Old 09-12-2017, 01:34 PM   #1
Blackwolf666
Blackwolf666's Avatar
Drives: 2013 camaro ss
Radio still on after closing door
It's been fckn hot here so ill go to my car and lower the windows a bit. I noticed when I go thru my passenger door and put key in ignition lower windows take key out close shotgun door the radio is still on I have to open and close the drivers side. Anyone know why?
Blackwolf666 is offline   Reply With Quote
Old 09-12-2017, 01:37 PM   #2
FacePlante
FacePlante's Avatar
Drives: 2015 Camaro 2LT RS
It stays on because it assumes the driver is still in the car since their door was never opened after taking the keys out.
FacePlante is offline   Reply With Quote
Old 09-12-2017, 01:43 PM   #3
Grey2ss
Grey2ss's Avatar
Drives: 2015 Camaro 2ss
I have quick question is there anything I can set on mylink to shut off ipod. Or does it just stay on unless you power it down and take if off the usb. Thanks not trying to hi jack thread.
Grey2ss is offline   Reply With Quote
Old 09-12-2017, 04:51 PM   #4
ZZZTOPZZZ
ZZZTOPZZZ's Avatar
Drives: 2013 L99 2SS Vert
If I'm not mistaken, the IPOD should power down on its own after a period of time. You may want to check your IPOD settings.
ZZZTOPZZZ is offline   Reply With Quote
Old 09-12-2017, 06:46 PM   #5
kmarshall2121
kmarshall2121's Avatar
Drives: 2012 45th Anniversary Edition
My Avalanche does that. Had to spray a bit of WD40 on the plunger switch the depresses when the door closes. It wasnt fully extending when the door opened, therefore, the radio didnt know to shut off. Worked like it was supposed to after that...
its also set on a 10 minute shut off delay unless the drivers door opens... not sure if the passenger door does the same.
kmarshall2121 is offline   Reply With Quote
Old 09-12-2017, 06:54 PM   #6
InFiD3ViL
InFiD3ViL's Avatar
These cars don't have plungers or any sort of visible switch. Not that I could find at least.
Matter of fact, I have no idea how the hell it senses door open vs closed.
Old 09-12-2017, 07:29 PM   #7
orange devil
Also on these cars if you open the passenger door it won't trigger the ambient lighting to come on only when you open the driver door
orange devil is offline   Reply With Quote
Old 09-12-2017, 08:19 PM   #8
Grey2ss
Grey2ss's Avatar
Thanks for your help as always this site ROCKS!
Old 09-12-2017, 08:59 PM   #9
18LTLoveIt
18LTLoveIt's Avatar
Drives: 2018 Hyper Blue LT RS
Neat feature, when you let out folks while you're still in the driver seat.
18LTLoveIt is offline   Reply With Quote
Old 09-12-2017, 09:04 PM   #10
orange devil
By any chance do you guys know of any other way to opening the trunk if the battery dies in our key fob .. and for some chance the button is not working on the door?
Old 09-12-2017, 09:09 PM   #11
blewbyyou
blewbyyou's Avatar
Drives: Dusk SE
Put the back seat down climb through and pull the emergency release handle
blewbyyou is offline   Reply With Quote
Old 09-12-2017, 09:15 PM   #12
orange devil
You can pull the seat down from the inside ?you don't have to pop something loose in the trunk first to drop the seat down?
Old 09-12-2017, 09:54 PM   #13
Talladega
Talladega's Avatar
Drives: 2013 Camaro SS
Nope, there is a little cloth or leather tab at the top of the seat you pull and the back will lay down. I think the convertibles require a key to lay it down but I don't know for sure since I don't have one.
Talladega is offline   Reply With Quote
Old 09-12-2017, 09:57 PM   #14
prod
prod's Avatar
Drives: HHR
From the owners manual:
prod is offline   Reply With Quote
