03-02-2018, 05:37 PM | #1 |
ZL1 fuel pump on n/a SS
So my stock fuel pump bit the dust today and I'm looking to replace it. I was pricing a new one today and noticed that the ZL1 pump isn't that much more expensive. Are there any drawbacks/benefits to running the ZL1 pump in the SS? I noticed a lot of people ran it in their SS, but mainly after going with a forced induction setup. I don't have many mods currently and will remain n/a for a couple of more years. With that said, is it even worth upgrading the fuel pump? I do plan on a cam within the next year or so. I'm ok with sticking to the stock pump, but was just curious of options since I was going to be going through the trouble of replacing the pump anyway. 2011 Camaro SS L99, Specs are in sig. Thanks
*SOLD* 1997 Camaro L36, Arctic white, manual, stock af Last edited by supashane; 03-02-2018 at 05:52 PM. |
03-02-2018, 05:52 PM | #2 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Unless you use a ZL1 Fuel Pump Control Module you won't notice anything it'll operate as a SS pump, once you add the ZL1 FPCM then you'll notice a difference with different injectors.
Orange Krush II
03-02-2018, 05:52 PM | #3 |
Interesting point, look forward to hear what other's have to say.
Follow Me @ssatann_ss |
03-02-2018, 05:58 PM | #4 |
Drives: 2011 convertible 2ss/rs Join Date: Sep 2015
Got a ss pump for a 100 plus shipping
Sent from my SM-N950U using Tapatalk |
03-02-2018, 06:01 PM | #5 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
long term goals? short term...do it! per above until FPM runs like stock but WTF...when/if(and you will!) step up N/A the hard part is done.
and lookup how to cut (CAREFULLY) thru the sheet metal under the rear seat right above where the access port is located...unless you WANT to drop the rear cradle(LULZ)... lots of peeps on here sell them for cheap...new is like $214 or $241 is(damn dyslexia!) any way for me it would be a no brainer...good luck OP....peace.
03-03-2018, 06:31 PM | #6 | |
2014 camaro 2ss/rs 1le [muffler & resonator delete, x-pipe , roto fab cai, 305 35 r20 rear tire 285 35 r20 front goodyear f1 supercar,1 7/8" tsp long tube headers with high flow cats, tsp Prc heads, K1 rods, Wisco pistons, 522whp 495tq, dynojet, btr stage3 cam kit, arp head studs and arp bolts.
03-03-2018, 10:33 PM | #7 |
Drives: 2018 Charger SRT 392 F8 Green Join Date: Aug 2010
You need a FPCM to make it work.
03-03-2018, 10:40 PM | #8 |
Angewendet Ingenieur
Drives: 14 Camaro ZL1 Join Date: Apr 2015
I would upgrade to the ZL1 it’s all pretty much plug and play. I wouldn’t want to be dropping the fuel tank more than once, (trust me been there done that!) Good Luck.
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah. |
03-04-2018, 01:43 AM | #9 |
Drives: 2012 2SS 45TH Anniversary Join Date: Mar 2012
As others have stated, the ZL1 pump is a direct plug n play drop in so zero modifications are needed. It will work just fine for all but the most insane n/a builds and even be good for mild FI if you ever decide to go that route
PFADT stage 3 suspension kit, SW LTH, SW cat less retro exhaust, MGW short throw, 3.91 gears, MRR Z28 wheels, Roto Fab CAI, SLP underpully, 255cc ported heads, TSP 229/236 Cam, ZL1 pump, Street Slayer Twin Carbon clutch, ID850 injectors, Snow Stage III Meth kit
480whp/460wtq tuned by Dynosty |
03-04-2018, 07:48 AM | #10 |
old school chevy rodder
There is a way to cut the right area out under the passengers seat in back over the area of the floor pan to make a square patch panel cover the area with some caulk/rtv and not drop the tank BTW. It was a DIY post so maybe you can find it there, good luck.
03-04-2018, 12:44 PM | #11 |
Thanks guys, you're awesome. that's what I needed to know. And definitely going the cut out route when it's time
*SOLD* 1997 Camaro L36, Arctic white, manual, stock af |
04-07-2021, 01:11 PM | #12 |
Drives: 2010 Camaro SS2 Join Date: Oct 2020
2010 2SS M6, Procharger, 8 rib, 12lbs, E85, Holley intake W/ fuel rails, TSP Blower cam 229/242 w/springs, Harden pushrod, FIC injectors, DSX Aux. fuel, Kooks long tube headers, xpipe, no cats, Mcleod twin disc, G Force Axles, DSS aluminum drive shaft, Detroit Trutrac, LPW dif cover w/BMR bushings, BMR Toe rods and Trailing arms, 5 Stars, M.T. E/T Streets, Hurst short throw, Mighty Mouse catch can, 702 WHP on Mustang Dyno 10.7 1/4 Mile
04-07-2021, 01:26 PM | #13 |
Holy 3 year old thread Batman
04-07-2021, 02:14 PM | #14 |
Drives: Camaro Join Date: Oct 2018
