03-19-2018, 06:30 AM | #1 |
Drives: 2013 Camaro LT Join Date: Feb 2018
I have 2013 LT2 does anyone elses heater suck???
My heater is just trash you cant even feel anything on the drivers side if you use the floor vent and then its ok if you use the normal vents is this just my car or is the heater in this car trash, My last caar was A 370Z and I never had a single complaint about the heater or anything, I am starting to regret this caar so much!
03-19-2018, 07:18 AM | #2 |
Drives: 2010 1SS RS M6 Join Date: Jan 2015
Check your coolant level
Vararam intake, gmpp exhaust, borla stainless long tubes, cat less, jannetty tune, bmr lowering springs, heritage grill , smoked lenses
03-19-2018, 07:25 AM | #3 |
My heater could cook a human being in 15 minutes.
No issues here.
03-19-2018, 09:54 AM | #4 |
Drives: Black camaro 2ss 45th Join Date: Jan 2018
You talking actual temp of the air you have it set to or the amount of air coming out of the vents? Cause if it’s amount of air coming out of vents when I have it set to mid level vents, the amount of air coming out sucks. Very little air comes out. Where as my 2010 became a wind tunnel
03-19-2018, 10:53 AM | #5 |
Drives: 2015 Camaro 2SS Join Date: Oct 2016
My 2010 is like an oven, and that's despite the fact I am going to be changing the heater matrix soon.
So even with a blown matrix it should still be toasty hot. What does your temp gauge read at operating temperature? Last edited by Gordo-D; 03-19-2018 at 01:05 PM. |
03-19-2018, 10:58 AM | #6 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
is this an airflow or air temperature issue? if it is an airflow issue then you need to replace the ac blower fan:http://www.camaro5.com/forums/showthread.php?t=265265
if it is a temperature issue then you need to see if you are getting hot coolant to the heater core and if not you will need to add coolant to the radiator when it is cold. still no heat? i'd take it to a shop.
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
03-20-2018, 03:13 PM | #7 |
Drives: 2012 Camaro RS 2LT 6spd man Join Date: Aug 2013
is your eng even getting up to normal operating temp? If not, replace the tstat. Also, like a lot of statements here, check your coolant level as well, could be a little low, ok, a lot low.
03-20-2018, 03:25 PM | #8 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
If it's airflow problem, the first thing to do is check your cabin air filter.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
03-21-2018, 05:47 PM | #9 |
old school chevy rodder
Two Camaro gen 5 owner since 2010...bake taters on my dash...... Like he said check your cabin air filter and you may have a problem with a actuator for the trap doors of heating system and need to check over others posts in repair posts. but its a good heater unless your blower motor goes out and then ....OMG on a Camaro most pull the windshield to pull the dash...I mean I have seen a post or two over the years how to do it without doing that and its still a major pain.Good Luck. Hopefully its more your never changed air filter........
2021 Wild Cherry ZL1 A10, Sunroof, Data,Red Carbon Interior, Nav, RotoFab Big Gulp , Elite x2ultra, Borla ATAK, Driveshaft shop, full BMR susp, Speed eng. valve covers, intercoolers, ATI , 2650 MAG, DSX lid, 103 NW, JBA shorties, Lingenfelter check, 1le wheels, spoiler and diveplanes, PCV, Big3racing ice tank, [SIGPIC]etc....
03-21-2018, 06:08 PM | #10 |
Drives: 2014 2LT RS Summit White Join Date: Apr 2017
I have the same LFX engine in my 2014 and as others have said, it will roast me out of the seat on high.
03-22-2018, 01:09 PM | #11 |
Drives: 2012 camaro 45th 2ss/rs Centri SC Join Date: Nov 2016
i've had dozens and dozens of cars over the years. The heater in this camaro blows me away. Can't ever have it on it's hottest setting
Jeremy
-2012 Camaro SS 45th M6-Kraftwerks Supercharger -2003 Avalanche z71-6" on 35's. DD 290k miles -66 mustang fuel injected resto-mod |
03-23-2018, 09:15 AM | #12 |
Drives: The red one Join Date: Jan 2015
Mine gets hot before I even get to the end of the block. Then again, I live in the desert. LOL.
03-24-2018, 12:08 AM | #13 |
Mine will do this in 14 minutes.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears. |
