Old 01-14-2018, 11:51 PM   #1
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
9.74@138 All Motor.
Finally got a clean pass in great air! Launching in 2nd gear with the 6l80.
Now I’m gonna go back stock bottom end to push the envelope in that catagory again!
https://youtu.be/iZJXlqBBsyM
Rhino79 is offline   Reply With Quote
Old 01-15-2018, 04:52 PM   #2
bhillakaiceberg
bhillakaiceberg's Avatar
Drives: 2011 2SS/RS & 2017 1SS
Congrats Man!! Hooking and Booking!!
2011 Chevrolet Camaro 2SS/RS L99 (1 of 782)
10.78 @125mph ALL MOTOR SBE
Built/Tuned by Me
2017 Chevrolet Camaro 1SS Auto
9.29 @144.57mph ALL MOTOR SBE
#TEAMGPI Gwatney Performance Innovation
bhillakaiceberg is offline   Reply With Quote
Old 01-15-2018, 05:00 PM   #3
shaggy2002
Drives: 2013 VR 2SS w RS 1LE
Nice run! What happened right after the 2-3 shift? DId you pedal it at the 8 second mark or was that two quick shifts?
shaggy2002 is offline   Reply With Quote
Old 01-15-2018, 05:02 PM   #4
Rhino79
Rhino79's Avatar
It lost fuel pressure. I made this pass at 19 psi.
Old 01-15-2018, 06:05 PM   #5
shaggy2002
So that means she has more in her?
Sent from my iPad using Tapatalk
Old 01-15-2018, 06:13 PM   #6
hammdo
'It's an experiment'
hammdo's Avatar
Damn Ryan, that’s fast! Congrats!
What the weight now of the car?
-Don
747 RWHP 794 RWTQ
Old 01-16-2018, 06:53 AM   #7
BFASTNOTLAST
BFASTNOTLAST's Avatar
Drives: 2012 SS LS3
Running out of fuel and still freakin flying!!! The SBE class is going to be fun this year, Ole red making a comeback!
BFASTNOTLAST is offline   Reply With Quote
Old 01-16-2018, 08:07 AM   #8
Bo White
Bo White's Avatar
Haulin
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 01-16-2018, 09:41 AM   #9
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
awesome run! proving again that these motor's are freakin BEASTS providing a great combo is put together! did you notice any lean out on the plugs? and what is the rear gear ratio?
Old 01-16-2018, 11:16 AM   #10
Rhino79
Rhino79's Avatar
It hadn’t one lean spike after the 2-3 shift but afr was good through the run because the ecm compensates for the lower pressure by working the injector harder. 3.91 gear.
Old 01-16-2018, 03:57 PM   #11
frankwjr
frankwjr's Avatar
Old 01-16-2018, 03:59 PM   #12
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
It just keeps getting better!!!!
Damn son!!
Old 01-16-2018, 08:54 PM   #13
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
Awesome pass!
Tuned by Ben @BWTuned, GPI 416 w/GPI S/C Cam, GPI Ported Heads, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump/DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Rossler T400 w/t-brake, Circle D Converter, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.73 Diff, DSS Axles, Wiles Racing Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
