Old 03-14-2018, 02:06 PM   #1
500hpbluez28
YUDLOSE
500hpbluez28's Avatar
Drives: Supercharged 2010 ABM 1SS
Anyone with a maggie running this firewall cover?
I have some damage to the insulation on the firewall that I have looking at and I saw this aluminum cover is available. Before ordering I wanted to see if anyone with a Maggie jackshaft style blower is using this as I would like to be sure it will work before buying a $200+ piece. My concern is the rear cog drive and coolant lines back there being in the way. Any help is appreciated.
Trey Jenkins
2010 Supercharged ABM SS Camaro LS3 #400 Order Number: NJGC85 Build Date: 06/24/2009
1996 Blue Z/28 Camaro 396 stroker in the process
1994 Red Z/28 Camaro
500hpbluez28 is offline   Reply With Quote
Old 03-16-2018, 08:37 AM   #2
500hpbluez28
YUDLOSE
anyone?
Trey Jenkins
Old 03-19-2018, 10:18 AM   #3
SSBUSDRVR
SSBUSDRVR's Avatar
Drives: '11 2SS/RS IBM/BLK M6
Don’t have a Maggie have Centri but interested in Fit /Installation of that Piece as well. Usually not one for any bling but that would look so much better than the shredded Firewall material have now. Hope someone can help you here.🙂
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416
ProCharger Stage II D1X Race ,Monster Triple,Alky Control Meth Inj, Forgestar F14 Drag Version and a bunch of other blah blah blah.838/688 at 12lbs Street Friendly
SSBUSDRVR is offline   Reply With Quote
Old 03-21-2018, 01:34 PM   #4
500hpbluez28
YUDLOSE
Originally Posted by SSBUSDRVR View Post
Don’t have a Maggie have Centri but interested in Fit /Installation of that Piece as well. Usually not one for any bling but that would look so much better than the shredded Firewall material have now. Hope someone can help you here.��
I placed an order the other day for it as I decided to take a risk and give it a shot. I may end up having to do some cutting to make it work but hopefully I can make it work either way. We shall see.
Trey Jenkins
Old 03-22-2018, 07:21 AM   #5
Missile Man
Missile Man's Avatar
Drives: 2010 2SS/Black
I have a Maggie, looks like it would interfere with the SC
2010 Black 2SS L99
Mods:
* CAI Intake
* Magnuson MP2300 TVS Supercharger/RDS Spacer
* Vector Motorsports Tune
* Stainless Power LT/Hi Flow Cats/Tru X-* Pipe/36" J-Pipes/40 Series
* R1 Concepts ceramic pads and slotted/drilled rotors
Missile Man is offline   Reply With Quote
Old 03-22-2018, 01:28 PM   #6
swiftkart
swiftkart's Avatar
Drives: 2010 SS/RS LS3 M6
I have that full under hood polished kit except for the firewall piece, I wasn't sure if it would clear the rear cog drive setup so I never got it, I will be waiting to hear back on if it works so I can get one and finish out my engine bay.
swiftkart is offline   Reply With Quote
Old 03-23-2018, 09:48 AM   #7
500hpbluez28
YUDLOSE
I am certain I will be able to modify it and make it work but I know it will not bolt right on the car unless stock. From looks of things I will be trimming quite a bit off of it but long as when I am done it hides the damaged part of my firewall insulation it will be all worth it.
Trey Jenkins
Old 03-23-2018, 10:26 AM   #8
Epinephrinejunky
Epinephrinejunky's Avatar
Drives: 2010 Camaro 2SS/RS (R6P)
Let us know how it works once you have it installed and running for some time!
Epinephrinejunky is offline   Reply With Quote
Old 03-26-2018, 10:40 AM   #9
SSBUSDRVR
SSBUSDRVR's Avatar
Yes please. Would probably Powdercoat it black here. Can't see in this pic they took, but firewall material is tore up pretty good. May just be me but eye is drawn right to it when open the Hood. Shouldn't be too much an issue fitting one in there.
Old 03-26-2018, 11:06 AM   #10
500hpbluez28
YUDLOSE
My plan is to hydro coat it once I have it trimmed and fitted to work with my application. Just got it last night so hoping to start the fitting process this week sometime. Looking at your application you probably could use it as is. My upgraded fuel system lines and hoses from the Maggie are all back there where this goes.
Trey Jenkins
Old 03-26-2018, 11:19 AM   #11
SSBUSDRVR
SSBUSDRVR's Avatar
Thumbs up. Look forward to seeing how it goes.
Old 03-26-2018, 11:51 AM   #12
500hpbluez28
YUDLOSE
hopefully well. Hate to know I wasted a couple hundred bucks
Trey Jenkins
Old 03-29-2018, 09:33 AM   #13
500hpbluez28
YUDLOSE
Well, I did some cutting and test fitting and I ended up having to trim quite a bit off. IT was late so I did not get any pics of it on the car but I am taking the piece to my hydrocoat guy tomorrow to get done. It is gonna hide most of my damage. Far as other people's application, note that even with me cutting to work for my car it is a very tight fit getting it into position so I can only imagine how much of a PIA it would be if I could of used it as is. I used 2 (1.5 actually lol) cutting wheels trimming so before you start keep that in mind if you don't have an extra. I will post pics once I get it back and put on. Hoping the dip will work, if not I will just paint is ABM. Also to help clean up the look, I bought some edging trim from Camaros of Michigan to go over where I cut it.
Side note, if you are not able to use the piece and have to cut to make it fit, the finish it comes in will most likely not work as it had some discoloring where I cut so plan on having it painted, dipped, powder coated.
Trey Jenkins
Old 04-14-2018, 07:46 AM   #14
500hpbluez28
YUDLOSE
Well I got the piece back from paint. It will be next weekend before I will be able to add the edging on the side I cut and put it on the car
Trey Jenkins
