Old 12-02-2009, 06:03 AM   #1
Exotic Performance Plus
Exotic Performance Plus's Avatar
Drives: 1999 Camaro Z28
671 rwhp from LS3 with 8.4 psi of boost and EPP Blower Cam
LS3 with long tube headers and exhaust, our EPP blower cam, and 8.4 psi of boost from an ATI ProCharger D-1SC. Keep in mind this is rear wheel horsepower, and is from our conservative Mustang Chassis Dyno. This was with a lot of timing being pulled out of it, as it is a stock bottom end. Bob
Exotic Performance Plus is offline   Reply With Quote
Old 12-02-2009, 11:36 AM   #2
Dans ls1
Drives: 1998 TA
Good work guys..can I see a dyno graph?
Dans ls1 is offline   Reply With Quote
Old 12-02-2009, 11:44 AM   #3
the rich dude
Drives: Getting 2010 Camaro
Nice job! What octane fuel were you running?
the rich dude is offline   Reply With Quote
Old 12-02-2009, 11:45 AM   #4
Andro
NOICE!!! ™
Andro's Avatar
Drives: Force Fed 427
Nice
Old 12-02-2009, 12:05 PM   #5
Mike TexaSS
Drives: 454 LS7 Camaro SS
Nice. Fuel system upgrades?
Mike TexaSS is offline   Reply With Quote
Old 12-02-2009, 01:58 PM   #6
JANNETTYRACING
JANNETTYRACING's Avatar
How come the Dyno Sheet Says Engine HP not RWHP.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 12-02-2009, 02:53 PM   #7
navyblueSS
Drives: 2002 Camaro SS
Nice work!! Stout numbers!
2015 1LE - CAI intake, TSP longtubes,
NPP, Futral Motorsports tuned, BMR 1"lowering springs, BMR trailing arms
navyblueSS is offline   Reply With Quote
Old 12-02-2009, 04:14 PM   #8
Z_Rocks
Z_Rocks's Avatar
Drives: everyone crazy...
Good point Ted. Do you suspect the software has already added the 15% loss?
Z_Rocks is offline   Reply With Quote
Old 12-02-2009, 05:50 PM   #9
Codefive
Codefive's Avatar
Drives: 1000HP 2010 SSRS
Sorry ... I gotta call on that one.
I can believe flywheel HP but not RWHP.
If that were accurate, than that car should run 10.20s @ 130 MPH at 4000lbs
Bring back a time slip.
There's just too many of these out there making similar numbers and yours is 15-20% higher than everyone elses???
That must be one "magic" camshaft.
Codefive is offline   Reply With Quote
Old 12-02-2009, 05:51 PM   #10
awesome Camaro
Old 12-02-2009, 06:04 PM   #11
old motorhead
Drives: Maggie blown LS3 vette
If you let the engine breathe, you can make big power on less boost. Boost is a measure of restriction....not a measure of power. These numbers are very believable. I make similar power on 8.5psi of boost in my TVS blown vette.
old motorhead is offline   Reply With Quote
Old 12-03-2009, 03:30 AM   #12
DallasPerformance
Drives: 911
Sounds inline to me. Was this a C6 or a Camaro Bob?
DallasPerformance is offline   Reply With Quote
Old 12-03-2009, 06:32 AM   #13
The dyno graph is shown above.
Thanks, 93 octane.
Originally Posted by Andro View Post
Nice
Thanks.
Thanks! We used a Kenne Bell Boost A Pump.
The above dyno graph shows the same thing. It is indeed rear wheel horsepower. The dyno graph above is from a Cadillac CTS-V that has also been on another chassis dyno. It gave similar results on the other dyno and to date is the highest recorded horsepower they have had on thier dyno. Here is a link to this CTS-V. http://www.exoticperformanceplus.com...Car.php?car=29 We started with a new LS2 block on the above CTS-V, added a 4.00" stroker crankshaft, the same EPP camshaft, off the shelf AFR 225 heads, and a FAST 92 intake manifold. We used a ProCharger F-1A.
Thanks, I appreciate it.
Nope, this is rwhp.
The LS3 heads flow 330 cfm right out of the box, with boost and a good camshaft the power output is always much higher than what we use to see with the LS2 engines.
awesome Camaro
Thanks, but this is a Corvette. Same basic type of drivetrain losses as it also has an IRS rear.
I agree, and I know you've been around these engines long enough to know what can be had out of them. Thanks.
Thanks, I know you've made a lot of power with these engines too. This is from an 2008 LS3 Corvette, so the drivetrain losses should be about the same as in the new Camaro. Here is a link to this Corvette. http://www.exoticperformanceplus.com...Car.php?car=59 Bob
Old 12-03-2009, 08:54 AM   #14
JANNETTYRACING
Nice Job, When will we See a 130 MPH Pass down the 1/4?
