![]() Drives: 2015 2ss Join Date: Jul 2015
headers and full exhaust on 15 l99 convertable, help
Have a 15 convertible ss that I want to do a headers back exhaust. understand its different what are you doing or what does it take to make the coupe one work. Thanks
#2 | |
![]() Drives: 2011 SS/RS , L99 convertible Join Date: Aug 2015
Sounds tame, except when 1st starting or going wot, then it sounds awesome!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 SS Supercharged Convertible Join Date: May 2013
The catback is different due to the extra support braces on the convertible. The headers and the high flows will be the same as a coupe.
Panther thanks that's what I was talking about. The bracing doesn't allow a regular kit to work so was curious if there is one out there that has worked well for someone.
Drives: 2013 2SS/RS Convertible Join Date: Apr 2016
Borla makes cat back systems specific to the convertible as well as with factory ground effects.
#6 |
As Royal Tiger mentioned, the Borla's, Corsa, Magnaflow and others make specific catback systems for our convertibles. I have the Solo performance Mach XC cat back.
Here is a link with some videos. Do some research on quality, looks, cost, etc. You won't get much in hp gains with any catback under 500hp. Good luck. https://solo-performance.com/mach-xc-cat-back-camaro |
#7 |
![]() ![]() ![]() ![]() ![]() Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
Here is my Stainless Works 3" full exhaust.
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/Gesi cats, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
#8 |
smoking I like that sw system going to their site to check it out. cold air and exhaust netted you 380 to the wheels, I like
#9 |
![]() ![]() Drives: 2015 2SS White Convertible CE/INDY Join Date: Mar 2016
That setup must be crazy loud...
joe...
ARH LTH/HFC/Legato muffler, RDP Custom Tune, K&N Blackhawk CAI, Bigworm Blackout kit, ZL1 Rims, Phantom Grills, VMAX PTB
#10 |
In the pictures shown before you will see the Retro Exhaust at the end. I have since went to the Chambered Turbo mufflers and yes it is a lot quieter.
#11 |
Try this website, very good company and it has the complete system
https://www.lgmotorsports.com/camaro...o-exhaust.html |
#12 |
lou thanks like that option with mufflers no cats? next year going to cam and ls3 conversion
