Old 06-10-2017, 02:41 PM   #1
sinisterlsx510
sinisterlsx510's Avatar
Drives: 14 ss camaro summit white
Gen 3 lq9 408 into a 5th gen possible?
I have a 408 lq9 thats been sittin for while due to lack of motivation.. so what would it take to make it work in a gen 5 camaro
2014 ss camaro
Stainless works long tubes , rotofab cai , vararam wedge , muffler delete,cat delete ,resonator delete , x pipe
2019 sierra duramax 2500 all terrain x
2001 trans am
Lsx 408 ci rebuild in progress(dead project)
1967 camaro
Sbc 327.
sinisterlsx510 is offline   Reply With Quote
Old 06-10-2017, 02:44 PM   #2
102SS
waiting at the tree
102SS's Avatar
Drives: SIM 2010 2SS/RS A6
Just so happens to be someone doing this
http://www.camaro5.com/forums/showthread.php?t=497781
2010 2SS/RS A6 Just a few bolt-ons and appearance doo dads
102SS is offline   Reply With Quote
Old 06-10-2017, 09:30 PM   #3
Trob85
Svt lol
Trob85's Avatar
Drives: 2011 ss inferno orange blown
I don't know how well that would work with the different locations of some of the sensors. I know like crank trigger and cam sensor those will be easy but the knock sensor will be in the valley cover not on the side of the block. I'm sure it can be done anything can be done with enough money but would it be cheaper to buy a ly6 block and swap everything over than it would to get that to work. I'm no expert in that swap but I would check on ls1tech I'm sure it's been done over there.
Trob85 is offline   Reply With Quote
Old 06-11-2017, 12:07 PM   #4
Dwright
Drives: 2011 Camaro 2ss
You will not be disappointed, I have an lq9 from Texas speed. With an lsa blower I am at 763 hp and 800 ft lbs of torque, only problem is I had it built with low compression and need more boost than the lsa blower can push, but the car is so well balanced and an absolute beast
Dwright is offline   Reply With Quote
Old 06-11-2017, 06:12 PM   #5
sinisterlsx510
My lq9 408 motor before a lifter took a dump was built mild high compression. 11:8:1 with ported ls3 heads..so im not sure if to keep it high compression or turn it down a notch
2014 ss camaro
2001 trans am
1967 camaro
Sbc 327.
Old 06-11-2017, 07:47 PM   #6
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Make sure it's the same reluctor.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 06-11-2017, 11:25 PM   #7
CALLAWAY11
CALLAWAY11's Avatar
Drives: 2011 2SS/RS Callaway
Yeah, thats me.
2011 Callaway SC572 2SS/RS, TVS 2300 Supercharger, 1-7/8" Kooks LT Headers, Fast 85# injectors, E85 Flex Fuel Conversion, Fore Twin Fuel Pumps, MGW flat stick short throw shifter, McLeod RXT twin disc clutch, Liberty Gears Tremec trans, DSS 1000 hp axles, Nitto NT555r drag radials, 10#'s of boost, 702 rwhp/ 697 torque, Recaro seat upgrade
CALLAWAY11 is offline   Reply With Quote
Old 06-12-2017, 05:28 PM   #8
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
58x reluctor, LS2/3 timing chain cover and sensor, 4 node cam gear, drill and tap block for new style knock sensors.
If you have DoD, that has to go because there is no way to get oil to it with a gen III block.
I know they make a box to go from 58x reluctor to a 24x ECU without changing the reluctor, but not sure they make one to go from 24x reluctor to 58x ECU.
Someone probably makes a pretty plug to fill the cam sensor hole in the back of the LQ9 block or you could plug it with the old cam sensor.
Old 06-13-2017, 12:26 PM   #9
sinisterlsx510
Yea thats what i was remembering about the reluctor wheel.. and conversion box... i havent seen one yet from 24x to 58x.. no dod on my lq9 block..
2014 ss camaro
2001 trans am
1967 camaro
Sbc 327.
Old 06-22-2017, 09:39 PM   #10
CALLAWAY11
CALLAWAY11's Avatar
Motor is assembled and next step is to put her in and hook it up. Looking (hopefully) like next week, I could be driving my car. I cant wait.
