Old 04-23-2018, 09:59 AM   #1
LordAndroid
LordAndroid's Avatar
Drives: 2013 ZL1
My Z is leaking but I can't figure out what kind of liquid it is
Any one know what kind of liquid this is by any chance. I just moved to PA from Chicago and I dont have any tools with me i cant get up under it to look. This has me freaking out. The car has been sitting inside all winter.
Sent from my 9th Guardian of the Galaxy
LordAndroid is offline   Reply With Quote
Old 04-23-2018, 10:20 AM   #2
ColdfuzionTN
Drives: 2012 Camaro SS
Any smell to it? Looks like water to me, could it be coming from a leak in the building?
ColdfuzionTN is offline   Reply With Quote
Old 04-23-2018, 10:22 AM   #3
tstodii
Drives: White 2015 Z/28
Looks like water... does it have a smell or certain feeling b/w your fingers that is different from water? It looks clear on my PC screen and I don't believe they used many clear liquids in the car
tstodii is offline   Reply With Quote
Old 04-23-2018, 10:28 AM   #4
LordAndroid
Drives: 2013 ZL1
The liquid has a blueish hue to it doesn't really smell nor does it have any kind oil based consistency. I thought it was windshield washer fluid because it does look and feel like it but it has no smell and I looked my wiper fluid resivour is full. I'm stumped. I'm afraid to use the car if it is related to the car I dont want make matter worse by using it.
Old 04-23-2018, 10:32 AM   #5
NoDakZ/28
NoDakZ/28's Avatar
Drives: 2014 Z/28 CTF
Do you have a trunk mounted methanol tank?
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM
NoDakZ/28 is offline   Reply With Quote
Old 04-23-2018, 10:36 AM   #6
LordAndroid
Drives: 2013 ZL1
No sir no meth just standard bolt ons exhaust cold air intake pullys headers
Old 04-23-2018, 10:51 AM   #7
ColdfuzionTN
Coolant levels topped off ?
Old 04-23-2018, 10:52 AM   #8
LordAndroid
Drives: 2013 ZL1
Coolant is filled to spec unfortunately.
Old 04-23-2018, 10:59 AM   #9
ColdfuzionTN
What about the coolant level for the supercharger cooler? I know color is off but only other thing I can think of.
https://www.camaro5.com/forums/showthread.php?t=521064
Old 04-23-2018, 10:59 AM   #10
Stro
Stro's Avatar
Drives: 2013 ZL1
From the stain on the concrete, it looks like the same pattern has been on the floor before. Hard to say from just looking at the pic, but perhaps it's coming from somewhere like a backed-up floor drain or something similar. Where in PA are you located?
Stro is offline   Reply With Quote
Old 04-23-2018, 11:06 AM   #11
LordAndroid
Drives: 2013 ZL1
I'm in Pittsburgh. I haven't checked the SC coolant but isn't this alot of liquid for it to be SC coolant? The pooling seems to be coming from the back under the front of the car its dry. I'll check the SC coolant after work
Old 04-23-2018, 11:27 AM   #12
Crash76
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500
There is nothing on the back of car that would leak a clear water like fluid... if there is nothing under the front of the car, it is not car related
That much fluid all you would have to do is open the hood, look at the mess in the engine bay
Crash76 is offline   Reply With Quote
Old 04-23-2018, 11:30 AM   #13
LordAndroid
Drives: 2013 ZL1
I had never seen this liquid before until now freaked me out. Just when my extended warranty expired.
Old 04-23-2018, 11:36 AM   #14
ColdfuzionTN
I agree on the coolant I doubt it's that from the amount and color just wanted to make sure its checked. Again my first thought is leak in building or like mentioned clogged drain.
Way I check fluids, If its in the rear it stinks, if its in the front its oily. lol. Since your's is clear I'd only say meth or washer fluid but its neither so I'd just move car, mop it up and see if it returns.
