clutch sticking to floor
anyone have or heard of this problem? 1lt/rs/6m when car is off clutch is fine when car is running clutch feels sticky and sometimes will stick to floor very scary when out driving. thinking maybe needs bled or fluid added going to dealer on monday to see. just trying to get info see if anyone else had same problem. thx
![]() Drives: 2010 VR SS Join Date: Sep 2009
I have the same car and so far have not experienced that. I barely have just over a thousand miles. How many does yours have?
about 1250
![]() Drives: Camaro 2LT RS Join Date: Jul 2009
Sounds like the clutch slave cylinder. There was another post about this somewhere else and the person ended up with a damaged flywheel as well.
Drives: 02 Silverado, 09 Vue, 10 1SS Join Date: Aug 2008
Location: Tired of apologizing when we should be kickin' butt!
Sounds like you've been spending too much time at the adult drive-in.
#6 |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
#7 |
so i did some more digging found other people having similar issues with clucth and they took out the clucth spring that is under the dash on the clutch pedal so i did it and wow it worked no more sticking everything seems to be fine. thx for yhe help guys
| Clutch fluid contamination problems on Vette fixed for Camaro??? | LDGn63 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 11 | 05-28-2012 10:17 PM |
| Oil Change Ramp | mjlash22 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 17 | 01-21-2010 11:40 PM |
| Clutch sticking again | KATHY63 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 13 | 09-21-2009 08:50 PM |
| Vengeance Racing Introduces RPS Organic Street Twin Clutch for 2010 Camaro!!! | Ron@Vengeance | V8 Bolt-Ons & Tunes | 2 | 08-05-2009 02:03 PM |
| Burned my clutch a bit with Launch Control.... Caution you guys... | Embalmer | 5th Gen Camaro SS LS LT General Discussions | 49 | 04-23-2009 09:49 PM |
