Old 07-03-2017, 09:47 AM   #1
Stewart
Stewart's Avatar
Drives: 2014 Camaro 2SS RS & Ground effects
Question Transmission service
I will be moving out to Cali in the very near future. With that said I will be driving from NJ to Cali, My mileage is around 42K and was wondering if I should have the trans serviced prior to the trip across country. I figured I would get the right answer from here then a service tech just saying yes to make money if not needed. This chart is in my owners manual, but was seeking advise from the experts
Don’t walk in front of me, I may not follow; Don’t walk behind me, I may not lead; Walk beside me, and just be my friend.
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260
Stewart is offline   Reply With Quote
Old 07-03-2017, 03:21 PM   #2
hammdo
'It's an experiment'
hammdo's Avatar
I did trans at 35k. Not a bad idea. Do it well before your trip to make sure no issues
-Don
747 RWHP 794 RWTQ
Old 07-05-2017, 07:35 AM   #3
Stewart
Stewart's Avatar
-Don
Thanks Don, I appreciate the info. I will schedule it for September then as I am leaving in December.
Stewart
Old 07-05-2017, 09:42 AM   #4
sspade
sspade's Avatar
Drives: 2015 Camaro LFX A6
What exactly is included in a "Tranny Service"
Cold Air Inductions CAI : Apex Air Scoop / WW Relocate Kit : JacFab Intake Manifold Spacer : Overkill 80mm Throttle Body : Overkill Tuned : MagnaFlow Cat-Back Exhaust : Elite Engineering Catch Can : ZL1 Strut Tower Brace : Custom Tunnel Brace : JPSS Caster Locks : JPSS 32mm Rear Sway Bar : JPSS Billet Radius Arm Bushings : Pegasus Solid Sub Frame Bushings : 1LE Brembo Conversion : B&M 70273 Trans Cooler
sspade is offline   Reply With Quote
Old 07-05-2017, 10:47 AM   #5
Avenging Orange
Avenging Orange's Avatar
I'd change my oil before the trip. Your mileage is still pretty low. My question...how hard do you drive it? Is it just a daily driver? You keep regular maintenance? If irs just a well maintained daily driver...I'd wait till I got there and then swap out all fliuds.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 07-05-2017, 02:03 PM   #6
sspade
sspade's Avatar
Is it just a drain, refill, filter swap?
Where is the filter located on the 6L50 ?
Old 07-05-2017, 02:31 PM   #7
Stewart
Stewart's Avatar
I really do not know, I am guessing fluid and filter change, going to have to ask that.
Mine is a daily driver, I do not drive it hard mainly highway mileage. I change the motor oil every 4000K. I used to the first year change it every 3K, but was told that I did not have to change it until every 5K so I split the difference.
O ok thank you, I am guessing it is in the bottom of the pan of the trans on mine not sure where it is on a "6L50"
Old 07-05-2017, 02:38 PM   #8
Stewart
Stewart's Avatar
I just googled the 6L50 Trans and yes it is in the pan of the trans. I did not know that is what type ot trans that is in our cars, but I do now. Thank you for that info.
Old 07-05-2017, 02:55 PM   #9
sspade
sspade's Avatar
Yours may be a 6L80.
Old 07-05-2017, 03:11 PM   #10
JusticePete
Drives: Camaro Justice
Changing the filter and fluid at 50K for a normal use Camaro is routine maintenance IMO. Race it hard on a road course or drag strip, far more frequent service is in order.
Old 07-06-2017, 06:46 AM   #11
Stewart
Stewart's Avatar
Thanks everyone for the great info. I always know I can count on the members here to help.
