![]() Drives: Sofia: 2012 Chevy Camaro 2SS LS3 Join Date: Feb 2012
Aftermarket dash kit advice (PAC vs Scosche vs Metra)
Hey everyone,
I've been out of the Camaro5 loop for a very long time, but I came back on since I am looking to upgrade my factory radio in my 2012 (no MyLink available) to a Wireless Android Auto HU. I would like dash kit advice. Doing some research on here, most of the main dash kits seem to be Scosche, Metra, or PAC. I have the BA audio system, with a sub and amp hooked via the rear inputs. I have the backup camera in my rearview. I would like to have the backup camera moved to the HU, if possible, and still retain the chimes (I didn't even realize you'd lose that), and well retain as much of the functionality as possible. Any reason to go with one or the other???? Like do you lose things in one kit but not the other???? I don't like the Metra look at all, I'll probably go with PAC or Scosche. Can anyone lend some insight on why they chose one over the other? I saw something about backup lights not working after a while, the heated seats not working, etc etc. Please, give me your thoughts. I did a search and didn't see a thread that directly compares just the kits, forgive me if there is one. If there is, if you could kindly point me to it, I'd appreciate it. Thanks!!!!
Interior: 2-tone gray interior, Blue Dome and trunk lights, L.A. Dodgers floor mats (to come: footwell lighting)
Exterior: Sunroof, custom painted gray stripes, vinyl Bowtie emblem decals, Holographic Transformer decals, white license plate LED lights Sounds: Stock highs, Alpine MRX-M100 amp mated to a 12" JL Audio W3 in a ******** Stealth enclosure Engine/Performance: Hurst Short Throw Shifter, Rx Catch Can painted IBM, (to come: JacFab CAI, muffler delete/Flowmasters) |
![]() Drives: 2010 Camaro SS/RS 6M Join Date: Feb 2018
If you get the PAC kit make sure to no matter what plug it into the non amped side for the plug. The pac kit isnt quite oem fit but it looks great I just installed it 4 days ago
"A free people ought not only to be armed, but disciplined…” – George Washington
![]() Drives: 2011 Camaro SS Join Date: Nov 2017
I chose the PAC because it has the closest to stock look, using the stock HVAC knobs. Frankly it just looks better than the other two. After reading up, it also seemed a lot of people were having problems with the others.
My Little Mid-Life Crisis Cure!
First - 1997 Camaro 3800 Y87, M5, Green - Gone | Second - 1997 LT1 Z28, M6, Silver - Sold | Third - 1999 LS1 Z28, M6, Pewter, Almost Stock! - Sold Current - 2011 Camaro SS, M6, black, 1LE suspension parts - Current |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS Black & Silver Join Date: Aug 2010
I went with the PAC audio unit too. So far it’s working very well.
STAINLESS WORKS HEADERS-TUNED BY JANNETTY RACING-C.A.I. INTAKE-TAYLOR 409 WIRES-SOLO AXLE BACK EXHAUST-ELITE CATCH CAN |
![]() Drives: [COTW 8/3/15] 2010 Camaro SS L99 Join Date: Mar 2015
A Little bit of power. ALL WORK DONE BY ME!
Just added 2021 ZL1 1LE to the Stable! https://www.camaro5.com/forums/showthread.php?t=418273 ![]() |
#6 |
![]() ![]() ![]() ![]() Drives: 2011 Camaro 2SS/RS Join Date: Oct 2013
I went with the new Scosche 2.0 dash kit. I wanted the different look other than stock that it gave. Plus I've been having HVAC issues since I got the car that I was pretty sure were caused by the controls. Didn't want to have to swap anything over when it came to the PAC kit. Plus I'm not a fan of of the big expanse of plastic that surrounds the radio face on the PAC. I think they could of done a better job sculpting and adding dimension to that area.
#7 |
What Kenwood unit is that????
#8 | |
#9 |
It works very well. I wonder if the video you saw was mine? When I first got the kit, there was a small piece of plastic flashing left from the injection moulding process that interfered with the touch screen. A quick light sanding solved the issue.
#10 |
#11 |
Which video is yours???? I'd like to see it.
#12 |
I took the video down once my isuue was resolved. What was happening was when I'd touch one of the screens, I'd get no response, a delayed response or a response for another area of one of the screens. Once I removed the touch screens from the face place and tested again, everything worked as it should. Found two small raised portions of plastic on the backside of the faceplate that I easily sand off. No issues sense.
But the kit did resolve other intermittent issues my HVAC system has had since the day I bought the car. My fan would never turn off, even with the knob in the off position. My fan speed would fluctuate wildly. The blend doors would open/close with the ignition off. And no matter what temperature it was set at, when I'd restart the car, it would be a full heat. Regardless of knob position. Since installing the Scosche kit, all those issues have gone away. I was pretty sure that all I needed was a replacement face plate for the OE radio, but the dealer wouldn't do it. They said they updated the software once then couldn't recreate the issue the next two times. My certified used car warrenty ran out before they could figure it out.
#13 |
![]() Drives: 2010 VR 2SS/RS M6 Camaro Join Date: Feb 2010
My vote is for the Scosche 2.0 kit. Everything works well, love all the touch screens, and it looks the best imo.
#14 |
![]() Drives: 2012 2LT RS Join Date: Apr 2018
posting to follow and to ask: do you lose the chimes when you install an after market HU? I am in the same boat (2012 no mylink, boston acoustics & backup cam + sensors)
