![]() Drives: 2014 camaro 2SS 1LE Join Date: Apr 2018
Oil catch can separator
I want to put on a oil catch can, I am looking at two products rxp and moroso.
Anyone on here use either product? |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 1SS 1LE Black - Std Exhaust Join Date: Mar 2013
I haven't but am hugely interested too.......
We mainly sell a bunch of the Elite Engineering set ups. Very high quality and they are not over priced.
![]() Drives: 2015 Z/28, 2015 1LE Join Date: Feb 2017
I have the moroso one. I don't have a problem with it.
Hard to want.
Drives: 2020 red hot 1SS 1LE Join Date: Aug 2017
Maybe a dumb question but why do you need one? Not being snarky, just curious.
#6 | |
It catches the oil that are engines should burn off. And gunks up our engines. You should watch a YouTube video, it's very interesting. I am ordering one just haven't made up my mind which brand I want. Last edited by Camaroguy066; 04-24-2018 at 03:48 PM. Reason: Wording |
#7 |
![]() Drives: 2014 white 2ss rs 1le Join Date: Mar 2017
It has been discussed a lot...when I was curious I did a google search...basically there is the "dirty" side and the "clean" side for oil bypass. The dirty side uses a catch can and the clean side uses a separator. Both are beneficial. The 1LE had a dealer option for a separator. For myself, I narrowed it down to Elite Engineering with the option to add the separator to the package. I think a lot of people recommend the Mishimoto.
#8 | |
![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro Join Date: Nov 2009
Best is to look at actual testing done with catchcans. The Moroso traps app. 30% as you can see in this independent testing vs our Patented design that traps 95% plus. Same testing performed with Mishimoto and most any other design.
Our E2-X uses this patented design and is the most effective on the market period. Our "catchcan challenge" still stands where anyone is urged to do the testing the same way: Very few cans on the market trap even 30% of what enters them, most fall into the 15% range, so you can;t rely on opinions or marketing hype, test yourself and see firsthand. Tech@EliteEngineeringUSA.com |
#9 |
These absolutely work !!
Been many "discussions" over the years but I just emptied mine today while changing the oil and I bet there was a good 3-4 oz in it. I empty it probably 3 times between each oil change with the same amount every one of them.
'14 1LE, Recaro, Cammed, Headers, Hi Flows, CAI, Tuned, 486 RWHP
https://www.youtube.com/watch?v=H57UfKCO0EY&feature=youtu.be |
#10 |
#11 |
![]() Drives: [COTW 8/3/15] 2010 Camaro SS L99 Join Date: Mar 2015
Use a Moroso and it works well for me..
A Little bit of power. ALL WORK DONE BY ME!
Just added 2021 ZL1 1LE to the Stable! https://www.camaro5.com/forums/showthread.php?t=418273 ![]() |
#12 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
Elite here on both my 1LE and MX5
#13 |
I'm going with elite with the clean side. That's just the brand I like.
2014 camaro 2ss/rs 1le [muffler & resonator delete, x-pipe , roto fab cai, 305 35 r20 rear tire 285 35 r20 front goodyear f1 supercar,1 7/8" tsp long tube headers with high flow cats, tsp Prc heads, K1 rods, Wisco pistons, 522whp 495tq, dynojet, btr stage3 cam kit, arp head studs and arp bolts.
