Old 11-21-2009, 08:18 PM   #1
mtm864
Drives: 2010 2SS/RS
Muffler delete +Warranty=??
just wondering before my car is here will it void the warranty if i installed a muffler delete kit from SLP? i really don't want to mess up the warranty because this is my first new car and i don't want to screw things up. Thanks for the help!!
mtm864 is offline   Reply With Quote
Old 11-21-2009, 08:27 PM   #2
Johnny1
Drives: Would only drive GM
I'm sure someone will chime in. But to the best of my knowledge from doing this on new vehicles in the past it will only void your exhaust warrenty from the cat converter back. If you have any other mechanical issues they have to prove that what you changed caused the other problem. Same with cold air intakes etc. Some will try to tell you that putting a cold air intake on will void your engine warrenty. But not true. Example if you put one on and some how mess your maf up in the process and try to get a new one under warrenty they will deny it because you had to change the maf out to the new intake. So you should be just fine. And as far as I know they can't void any cat converter problems either because what you will be doing is after the cat.
Johnny1 is offline   Reply With Quote
Old 11-21-2009, 08:34 PM   #3
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
If all you're doing is a muffler delete then don't worry. It'll only effect your exhaust warranty.
However, depending on your state laws, you may have a bigger issue then your warranty as it's illegal in most states to do a muffler delete.
Old 12-05-2009, 12:22 PM   #4
paigeodad
paigeodad's Avatar
Drives: 2010 ss/rs black/slvr 6 spd
from what I understand, even with a muffler delete the resonaters are considered a type of "muffler" which even in those states should keep it legal. The decible noise should still be in the legal range.
paigeodad is offline   Reply With Quote
Old 12-05-2009, 03:19 PM   #5
defragme
Drives: 2SS/RS LS3
If you have ever seen the picture on this forum of where someone cut open a stock muffler, then you will see that the stock exhaust is straight through flow. So by doing a muffler delete you aren't even changing anything as far as backpressure for GM to claim you are causing a problem with the engine.
So I agree with everyone else that a muffler delete shouldn't cause any warrany problems. I'm thinking of doing this myself. Best deal I have seen on the SLP kit is from lmperformance.com
defragme is offline   Reply With Quote
Old 12-05-2009, 03:23 PM   #6
defragme
Drives: 2SS/RS LS3
Oh, and magnaflow also has a muffler delete kit that I have been looking at. It is like $100 more though, but it has HUGE tips. Looks pretty nice but not really worth that much more money. If you can find a good sale or coupon at autoanything.com though, you can get it for maybe only $10 more.
Old 12-05-2009, 04:33 PM   #7
cuda_z28
cuda_z28's Avatar
Drives: 1994 Quasar Z28, 2010 SIM 2SS, 6M
Ebay has the Magnaflow 16582 axleback brand new for $410.00 free shipping . I got mine there. I really like the 5" tips.
cuda_z28 is offline   Reply With Quote
Old 12-05-2009, 07:27 PM   #8
formaxboxers
formaxboxers's Avatar
Drives: Red Jewel Tintcoat 2SS/RS
Check out solo in the vendor section, they are awesome and have 4.5" tips
2010 Red Jewel Tintcoat 2SS/RS, Black Rally Stripes, Black Interior, M6, Sunroof, 20" Polished Wheels, Solo Mach-X Cat Back Exhaust, Blacked Out Bowties
Got screwed by original dealer in Eufuala, Oklahoma on November 3, 2009.
Found new one at Paddock Chevrolet and drove 2400 miles roundtrip to pick her up in Buffalo, New York on Nov. 5, 2009.
formaxboxers is offline   Reply With Quote
Muffler Delete or Aftermarket? JohnForeman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 11-01-2009 11:46 AM
6LE Muffler Delete Kits WITH Double Wall Tips!!! 6LITEREATER V8 Bolt-Ons & Tunes 1 10-30-2009 11:31 PM
DIY at home Muffler Delete for $20 CDBiker220 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 10-12-2009 06:32 PM
Considering a Muffler Delete, Straight Pipes or NOS in Ontario? Matster Canada 18 08-29-2009 03:41 PM
Muffler Delete with Dyno clips and pictures KK2010SS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 07-26-2009 02:09 PM
