Old 10-30-2009, 11:26 PM   #1
Ghost Rider
I'm one bad Mamma Jamma
Ghost Rider's Avatar
Drives: 2010 Camaro SS/RS
There is hope - 2SS gas mileage
I have been getting about 17.1 mpg on my Camaro with a combo of city and highway which is not that great and so I figured the 25mpg HWY as claimed on the sticker was bogus. However, I recently had a chance to take my new Camaro on a reasonably long dsitance, all highway trip and got better gas mileage than I expected. Here's the info:
Location - Highway 74 between Wilmington and Wadesboro NC
Total distance traveled - 130 miles exactly
Road conditions - pretty straight and level, light traffic
Air temp. - 73 - 76 degrees F.
Altitude - 10 ft. - 700 ft. above sea level (estimated)
2010 Camaro SS - A6 (Auto for those that don't know what A6 means)
A/C - off
Cruise Control - on
tire pressures - 34 lbs in each tire
total miles on car - 1871-2001
Avg. MPG per computer - 24.9
Avg. MPG actual - 24.71
Gallons of gas - 5.26
Average speed over distance - 68.8 MPH
Peak MPG per computer - 27.5 @ average speed of 63 MPH
Fuel Range per computer - 440 miles
Speed limits over the distance ranged from 55 mph to 70 mph and I kept the crusie control at 9 mph over (there's lots of cops on that highway).
I hit and held 27.5 mpg for the first 25 miles or so in the trip at the lower speeds but as I hit higher speed limits of 60 and 70 mph and as I set the cruise at 69 and 79, I watched the avg. mpg drop.
The really good news is that the car is capable of 25 mpg and more under optimal conditions. I guess that fuel management system really works.
I dare you to challenge my BRUTE!
http://ghost-rider-5.mybrute.com
DELIVERED on August 25, 2009- 2010 2SS/RS, Yellow, A6, VIN # 34902
DELIVERED on September 9, 2009 -Custom Bumblebee Stripes and engine cover.
DELIVERED on September 10, 2009 - Painted GFX
Ghost Rider is offline   Reply With Quote
Old 10-30-2009, 11:29 PM   #2
Mark A Collier Sr
Retired Army, 101st ABN
Mark A Collier Sr's Avatar
Drives: 2 SS/RS w/sunroof
GREAT NEWS!
"BABY" is a Summit White, 2SS/RS, My Tribute to the 13 years I served in the 101st Airborne Division!!!
ORDERED: 18 JUL 09 #NMMS88,
BORN ON 4 NOV 09 at 12:26pm VIN:63460~ HOME on 18 NOV 09!
"101BABY"
Mark A Collier Sr is offline   Reply With Quote
Old 10-31-2009, 08:28 AM   #3
VenomZ302
Live to Win, Dare to Fail
VenomZ302's Avatar
For the record, I've gotten 26.5 mpg at 60-65mph in my 2SS 6MT, so there's definitely hope for better mileage.
You should really have more air in your tires, especially if it was 34 psi, hot... That can significantly factor into your mileage as well, if you were unaware. The sticker in my car (and yours too, I would assume) says that the cold pressure for your tires should be 36 psi for all four tires.
Originally Posted by Camaro Owner's Manual
Tire Pressure
Tires need the correct amount
of air pressure to operate
effectively.
Notice: Do not let anyone
tell you that under-inflation or
over-inflation is all right. It is
not. If your tires do not have
enough air (under-inflation),
you can get the following:
• Too much flexing
• Too much heat
• Tire overloading
• Premature or irregular wear
• Poor handling
• Reduced fuel economy
If your tires have too much air
(over-inflation), you can get
the following:
• Unusual wear
• Poor handling
• Rough ride
• Needless damage from road
hazards
3/13/09 - Ordered Aqua Blue Metallic 2SS/RS M6!
7/13/09 - Built!
8/11/09 - Delivered!
2G1FT1EW2A9124579
Old 10-31-2009, 10:16 AM   #4
Brown5150
#17,149
Brown5150's Avatar
Drives: 2010 Camaro 2SS
After the AFE intake I get 21 MPG.
Brown5150 is offline   Reply With Quote
Old 10-31-2009, 10:48 AM   #5
TooCool5
TooCool5's Avatar
Is this before or after the first oil change?
