Old 03-26-2019, 07:54 AM   #1
Bfh_american
Drives: 2013 Camaro 2SS
Injector and Fuel Pump shopping
Gonna replace both when I SC and Cam my vehicle. Wanted some input on what injectors and pump I should use. I'm 98% going with the Whipple SC, ARH longs, and still debating on which cam. Gonna be my daily, so I don't need track or race power, but I want to do it right and not lose power due to insufficient fuel. I'm looking got optimal power, without crossing into the heavy drag/race scene. Sorry for all the posts, just trying to absorb as much as I can on this topic before I drop $15k+-.
Bfh_american is offline   Reply With Quote
Old 03-26-2019, 08:16 AM   #2
Bfh_american
The Whipple SC comes with this.
(2010-2012) MSD ™ Fuel pump booster with pre-defined voltage curve for less pump duty cycle then other pump boosters, only supplies increased voltage when needed, others are on/off
(2010-2012) MSD ™ Fuel pump booster voltage curve can be adjusted by user, no need to purchase "competition" version, already included
(2013-2015) GM High Performance high flow fuel pump from factory supercharged ZL1 and CTS-V
I'm not sure how I feel about that? Thoughts
Old 03-26-2019, 10:44 AM   #3
mrimpala02
Drives: Black 2SS RS w/White Stripes
What is your ultimate final HP goal? What fuel you going to run?
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods |
Installed by Me & Tuned by Pat G
mrimpala02 is offline   Reply With Quote
Old 03-26-2019, 10:55 AM   #4
JANNETTYRACING
JANNETTYRACING's Avatar
I would be glad to help you out, I can provide you with the Whipple supercharger tuner kit and fill in the blanks with supporting headers, plugs wires sensors, air intake injectors fuel pump cam and custom tuning 1 stop shopping.
Feel free to call me directly for a consultation to put a package together that meets both your budget and goals.
Ted. 203-753-7223
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 03-26-2019, 11:20 AM   #5
Juiced1
Drives: 2012 2SS CAMARO 45th
OP we have a ton of options for fuel delivery and some great deals to. We are a Whipple authorized dealer and can also set you up with a killer package.
Juiced1 is offline   Reply With Quote
Old 03-26-2019, 06:05 PM   #6
Punisher_ATX
Drives: 2010 SS
I have the Vaporwox returnless dual 450 system. Probably the best bang for buck for over 700hp fuel system.
Punisher_ATX is offline   Reply With Quote
Old 03-27-2019, 02:33 AM   #7
Bfh_american
93, Super/premium
HP over 600+. SC+CAM+HEADERS+TUNE+EXHAUST and i'll easily get that. Just don't want to have lacking Injectors. Was reading that stocks are no Bueno.
Old 03-27-2019, 08:10 AM   #8
JANNETTYRACING
93, Super/premium
Our JRE Super Street Brawler package has everything you need to easily make 675+ RWHP on 93 octane.
Old thread but right up your alley.
https://www.camaro5.com/forums/showt...STREET+BRAWLER
Old 03-27-2019, 10:18 AM   #9
mrimpala02
93, Super/premium
You are correct the stock injectors will not cut it! I would look for at least ID850 or equivalent.
As Ted mentioned he offers a great package.
Old 03-27-2019, 12:02 PM   #10
sscamaro
Drives: 2010 2SS, 2017 Silverado LTZ
93, Super/premium
Are you talking 600+ rwhp or crank hp?
sscamaro is offline   Reply With Quote
Old 03-27-2019, 12:53 PM   #11
JANNETTYRACING
RWHP with the parts combination requested.
Old 03-29-2019, 03:54 AM   #12
Bfh_american
Looking at Injector Dynamics 1050x and DW400 Fuel Pump kit. Thoughts?
Old 03-29-2019, 04:58 AM   #13
John_C
LSx FTW!!!
Drives: 2010 Camaro 2SS RS
My advice, go as big as you need and then some.
I've gone from ID850's to ID1300x's
Then, the ZL1 pump is now maxed out.
Did DSX Aux pump, but still need more in-tank pump to supply fuel before the DSX Aux kicks on.
Wish I had known about the DW400 when I bought the ZL1 pump....
It's expensive buying a fuel system twice!
John_C is offline   Reply With Quote
Old 03-29-2019, 05:06 AM   #14
Slickcas
Drives: 12' 2SS/RS LS3 IBM
I am running ID 1050x with the DSX auxiliary pump and DSX Flexfuel Kit. Also have the ZL1 pump NO BAP. I have the fule pressure set to 65. The DSX kicks on at 4psi boost not the standard 10 pounds of boost . The FPCM just slows down the pump in the tank and maintains 65psi. Pushing 700rwhp on true E85 with the TH400. Injector duty cycle was like 65%. Much lower when there is 93 in the tank or a mix.
Slickcas is offline   Reply With Quote
advice, fuel injectors, fuel pump, injectors, pump
