Which type of gas?
This maybe a dumb question but what type of gas are you all putting in your Camaro's?
I just got mine and filled her up twice so far. I used Regular and the gas attendent insisted I'm using the wrong gas and should use Super. Is he right? Or did he just think my car was more expensive than it is. |
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Black Camaro 2SS/RS Join Date: Aug 2009
My boyfriend don't mind it. |
Yeah, the V6 is fine with regular -- it makes no difference.
camaro blogger
Correct, the V6 will burn pretty much anything besides diesel
Thanks guys, don't want to pay more if i don't have to
#6 |
#7 | |
![]() Drives: 2010 Camaro 2SS VIN#11184 Join Date: May 2009
Lingenfelter 550 HP TVS2300 Supercharger Package, Hennessey CAI, Pedders Extreme XA Drag Package and Sway Bars (waiting to take delivery) Painted gills, stripe, and bow ties, tinted windows to 30%, smoked lights, Orange headlight/fog light halos, NOWEEDS, and GMPP Exhaust
#8 | |
If there's been regular gas in your tank, I urge you to try the fuse pull, because your computer will probably have shifted to the lower octane table. Check the forum on Engines, it is stickied to the top. The difference is tremendous. I had a gas station attendant accidentally put 7 gallons of regular in a tank otherwise full of 93, and that made the octane table jump to the lower setting. The computer is supposed to re-check this itself in case you've put in better gas, but it doesn't. Fuse pull. Do it. Trust me.
My boyfriend don't mind it. Last edited by CamaroFemme; 11-17-2009 at 03:37 PM. |
#9 |
Lightning & Thunder
The SS will run on regular, but only in a pinch. Don't put less than 91 octane in it unless you have to. Yor dealer is wrong. Tell him/her to read the manual.
#10 |
![]() ![]() ![]() ![]() ![]() Drives: 2012 1SS IOM Join Date: Oct 2009
#11 |
Raining Blood
Drives: 2014 SS Performance Sedan Join Date: Oct 2009
Agreed.
SS = Premium LS & LT = Regular I wouldn't take any more advice from a dealer that doesn't know the difference....
Ordered 1/9/12 - Born 2/3/12 - Delivered 2/21/12 - '12 1SS/RS Summit White - TRADED.
![]() 2014 SS Performance Sedan #2974 - Red Hot 2 - S/R. & Spare. Built 01/09/14 #238 of 291 as configured |
#12 |
![]() Drives: RJT L99 500HP Join Date: Aug 2009
I believe all SS's are tuned for 91 so running 93 won't make it run any better than 91 unless you get it tuned for 93. At least that's how I understand it. Running 87 can kick you down into the low octane table which will have a very negative reaction on performance. Keep it 91 or above to stay with the more advanced ignition timing. Now if you have 93 available and want better performance then go get it tuned for 93 and it will run even better but then you void the warranty. Unfortunately out here in CA we only have 91 so can't get a custom tune for 93.
#13 |
![]() ![]() ![]() Drives: '10 Camaro SS Join Date: Apr 2009
I use 91 becasue it's the highest Octane available where i live. Would run 93 if i had that option.
2010, SIM, 2SS/RS, LS3, CGM Stripes
#14 | |
| Mixing Gas to get 93 Octane | FarmallsForever | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 29 | 06-03-2013 06:19 PM |
| Hard to fill gas tank | herkman | 5th Gen Camaro SS LS LT General Discussions | 35 | 11-09-2009 06:16 PM |
| Check your Order here | bvonscott | Camaro Price | Ordering | Tracking | Dealers Discussions | 665 | 06-29-2009 01:00 PM |
| Fuel pump or bad tank of gas? | Boomer Sooner | 4th Generation Camaros | 25 | 01-02-2009 06:34 PM |
| 5th Gen Camaro LS3 info from Chevy Hi-Po...READ | TAG UR IT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 295 | 03-07-2008 10:06 AM |