Old 10-31-2009, 10:58 AM   #6
Leolee
Leolee's Avatar
Drives: camaro
nice i travel a lot to wilmington from charlotte and its that straight shot on 74.... its 45 to 55 to 60 and 70 mph on there
Leolee is offline   Reply With Quote
Old 10-31-2009, 11:05 AM   #7
2Fast4U2010
2Fast4U2010's Avatar
Drives: Camaro 2SS
I really did not buy my 2SS because of the gas mileage as most of us can agree on Just to enjoy a nice big V8 again. Good info thou.
2Fast4U2010 is offline   Reply With Quote
Old 10-31-2009, 11:07 AM   #8
Ghost Rider
It was before the first oil change. I just changed the oil yesterday, after I got back from my trip.
Old 10-31-2009, 01:58 PM   #9
joepitt
joepitt's Avatar
Drives: 2016 2SS Camaro, 2017 Acura
I think the highway mileage with cruise control is the only good test for most of us whether we have a v6 or v8. It is too tempting to be heavy footed around town, which kills the mpg number.
2016 2SS, Auto, Garnet Red, Black Interior, Magnetic Ride, Performance Exhaust, and Nav.
Past highlights: 2013 2LT/RS, 2010 pre-order Camaro 2LT,1969 Chevy Malibu, 1972 Plymouth 'Cuda, 1972 Pontiac GTO, 1979 Turbo Buick Century.
'See the USA in your Chevrolet...'
Dinah Shore, 1952: http://www.youtube.com/watch?v=KGZvQoPxhNs
joepitt is offline   Reply With Quote
Old 10-31-2009, 02:04 PM   #10
CamaroFemme
CamaroFemme's Avatar
Drives: 2010 Black Camaro 2SS/RS
Originally Posted by Doc View Post
I'd recommend at least running the factory tire pressue of 36 lbs per tire. Contrary to what they post as to not "over-inflating" you can go a couple lbs over which will make the steering slightly more responsive, give you crisper handling, and improve your mileage by 1-2 mpg. They always have to think of legal issues when they make recommendations to avoid lawsuits. You can run 38 lbs per tire with no problems and in fact it tends to give you better wear because typically the edges of tires wear faster because people usually don't pay attention to their tire pressures and they're under-inflated. Going 2 lbs over distributes the wear more evenly across the center of the tread. You will notice a slightly firmer ride but it will handle better, stop better (less likely to slide because of better grip) and you'll see better gas mileage.
You are my Camaro info guru.
CamaroFemme is offline   Reply With Quote
Old 10-31-2009, 02:08 PM   #11
lee
lee's Avatar
Drives: 2010 2ss/rs
im gonna add some air to mine , good info
Old 10-31-2009, 04:41 PM   #12
eynigush
SoCal C5 Family Member
eynigush's Avatar
Drives: 2010 Camaro SSRS Rally Yellow
Great info. Like everything else in life, the small details can make a difference.
eynigush is offline   Reply With Quote
Old 10-31-2009, 05:38 PM   #13
Ghost Rider
UPDATE
After reading the comments about the tire pressure I went out and checked the computer for tire pressure and it read as follows:
34 33
34 34
So I took it for a drive, about 10 miles or so and it read as follows:
37 36
37 37
So I'm guessing the tire pressure was higher than I inititially reported. I relied on the computer reading when the tires were cold. Just an FYI.
BTW - the dealer put nitrogen in the tires when I bought the car. He said nitrogen doesn't leak out as easily as air. True or false? Also, I thought he said nitrogen wouldn't be affected by heat and cold like air and the tire pressures would be stable. Apparently that's not true.
Old 10-31-2009, 06:17 PM   #14
VenomZ302
VenomZ302's Avatar
UPDATE
34 33
34 34
37 36
37 37
It doesn't matter. Your cold tire pressure is supposed to be at least 36psi.
7/13/09 - Built!
2G1FT1EW2A9124579
SS Gas Mileage chevyridinghigh 5th Gen Camaro SS LS LT General Discussions 72 09-13-2009 02:14 PM
Gas Mileage question: V6 vs V8 MyCamaro5 5th Gen Camaro SS LS LT General Discussions 1 09-10-2009 02:56 PM
Why aren't there any Aqua Blues yet? txcamarogirl 5th Gen Camaro SS LS LT General Discussions 40 08-20-2009 11:05 AM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 02:00 PM
Tougher EPA '08 mileage estimates are issued KILLER74Z28 General Automotive + Other Cars Discussion 0 12-12-2006 07:30 PM
