Old 07-18-2017, 05:48 PM   #1
ltrout
Drives: 2018 Camaro 1LT/RS V6 A8
Drivers Door not opening from inside or outside?
Hey guys, I'm in need of some quick help. I took my driver's door handle off to wrap it and I was able to get back into the car and everything fine afterwards. I went to the store and was not able to open my door from inside or outside now. The outside handle opens fully, while the inside doesnt. I'm not sure how to open the door because now my radio won't turn off or anything. Windows and locks still work. I dont want to run to a dealer because I dont have the funds currently so I would like to see if I could open it myself.
ltrout is offline   Reply With Quote
Old 07-19-2017, 08:38 AM   #2
MrChrisLS3
Drives: 2018 1SS M6
Sounds like there is a mis-alignment somewhere. Just take it back off and do it again. May have to pull the door panel, which is never fun on any car.
MrChrisLS3 is offline   Reply With Quote
Old 07-19-2017, 09:23 AM   #3
jrhagen
Banned
Drives: Camaro
Start over.
jrhagen is offline   Reply With Quote
Old 07-19-2017, 02:50 PM   #4
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
You mentioned the radio not turning off? Normally, when you shut off the ignition, the radio states on due to the Retained Accessory Power until you open the door. The door sensor is part of the door latch. You were doing something with the door handle.
Putting two and two together, something is not right with the latch and/or sensor wiring. Did you unplug any connectors when you were taking stuff apart? Did you disconnect the battery before pulling connectors?
Rock-It Man is offline   Reply With Quote
Old 07-19-2017, 03:18 PM   #5
MjrStfy
MjrStfy's Avatar
Drives: 2015 Chevy Camaro V6 2LT RS
Try http://www.camaro5.com/forums/showthread.php?t=116016 I had the same issue when I removed the driver side. The drivers side has a pin that you need to adjust when putting the handle back in.
Instead of using wire like the guy did in the thread to pull the pin out use dental floss easier to remove the dental floss then wire.
MjrStfy is offline   Reply With Quote
Old 07-19-2017, 05:52 PM   #6
kmarshall2121
kmarshall2121's Avatar
Drives: 2012 45th Anniversary Edition
could it be that when you put it in gear the doors all locked? and since the handle is missing, might not send a signal to unlock once youre out of gear?
kmarshall2121 is offline   Reply With Quote
Old 07-20-2017, 06:07 PM   #7
Rock-It Man
I looked in the shop manual. So many ways to **** up the door latch system!
What did you take apart? Did you take the interior trim panel off?
Old 07-21-2017, 02:47 PM   #8
1Coopgt
1Coopgt's Avatar
Drives: All Black 2012 1LS
Re-read his first post in this thread. He took off the outer door handle.
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
1Coopgt is offline   Reply With Quote
Old 07-22-2017, 09:00 AM   #9
Rock-It Man
I know what he wrote. But taking off the handle alone shouldn't affect the latch, so it may be about what he didn't write.
Somehow, the door sensor has been affected, and the BCM doesn't know what position the door is in.
