Old 06-30-2017, 11:44 AM   #1
0311
IG: Vector_Blue
0311's Avatar
Drives: 2018 Cadillac CTS-V
Brake squeal help!
So about four months ago now I replaced the brakes on my V6 with Brembos from an SS. I replaced the calipers, brake lines, brake pads, and brake rotors will all new parts. Within the last month or two I've noticed that the front brakes will sometimes squeal horribly when braking lightly at low speeds, such as when backing up, and coming to a stop sign/light. They never squeak when I brake hard, brake at higher speeds, or when I apply more pressure to the pedal. It's to the point where I don't even want to drive the car because it sounds so bad. The pads are ceramic, still like new, and aren't anywhere close to the wear bars so that's not it. I even took it to a shop and the best answer they gave me was to just replace my pads with a different brand. I might just do that and see but before I spend that money.. What am I missing here? Any ideas I should investiagte? I can't for the life of me figure out what's making contact, or why.
RIP Crystal Red Tintcoat 2013 Camaro ZL1, 11/22/17.
0311 is offline   Reply With Quote
Old 06-30-2017, 11:59 AM   #2
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
This is normal brembo dude. They prefer to be mashed instead of feathered.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 06-30-2017, 12:00 PM   #3
TheFlyingBananaSS
Try the trw rollerskate pads. It fixed the issue for me.
Old 06-30-2017, 12:05 PM   #4
Avenging Orange
Avenging Orange's Avatar
Nature of the beast. Even my rollerskates squeal.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 06-30-2017, 02:50 PM   #5
bayarea408
bayarea408's Avatar
Drives: T
big brakes, big stop, big squeal. Helps to do a break in process with brand new pads to seat them properly, but none the less squealing pigs.
bayarea408 is offline   Reply With Quote
Old 06-30-2017, 02:53 PM   #6
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
I've noticed that these cars also like to build up brake dust and squeal. Every now and then I take mine apart and clean everything.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 06-30-2017, 03:14 PM   #7
0311
IG: Vector_Blue
0311's Avatar
Huh. I would have never guessed it's normal. I always feel like I'm driving a beater around when I pull up to places and everyone turns to see what the hell made that horrible squeal. Yeah, the pads I bought have the rollerskate weights, and I did a proper break in.. Maybe I'll try the trw ones suggested. Thanks all.
Old 06-30-2017, 03:48 PM   #8
JusticePete
Drives: Camaro Justice
High performance brakes make noise because the pads are harder. Race car pads make your SS pads completely quiet by comparison. Relax and enjoy what are among the best combination of performance and street-ability in brakes on a Modern Muscle Car.
Old 06-30-2017, 08:01 PM   #9
Avenging Orange
Old 06-30-2017, 11:00 PM   #10
MJanowich
Door ding magnet
MJanowich's Avatar
Drives: 2010 Black 2SS/RS
My OEM pads never made noise on my SS. Did you bed the pads proberly as per instructions? Did you use brake grease on the back of the pads? If not, try that since it's the cheapest option. It could just be that your particular rotors and pads are a noisy combination.
"When you're racing, it's life. Anything that happens before or after is just waiting."
MJanowich is offline   Reply With Quote
Old 06-30-2017, 11:37 PM   #11
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
I sometimes let my SS sit for weeks. The rotors have rust on them. I spool it up to 50+MPH and stomp them. And I mean stomp them, like you are trying to stop a gorilla. Don't worry, you won't break them. Just check your rear view first because if an Audi is behind you you will be in trouble.
Next time you roll up to the florist they will be quiet. Until you buy the flowers and then a lisp will come out.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
