Old 07-27-2017, 10:30 AM   #1
Lawlow97
Drives: Black 2015 camaro 2ss
Camaro Cat Back Exhaust
So I've been trying to make my camaro a bit louder and decided to buy a new exhaust, but I'm worried that it'll void my warranty does anyone know rather it will or not ?? Thanks
I have a 2015 2SS camaro.
Lawlow97 is offline   Reply With Quote
Old 07-27-2017, 10:33 AM   #2
14Black1LESS
14Black1LESS's Avatar
Drives: 2014 2SS/RS/1LE
It would only void it from where you bolted on the exhaust to the back. Unless you get a real prick of a dealership that will try to void the entire warranty.
14Black1LESS is offline   Reply With Quote
Old 07-27-2017, 08:38 PM   #3
pyroguy
Keeper of “THE list”
pyroguy's Avatar
Drives: ABM #832
^^^ What they said. The only part that would be voided is the factory catback warranty. Now if you do headers, then when you get a tune you'll void more warranty than just a catback, but your car will scream louder and perform better.
Check out my build thread
Old 07-28-2017, 02:42 AM   #4
Lawlow97
Well as of now I plan on just getting the cat back exhaust from borla, which I hope sounds nice!!!!
If it doesn't then I'll get the headers.
Thanks for the replies and help btw
Old 07-28-2017, 03:12 AM   #5
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
Why not just get a muffler delete?
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 07-28-2017, 05:25 AM   #6
pyroguy
pyroguy's Avatar
Drives: ABM #832
I am slightly partial, since this is my exhaust setup, but here's my setup:
Kooks LT with cats and Solo Mach XL catback
Old 07-28-2017, 06:35 AM   #7
myold88
myold88's Avatar
Thats what I was thinking. Just delete the mufflers. I've had the Solo Axle
Back J/Pipe exhaust for 7 years and love it. Personally I wouldn't want it any
louder and its a deep rumble with absolutely no drone.
Axle back= less expensive, easy install plus you can keep your factory set
up to put back on if and when you sell your Camaro.
Old 07-28-2017, 06:59 AM   #8
Smokin19
Drives: 19' ZL1 A10, w/pdr
Here is your solution. Muffler delete pipes from Stainless Works, install in less than an hour. Selling these pipes for $150 plus shipping.
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/Gesi cats, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
Smokin19 is offline   Reply With Quote
Old 07-28-2017, 10:28 AM   #9
myold88
myold88's Avatar
And the drone? Bad advise especially if the OP has the L99 / Automatic.
Old 07-28-2017, 10:51 AM   #10
StevenBateman
StevenBateman's Avatar
Drives: 2011 2SS/RS
Go for the atak catback with headers and no cats
"Scarlett" the Black Widow
BTR Stage 4 Cam, FTI 3600 Stall Converter, GM 3.91 Gears, GPI Intake Mod V2, CAI Cold Air Intake, SLP 25% Underdrive Pulley, LS3 Conversion, PRC Ported/Polished Heads, Stainless Power Long Tubes w/off-road pipes, Borla Atak Cat-Back Exhaust, Tru Cool 40K 482rwhp/425rwtq, Built and tuned by Champion Motors
StevenBateman is offline   Reply With Quote
Old 07-28-2017, 11:48 AM   #11
Avenging Orange
Avenging Orange's Avatar
Whoa...wait! If headers are on the possibility list....then scratch the cat back. Your exhaust should always start up front. Headers will nake any exhaust sound better and louder. Headers on stock exhaust is you best advise.
BUT....if warranty is truly an issue....then I suggest you wait...save your money...and do it right the first time. Wait till either warranty expires or you decide you are ready to mod. Bear in mind, headers will require a tune that can also void warranty. Take you time and make educated decisions.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 07-28-2017, 12:17 PM   #12
WoodBoss
"Old School"
Drives: 2010 2SS L99
That is a great deal and will sound good. All you guys complain about drone, this and that it's really no big deal.
WoodBoss is offline   Reply With Quote
Old 07-28-2017, 12:24 PM   #13
Welker2
Ret AF, cancer survivor
Welker2's Avatar
Cat/Axel back will not void your warranty.
Old 07-28-2017, 12:51 PM   #14
imaSSnake
'Maro
imaSSnake's Avatar
Drives: 2015 SS 6.2L Auto 2SS
Plus if you use the paddle shifters it keeps it out of 4-cylinder mode so no stupid farting
2015 SS 2SS Auto 93 SCT Perf, Kooks LTH & HFC MBRP Axleback Muffler Delete "Z/28" Spoiler and Grille OEM ZL1 wheels 285/305/35R20 BFG G-force Pro Comp 2
imaSSnake is offline   Reply With Quote
exhaust borla, warranty camaro
