Old 07-07-2017, 01:59 PM   #1
Fondue Wormhole
Bad Example
Drives: Camaro SS
One Cooling Fan Not Working.
One of my cooling fans isn't coming on.
With the engine cold & the AC on, standing at the front of the car and looking in the engine bay, only the right fan comes on. With a coolant temp over 220*'s, only the right fan is on.
I see in the fuse box there are 3 relays: K612 (Mini) Cool Fan HI (HC), K613 (Micro) Cool Fan Low (HC), & K614 Cool Fan CNTRL, as well as 3 fuses: #11 (Mini) Cool Fan Rly (10A), #41 (J-Case) Cool Fan HI (30A), & #44 (J-Case) Cool Fan Low (30A); all 3 fuses Ohm-out as good. I don't have a diagram to check the relays.
What is the operation of the fans suppose to be? That-is, does only one fan come on at a particular temp then both fans activate at another temp? Or do both fans come on at a Low setting at a particular temp, then a High setting at another temp?
Before I buy another fan, I want to make sure it's not a relay or sensor issue.
Fondue Wormhole is offline   Reply With Quote
Old 07-07-2017, 04:28 PM   #2
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
Turn the AC on, see if that kicks on one or both fans.
I've never looked at my fans running if I'm honest.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 07-07-2017, 06:24 PM   #3
Fondue Wormhole
Bad Example
Drives: Camaro SS
Already did that:
Originally Posted by Fondue Wormhole View Post
With the engine cold & the AC on...
A little research shows that both fans work in both Lo & Hi conditions. They run in series for Lo operation, and in Parallel for Hi operation...
The relays have the connections printed on them, and they all test good as well.
Looks like I lost a fan...
Old 07-08-2017, 01:47 PM   #4
Fondue Wormhole
Bad Example
Drives: Camaro SS
While troubleshooting, the fan that wasn't working suddenly went on & off, which led me to the problem:
