Old 11-13-2009, 10:17 PM   #1
general23cmp
Drives: 2010 RS SS
fuel injectors and pump limits
At what point (HP) will the stock injectors be insufficient? Same question for fuel pump, without a BAP, and then with a BAP? Going custom forced induction and need to know when to expect to hit the wall with each.
general23cmp is offline   Reply With Quote
Old 11-14-2009, 02:58 AM   #2
Will@Apf
Will@Apf's Avatar
Drives: corvette
Forced induction??? You already need injectors/fuel pump
Will@Apf is offline   Reply With Quote
Old 11-14-2009, 03:13 AM   #3
mtcwby
High on "The Camaro Life"
mtcwby's Avatar
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam
Send a message via AIM to mtcwby
The stock fuel pump will handle well over 600 RWHP easily, but the injectors need to be increased with any forced induction.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
mtcwby is offline   Reply With Quote
Old 11-14-2009, 03:29 AM   #4
Will@Apf
Will@Apf's Avatar
Drives: corvette
WOW on that fuel pump....bad little suckers.. i replace them over 500rwhp but that's only because i don't like to push things, some call it overkill i just call it safer ..
Old 11-14-2009, 09:52 AM   #5
Sean@Swift
Sean@Swift's Avatar
Drives: 70 Chevelle
The Stock pump should do about 600Whp in theory....BUT. What we have seen is that the pump at 90% Duty cycle is good to about 500Whp then it just cant keep up with the normal requested 58Psi.
We just turboed an L99 with a GT37R. We were able to maintain AFR's in the 10.7-11.4 range throughout the pull at 7.5 psi of boost. That made 579.6RWHP and 598RWTQ.
But that was with 65# injectors at 90% duty cycle and they have a delta pressure of 38...they should be 65 at 58psi fuel pressure and should not be anywhere near static (90%dc). Those injectors should be able to support at least 800whp if the 58PSI were maintained by the pump.
Swift Performance is the Northeast's Installation and Dyno tuning facility for all cars that want speed.
Check out our new inventory, and specials on the site!!
www.swiftperformanceautomotive.com
860 823-1909
Sean@Swift is offline   Reply With Quote
Old 11-14-2009, 10:24 PM   #6
general23cmp
Drives: 2010 RS SS
So if I go big enough with my injectors, I should be OK with the stock pump and no BAP? I just wont have the pressure the injectors are rated for. Any downside really? I like the thought of not using a BAP since I think it is bad for pump life.
Old 11-15-2009, 10:52 PM   #7
Sean@Swift
Sean@Swift's Avatar
Drives: 70 Chevelle
IMO the injectors being static in order to keep up is not a good thing. They have no more to give, that being the case, if something were to happen where the fuel pressure dropped for some reason it can not be made up for by the injector duty cycle being opened longer. Also, like I said the Fuel pump is at 90% as well. so as far as pump life goes you have constant full load on it any time you are over 480+ HP. At the same time I have read threads where people are using a BAP and it is doing them some good (Keeps FP up 3-4 psi more than without it) and other threads where it is doing nothing for them. So I am still sorting through all of that as well. With the car I mentioned I think we are going to try a twin pump set up and see what happens. I figure 2 255LPH pumps working at 60-70% under full load is better than one working at 90% all the time. We will keep you updated.
860 823-1909
Old 04-08-2015, 10:10 PM   #8
SantosNL
Drives: 2012 Camaro 2SS
Sorry I'm a little new to this but what's BAP?
SantosNL is offline   Reply With Quote
Old 04-08-2015, 10:39 PM   #9
Bo White
Bo White's Avatar
Boost a pump. It adds voltage.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 04-09-2015, 05:37 AM   #10
2010SSRSM6
2010SSRSM6's Avatar
My '10 with a cam and header was pushing my comfort level with the factory pump and injectors at 480rwhp. Injectors were maxed out and fuel pressure was inconsistent. If you want to push it to 600rwhp your motor will not last long.
The last thing you want to do is starve the motor of fuel. Look at all the issues the Edlebroc SC's had with breaking the #7 piston due to fuel starvation..... Thanks but a good fuel pump and injectors are a hell of a lot cheaper than a new motor.
Old 04-09-2015, 06:46 AM   #11
ToddB
Drives: 2011 2SS Convertible Supercharged
ZL1 pump and ADM FPCM good for around 650hp
ToddB is offline   Reply With Quote
Old 04-09-2015, 08:57 AM   #12
PRO CUSTOM MARK
Drives: 2010 Camaro 2SS TURBO
I'm running 80 lb injectors with the stock pump. 5-6 psi you will be ok. I noticed a couple times at or above 7psi it started to lean out a little. I'm going to drop in a zl1 pump and be done
PRO CUSTOM MARK is offline   Reply With Quote
Old 04-09-2015, 11:18 AM   #13
Bo White
Bo White's Avatar
Those 80lb injectors are bored.
Totalled:
Old 04-09-2015, 06:45 PM   #14
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
This
Last thing I want to do is lose a motor. Failures are going to happen when it comes to power, more power, more stress. But I would rather have small failures that are manageable to fix, then to loose my motor over fuel issues. I think one day when I go forged, I will crank up the boost and see how long it lasts, but thats when I am ready to drop in a new package and have the money set aside for it to happen.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Nitrous info CamaroSpike23 Forced Induction - V8 65 03-19-2020 08:22 AM
Anybody Spray'n their SS yet - nitrous ? WeeZee Forced Induction - V8 37 12-29-2012 09:56 PM
Nitrous System ?????s PoleCat2SSRS2010 Forced Induction - V8 29 12-08-2010 05:55 PM
Nitrous Info Milk 1027 Wiki 0 08-12-2009 06:26 PM
Cadillac's direct-injection allows V6 to pump out 300-hp KILLER74Z28 General Automotive + Other Cars Discussion 2 03-27-2007 07:43 PM
