Old 11-04-2009, 09:54 AM   #1
ThunderSS
ThunderSS's Avatar
Drives: 2010 CGM 2SS/RS
For those that are having to pull the crank pulley off.
In order to put it back on you really need to have a longer bolt to ensure you do not booger up the first few threads of the crank..
You take a big risk of doing this by trying to use the stock crank bolt to put the pulley back on. the stock bolt will only grab the first 3 threads with the stock pulley, and with the SLP under drive pulley it wont even reach the threads..
To take care of the problem you need to head to you local Gm parts department and older this bolt.. It is 1.25 inches longer than the stocker.
Gm part Number [11570163] Pulley bolt that is 1.25 inches longer than the stock bolt.. Cost is $6
Hope this helps some of you out..
2010 Camaro SS/RS HKE Forged 416 CID
http://www.fquick.com/ThunderZ28
510 HP/485 Ft. Lbs
ThunderSS is offline   Reply With Quote
Old 11-04-2009, 11:01 AM   #2
GaryTucker
Drives: 09 Vette GT1, 06 350Z, 82 MSE
The biggest issue is to consider whether this longer bolt will bottom out and if so, remembering to stop and reinstall the older bolt once you get the pulley started. There are installers made that alleviate this concern...but they are much more than $6, so this might be an option that would work for the job.
GaryTucker is offline   Reply With Quote
Old 11-04-2009, 11:07 AM   #3
2Tightwads
Banned
Drives: 2002 LS1 swapped into a 1994 Z
Ls7 bolt to install/bottom out pulley, supplied new ls3 bolt for final bolt down...problem solved.
2Tightwads is offline   Reply With Quote
Old 11-04-2009, 01:19 PM   #4
ThunderSS
ThunderSS's Avatar
This bolt doesn't bottom out, but I wouldn't/didnt use it to torque the pulley down..
Originally Posted by 2Tightwads View Post
Ls7 bolt to install/botton out, supplied new ls3 bolt for final bolt down...problem solved.
510 HP/485 Ft. Lbs
Old 11-04-2009, 01:44 PM   #5
2Tightwads
Banned
Red face
What did I miss?
Old 11-04-2009, 01:45 PM   #6
GaryTucker
I meant if they were using a thinner pulley or something other than the set up you had...sorry that wasn't clear. I can't tell you how many bolts I've had to pull out over the years because a customer didn't "think it through" when the bolt stopped turning and it wasn't all the way in.
The comment wasn't aimed at your process. Obviously it works on the setup you are using. Nice to have an affordable alternative for sure!
Old 11-04-2009, 02:06 PM   #7
2Tightwads
Banned
Looks like I missed the fact that PN # 11570163, IS the LS7 factory original crank bolt. Sorry I didn't have the PN # memorized. I get the pulley started (stop about half way) with the LS7 bolt so as not to tear up threads, put back in the old stock bolt to bottom out the pulley and torque as necessary, then put in my new supplied bolt to do the final torque/angle. Sorry we weren't fully clear, we're from TEXAS!
Old 11-04-2009, 05:18 PM   #8
ThunderSS
ThunderSS's Avatar
aint no problem guys...
2tightwads, I figured thats the one you where in reference to.. that was the only smiley for it...
510 HP/485 Ft. Lbs
Old 11-04-2009, 05:37 PM   #9
rex113
rex113's Avatar
Drives: 2010 2ss silver/cyb
Hey ThunderSS thanks for the tip,I am going to do the underdrive pulley also.Did you feel any difference with the new pulley?
rex113 is offline   Reply With Quote
Old 11-04-2009, 05:42 PM   #10
ThunderSS
ThunderSS's Avatar
That I couldn't tell,
I definatley feel a difference but that's because I did a cam swap/ Full Exhaust, and tune along with it...
Soooo....
Yeah I felt a difference...lol
510 HP/485 Ft. Lbs
Old 11-04-2009, 10:06 PM   #11
DaddySS
Kept The Faith
DaddySS's Avatar
Drives: 2011 Camaro SS Convertible
I don't recommend that you pull the balancer on with a bolt. For those of you not familiar with the LS engines, there have been too many horror stories of damaged threads and ruined cranks. I recommend threaded rod and then pull the balancer on with nuts and washers.
DaddySS is offline   Reply With Quote
Old 11-05-2009, 09:42 AM   #12
2Tightwads
Banned
Wink
I have to admit I do have one of these (see below link)...hope I don't get modded (banned) for mentioning it here.
http://ls1tech.com/forums/tools-fabr...ol-pics-5.html
P.S. I don't SELL this thing...its simply a REFERRAL!
OR Hey if you want to be a baller and spend on pro tools go here... http://cgi.ebay.com/ebaymotors/GM-Ke...motiveQ5fTools
Old 11-05-2009, 12:18 PM   #13
MoranoRacing
Drives: 2005 GTO, 1973 Camaro
I used a summit racing pulley for my 05 GTO, and the instructions said to put it in the oven for a little while and it will install alot easier. I tried it and had no problems. I used the same bolt to get the pulley on more and then replaced it with a brand new bolt. No Problems!!
MoranoRacing is offline   Reply With Quote
Old 11-05-2009, 12:21 PM   #14
2Tightwads
Banned
Thumbs up
I wouldn't put anything like this in the over myself (agree it works though!)BUT personally in the beginning I did use a torch to heat the center section of the new pulley once prior to install and it does slide right on. Atleast far enough to alleviate any 3-4 threads grabbing only issues. Today I recommend just using proper tools that won't cost you an arm and a leg as mentioned above though.
$6 bolt, $30 tool, or heat it and take your chances. All worthy ideas I guess.
DIY : Install underdrive pulley on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 34 09-30-2013 09:25 PM
Texas Speed & Performance 2010 Camaro SS Underdrive Pulley Kit Jason 98 TA Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 03-17-2012 11:22 AM
Underdrive pulley 10-HP gain. rex113 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 10 01-05-2010 07:25 PM
2010 SS - Corsa, Rotofab, U/D Pulley - VIDEO Chris@Livernois Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 08-28-2009 10:06 PM
Texas Speed & Performance 2010 Camaro SS Underdrive Pulley Kit Jason 98 TA V8 Bolt-Ons & Tunes 1 05-20-2009 11:40 AM
