Old 06-07-2017, 01:40 AM   #1
Inspiro
Drives: 2012 Camaro SS
Square or staggered tires, brand recommendations?
Hi guys
For a daily driver SS with stock FE4 suspension, that visits a few tracks yearly(road course), will follow up with some suspension upgrades as well, but nothing extreme going here
Do you recommend square or staggered tires setup?
keep the 20s or drop to 19s or may be even 18s?
Which brand and sizes do you recommend?
Thanks in advance
Inspiro is offline   Reply With Quote
Old 06-07-2017, 06:03 AM   #2
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
when you say tracks, are you talking road course or drag strip?
I do both and like the staggered and 20's. If I wanted to really go a little more hard core in either direction, I would probably go 19's and squared for the road course. 19's and staggered for the drags.
hrpiii is online now   Reply With Quote
Old 06-07-2017, 07:54 AM   #3
Avenging Orange
Avenging Orange's Avatar
I dont track.....but found decent handling improvement by simply squaring up with stock 20x9 wheels and 275/40's.
I have been reading alot on suspension and found (what I believe) to be a reletively inexpensive combination.
Rear sway bar, better springs, fe4 or fe6 (1le) struts, front sway endlinks. My added extras are differential bushings and front radius rod bushing.
Others will say solid rear cradle bushing is best place to start.....but requires dropping the rear cradle....which, unless you have the right tools and do it yourself.....can get rather pricy in labor.
Good read http://www.jpssonline.com/#/the-book...n-2010-camaro/
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 06-07-2017, 08:31 AM   #4
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
Rear cradle bushing inserts are much easier to install. I am very pleased with the results. I bought mine from Pedders USA while they were still in business, but there are other vendors still available.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 06-07-2017, 08:49 AM   #5
charles71
charles71's Avatar
Drives: 2011 Camaro SS
Nothing beats the staggered look but you cant rotate your tires either so there are trade offs. Really depends on what you want to do with the car. I am staggered with 20's 275 up front and 315's in the rear. Nitto invos up front and Drag radials in the rear. Sees the local drag strip about two to three times a year.
Livernois Stage II Heads & Cam, LS7 Lifters, Ported Intake & Throttle Body, Rotofab CAI, BBK High Flow Fuel Rail @ Guage, Eaton Tru Trac Posi with 3.91 gears, 1000 HP Axels, Kooks Long tubes & full Corsa Exhaust, GM Hurst Short Throw Shifter, Mcleod RXT Twin Disc, Vitesse Throttle Controller, 1.5" Lowering Springs, Strut Tower Brace, SLP 25% Underdrive Pulley, Apex reservoir relocation kit and air scoop.
charles71 is offline   Reply With Quote
Old 06-07-2017, 08:46 PM   #6
JusticePete
Drives: Camaro Justice
Old 06-08-2017, 02:28 AM   #7
Inspiro
Road course
Old 07-09-2017, 01:50 PM   #8
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
Go square setup if road racing.
Subframe bushings really weren't that bad at all as long as you had a propane torch, which are like $30.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 07-09-2017, 02:04 PM   #9
JusticePete
Forgeline 19x11 front and 19x11.5 rear
305/30/19 RE-71 for street and track Hoosier A7 for road course
