Old 11-29-2009, 02:49 PM   #1
HaZe_X
HaZe_X's Avatar
Drives: Trailblazer SS & Camaro SS
BCM wiring
So I got to thinking, I saw a couple of DIY's about killing the DRL's, and having fogs come on at night, and all these guides are not using the BCM wiring.
Now I know on my Trailblazer SS we can splice 2-3 wires, and add a relay to the BCM to kill the DRL's, or kill the auto lights, or even have High+lows on at the same time.
Wouldn't it be a simpler solution for the camaro to do this all in the BCM wiring rather then go to the headlights? Im sure all those functions are controlled by the BCM, and I have the wiring diagram for my 07 TBSS, cant be to far off from the new camaros.
If anyone has a the BCM wiring diagram, post it up..
HaZe_X is offline   Reply With Quote
Old 11-30-2009, 09:10 AM   #2
HeavyD
HeavyD's Avatar
Drives: 1SSRS RY L99
I wouldn't mind some more wire diagrams too.
HeavyD is offline   Reply With Quote
Old 11-30-2009, 11:32 AM   #3
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
http://www.camaro5.com/forums/showthread.php?t=24704
http://www.camaro5.com/forums/showthread.php?t=33592
Old 12-01-2009, 11:44 AM   #4
HeavyD
HeavyD's Avatar
I'd like to see ignition feed circuits and BC inputs and outputs.
Old 11-03-2012, 06:57 PM   #5
ABB
Transforming BumbleBee
ABB's Avatar
Drives: Bumble-Bee Camaro 2012
Below are some, hope it helps
ABB is offline   Reply With Quote
Old 09-26-2019, 12:28 PM   #6
Slip n Slide MN
Slip n Slide MN's Avatar
Drives: 2011 Camaro 2SS - RED
I understand this is a very old thread, but I have a question and hopefully someone can give an answer... I have replaced my Halo lights with red LED rings 'demon eyes'. I love them and have used them for years. But recently I have needed to disconnect them because the police do not like red lights on the front of a civilian car.
I have found the +12 wire for each LED ring at the BCM right above the gas pedal.
My Question is, can I bridge these into one SPST switch to manually interrupt them? Or should I get a DPST switch to keep the two channels separate?
The two wires do not have continuity when switched on. But I don't know if it would hurt the BCM to bridge the two +12 wires.
Thank you for any help/advice/thoughts on this... :-)
Slip n Slide MN is offline   Reply With Quote
Wiring in a KB Boost a pump R8cerX Forced Induction - V8 59 11-25-2019 05:34 PM
Garmin nuvi > mounting & wiring for the Camaro 67 GTO Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 25 11-05-2011 01:52 PM
Halos/HID on 2 LT wiring ? lostinvt Camaro DIY & HOW-TO instructions & discussions 2 12-29-2009 09:54 AM
Anyone have picts/info on the factory infotainment system wiring harness & plugs? Matt'sSS Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 3 10-01-2009 01:48 AM
