Old 04-29-2018, 12:42 PM   #1
hush18
hush18's Avatar
Drives: 2012 2LT RS
Brake Whooshing Noise After V6 to V8 Conversion
I did the v6 to v8 brake conversion yesterday. A friend and I replaced the lines with stainless steel, put on the new rotors, pads, and calipers, then we swapped the master cylinder for the v8 master cylinder after bench bleeding it. We then did a pump method brake bleed.
A strange issue that I’m running into now is that when the car is on and in park, the pedal feels spongy and when the pedal travels about halfway down, there’s a whooshing noise coming from the firewall near the pedal. What could this sound be? Is it an indication that something needs to be fixed or is this now going to be the new normal? I would expect the pedal to be a lot harder than it is with the new brake setup. When the car is off and the pedal is pumped, it does get very hard.
Thoughts?
hush18 is offline   Reply With Quote
Old 04-30-2018, 12:00 AM   #2
43Camaro
43Camaro's Avatar
Drives: [COTW 8/3/15] 2010 Camaro SS L99
Get a power bleeder and bleed the brakes again just to eliminate possibility of air in the system.
A Little bit of power. ALL WORK DONE BY ME!
Just added 2021 ZL1 1LE to the Stable!
https://www.camaro5.com/forums/showthread.php?t=418273
43Camaro is offline   Reply With Quote
Old 04-30-2018, 11:31 PM   #3
Pro-tuned
Angewendet Ingenieur
Pro-tuned's Avatar
Drives: 14 Camaro ZL1
Check vacume booster
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah.
Pro-tuned is offline   Reply With Quote
Old 11-02-2018, 09:48 AM   #4
600hp-lpe
Drives: 2010
spongy pedal - bleed the brakes again. you may need to get the ABS to cycle as well.
600hp-lpe is offline   Reply With Quote
