05-16-2018, 04:53 PM | #1 |
missing out at wot=stumped
hey guys I could sure use a hand here, I think i might have a fuel pressure issue but not sure. car was on the dyne last saturday after cam and bolt ons and ran fine. I drove it for a day or two (no wot)and its fine this morning my little boys says go fast daddy, alright here we go but not so fast like. seems to run fine except for wot. after i dropped him off i made a couple hard pulls and it does it pretty bad. not down low in say 3rd gear but if you hammer it 1st it does it, hammer it in 2 from about 3k does it. changed plugs and wires for giggles. checked and cleaned maf. sprayed starting fluid over anywhere air could leak. got out the sct x4 and its showing about 19psi. seems awful low to me but does the sct read it at the pump or up at the rail or does it matter. driving me nuts cause i just bought this thing, done the work and now this. had it about three months and have driven it about 200 miles. no codes by the way.
'11 2SS/RS M6
05-16-2018, 05:25 PM | #2 |
just took it out right now again and it seems like it runs fine before everything gets heatsoked. ran fine several pulls for 8-10 minutes then runs like crap again. kinda feels and sounds like an old rev limiter that drops cylinders.
'11 2SS/RS M6
05-16-2018, 05:53 PM | #3 |
Drives: 2015 SW 2SS 1LE Join Date: Jan 2018
What mods have been done to the engine?
Maggie 2650 @ 18psi/ 75mm 10 rib/ Dual alky nozzles/ Roto-fab/ ARH 2" Lt's/ GT-12 cam/ ZL1 3.23 Conv./MGW/RPS triple carbon clutch/RSG tranny upgrage/Pedders Ex. XA w/ remote cans and a lot of other crap 897/8??@tires
05-16-2018, 09:23 PM | #4 |
tsp stage 3 cam, headers, exhaust and cai. and dyno tune Sent from my iPhone using Tapatalk
'11 2SS/RS M6
05-16-2018, 09:40 PM | #5 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
Man, I’m no paid shill for anyone but I’ve been hanging around here long enough to know that if Ted Jannety, Ryan at GPI, or Dyno Steve didn’t do your tune on your Camaro, post mods, yer Fooked. My nightly prayers include, ‘please Lord, let these guys still be around when I finally mod MY Camaro!
05-16-2018, 10:12 PM | #6 |
Drives: Camaro and Sierra Join Date: Jul 2012
While ryan is a good tuner and I'm running GPI cam, those are by far not the only three. They are really just the three talked most about on C5.
05-16-2018, 10:30 PM | #7 |
And represent goodly portion of a fairly large group who share similar vehicles. Hard to argue with that
05-16-2018, 11:12 PM | #8 |
Drives: [COTW 8/3/15] 2010 Camaro SS L99 Join Date: Mar 2015
Fuel pressure? AFM gauge reading? Injectors? I had this happen on occasion and i was running out of fuel. It was not frequent, but happened at WOT after I had been running for a while. After I upgraded injectors, pump and fuel rail the problem disappeared.
A Little bit of power. ALL WORK DONE BY ME!
Just added 2021 ZL1 1LE to the Stable! https://www.camaro5.com/forums/showthread.php?t=418273 |
05-17-2018, 08:48 AM | #9 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Was the 19lbs at idle? That is very low. I'm running around 60lbs, give or take, at the rail. Under load, it dips a little, a pound or two. Sounds like you do have a fuel delivery issue.
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
05-17-2018, 10:34 AM | #10 |
Drives: o Join Date: Jun 2017
The pressure sensor is forward of the fuel tank in the feed line.
The pressure, key on engine off command pump on with scan tool should be 50-60 psi. Last edited by Gasoholic; 05-17-2018 at 11:02 AM. |
05-17-2018, 11:54 AM | #11 |
What part of S. Central Texas are you at?
05-17-2018, 02:42 PM | #12 |
i am in new braunfels, 25 miles east of san antonio. the 19lb is coming from the handheld but it is pretty consistent 19 everywhere which kinda leads me to believe that’s just what the sct is reading. i was leaning toward changing the pump today but since it shows 19 when cold and runs fine then shows 19 when heat soaked runs like crap i don’t know if the sct is misreading it or what the heck the deal is. i’m going to try to find a gauge to put on the rail. i’m not really getting how it can runs so bad and not throw a code also.
'11 2SS/RS M6
05-17-2018, 03:11 PM | #13 |
You know one of the best tuners is in your backyard? HPT
05-17-2018, 03:25 PM | #14 | |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Ls1tech isn't too kind to jannetty or RDP... Check out some threads there if you want more info
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 Last edited by xc_SS/RS; 05-17-2018 at 03:44 PM. |
