Old 03-06-2019, 05:41 AM   #1
GatorGreg
GatorGreg's Avatar
Drives: '14 Blue Ray ("Suite Madame Blue")
2014 RS headlight issue
Hey all, last night I noticed my left headlight was turning off by itself about 20-30 seconds after turning it on. The halo part continues to stay lit. Is it a burned out HID bulb or something else might be wrong? Seems weird that it goes on but doesn't stay lit. I'm gonna take it to the dealer this weekend to have it checked out.
GatorGreg is offline   Reply With Quote
Old 03-06-2019, 08:23 AM   #2
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
possibly a ballast issue?
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 03-06-2019, 08:43 AM   #3
Junior
Junior's Avatar
Drives: 2014 2SS/RS A6 AGM
Send a message via Skype™ to Junior
Take the bulb out and put it in the other housing to test functionality. Take care not to touch the bulb itself. This should indicate a bulb or a ballast issue. I had the same exact symptoms happen to my '14 a while ago and it wound up being the bulb. Plenty of replacements out there cheaper than OEM.
Junior is offline   Reply With Quote
Old 03-06-2019, 09:26 AM   #4
J Rod
J Rod's Avatar
Drives: '14 BRM 1LE 2SS/RS
This!
I had the same thing happen on my old 300C a couple months after I bought it. I took it back to the dealer I bought it from and they told me the headlight was bad and I needed to purchase another one for $1100. I took it back home, swapped the bulbs, and the problem moved to the other light. So I bought a $40 replacement bulb online and never had another issue with it. Needless to say, I'll never buy another car from that dealer.
592 HP/590 TQ
LSA Blower w/ 2.45 Griptec, Reinforced Brick, FIC 1000 injectors, JRE FPCM, LFP Dual Pass HX, ZL1 IC pump, RotoFab CAI, Bo White TB, Coated Stainless Power 1-7/8" LTs, NPP, NGK TR7IX, Mighty Mouse Wild CC, AEM X-Series WB, Aeroforce Interceptor, MGW Shifter, Z28 Grill, Gary's Custom ZL1 Rockers, Hero Tails, Tuned by IMC
J Rod is offline   Reply With Quote
Old 03-12-2019, 07:33 AM   #5
Black Phoenix
Alamo City Camaros
Black Phoenix's Avatar
Drives: 2014 2LT/RS 2014 2SS/RS/1LE
Cool
Had the same exact problem with our 2014 2SS/RS 1LE. It would turn on for about 30 seconds like you mentioned and then turn off. It was the ballast. Bought the parts online, much cheaper, removed the front fascia and replaced both of them. Might as well replace both, the other is probably not to far behind and you don’t want to have to do the same job twice.
CAI Intake, Borla Touring Axle Back, FOOSE Legend Wheels, Vertical Doors by River City Creations, Expel sidemarker Blackouts, GTS Headlight & Tail light Blackouts, Oracle Headlight Colorshift & Fog light Halo's, Engine Bay, Grill, Wheel ring & underglow lighting by RiverCity Creations, Hood & Deck lid murals by SC Airbrush & Designs
Black Phoenix is offline   Reply With Quote
Old 01-09-2021, 05:47 PM   #6
bdm14107
Drives: Chevy Camaro 2014
Greg. Replying to your post about the 2014 ballast. I tested and proved I have a bad ballast. i can't find a replacement. The OEM has ridge on the bottom, then the O ring, then nothing. The replacements all have two ridges with the O ring in between. Needless to say, it doesnt fit and the bolt holes don't line up. I've checked rock auto, online headlight companies, local auto parts etc. Any thoughts? Did you run into the same issue? Any ideas?
bdm14107 is offline   Reply With Quote
