dude's Avatar
Drives: ‘13 1LE
No one believes in OEM or O.E wires anymore???
Camaro Dude is offline   Reply With Quote
Old 05-30-2017, 11:40 PM   #12
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
I'm running OEM wires with thermal socks. No issues, runs great at the track or on the street.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 05-31-2017, 06:23 AM   #13
07-SRT
07-SRT's Avatar
I was until the oem Spark pkug wire connection at coil pack was bad....
2022 Camaro SS 1LE
Old 05-31-2017, 07:56 AM   #14
Dega Man
Drives: ZL1
Haven't had the first problem with the MSD wires, running ARH 2 inch headers.
Dega Man is offline   Reply With Quote
headers, sparkplug, wires
