Old 03-30-2019, 04:40 PM   #1
Jimmy Hot-Wheels
Jimmy Hot-Wheels's Avatar
Drives: 2013 Hot Wheels Edition 2SS/RS
Will OEM GM ZL1 Splash Guards fit my 2013 SS?... YES
After searching MANY threads here on Camaro5 and reading about splash guards / splash shields / rock guards, I came to the conclusion that a definitive answer didn't exist to this question:
Will OEM GM ZL1 Splash Shields fit my 2013 2SS without ANY modification to my car or the parts?
The short answer is YES. I used part numbers 22895337 and 22895336.
I know there are other brands and styles; each with their pros and cons. I used to have ZL1-addons rock guards on my 2014 1SS, but that rear diffuser is way different. This time I really wanted something that looked stock, and didn't look like a truck mud flap or just a flat piece of cut/shaped plastic.
In reading other's posts, some said the holes on the OEM GM parts didn't line up with their 2013 or they had to drill, modify, etc. NOPE NOPE NOPE.
Did I remove the tires? NO (it would have been easier though)
Do I have the ZL1 rear diffuser? NO
Just remove the three T20 Torx fasteners. A socket that fits the Torx bit wrapped in a rubber band can help here. Pull back the wheel well liner to reveal the factory holes. Clean the area; there is some tape (unneeded in my opinion) on the guards to stick it onto the car body.
I prepped the guard by "plugging" the empty/unused hole at the bottom that would connect to the ZL1 diffuser; it does look better without an open hole visible.
I also prepped the guards with 2 body fasteners in the lower holes. I used a plastic molding removal tool to help push the fasteners into the holes since it's tight and my thumb alone couldn't do it. The top hole on the guard will line up with the factory fasteners.
From under the rear of the car, line up the guard with the factory holes and press the fastener into place with the plastic tool, then push in the fastener pin with the tool.
Align the wheel well liner and re-install the 3 torx fasteners. Pull the adhesive tape, press, and you're done!
I took my time and enjoyed some garage time, but it only took me about an hour.
Jimmy Hot-Wheels is offline   Reply With Quote
Old 03-30-2019, 06:02 PM   #2
Sinister10
Sinister10's Avatar
Drives: 2010 Camaro SS
nice!, im gonna have to look into these as well
2010 2SS/RS 6M, MGW flatstick, CAI cold air intake, SLP loudmouth 2 axleback, TSP 1 7/8 headers w/ hfc, pfadt 1" springs, SRP pedals, emblempros "6.2L" emblems on hood, ZL1 grill, M/T SC-5 wheels, nitto motivo 275f 315r. ZL1 addons wickerbill, smoked lenses, resonator delete x pipe, diode dynamics DRLs 1LE suede steering wheel, mighty mouse CC. SCTX4 and Dyno Steve tune.
Sinister10 is offline   Reply With Quote
Old 03-30-2019, 06:37 PM   #3
Railguy2
Railguy2's Avatar
Drives: 2010 Camaro 2SS
sweet just ordered a set on fleabay ,, thanks great post
Railguy2 is offline   Reply With Quote
Old 03-30-2019, 06:39 PM   #4
Yellow Bullet
Yellow Bullet's Avatar
Drives: 2017 Chevy Sonic RS 1.4T
Nice! I also prefer the stock look and have installed mine as well.
2015 Camaro RS/SS SIM LS3- Sold
2017 Sonic Mosaic Black RS 1.4T
Yellow Bullet is offline   Reply With Quote
Old 03-30-2019, 07:36 PM   #5
qcman
qcman's Avatar
Drives: 2013 Camaro 2SS RDP Tuned L99
Very nice OP. Can you take them off and then put them back on while making a video tutorial LOL? J/K of course. Any links to the parts? I see ZL-1 rear pairs on Ebay but don't see the front ones for some reason. I'm thinking of doing this after seeing yours.
qcman is offline   Reply With Quote
Old 03-31-2019, 07:00 AM   #6
Jimmy Hot-Wheels
Correct me if I'm wrong, but I believe the only front splash guards on the 2013 ZL1 were in FRONT of the wheels. This is why there's always so much discussion on what 'set' to buy when there really isn't an OEM set of 4 rear positioned splash guards.
Also, just to clarify, NO fasteners or mounting hardware come with the GM rear set. The parts diagram looks like they might use rivets, but the fasteners I pictured above worked great and securely hold them.
Old 03-31-2019, 08:39 AM   #7
lt1power
Drives: 2011 2SS RS
Where did you get the fasteners?
lt1power is offline   Reply With Quote
Old 03-31-2019, 08:57 AM   #8
qcman
qcman's Avatar
Oh thanks I didn't realize until I looked again at the pics that this is only for the rears. I think the mention of 2 different part numbers confused me a bit. But I like them and may do the same thing. Can you post a pic of how the whole car looks with just mud flaps on the rear by chance? I'm just curious if it still looks balanced with only the rears on it. I imagine it does as they are a stealthier look than many I've seen.
Old 03-31-2019, 09:20 AM   #9
myold88
myold88's Avatar
I don't get the advantage &/or reason for these splash guards.
1) They get dirty and must be constantly cleaned.
2) I don't like the look.
3) After 10 years my L&R rear side facias are chip free.
Old 03-31-2019, 09:22 AM   #10
redirish
redirish's Avatar
Drives: 10' IOM 2SS/RS/M6
Would these for on a 2010 SS? Same body
redirish is offline   Reply With Quote
Old 03-31-2019, 10:18 AM   #11
Jimmy Hot-Wheels
Really, regarding #3??
My car has only 22,000 miles... but look at all the chips.
Old 03-31-2019, 10:48 AM   #12
Jimmy Hot-Wheels
I bought a kit on eBay or Amazon a while back for a different project. The ones I pictured seemed to fit and hold the best.
Something like this:
https://www.amazon.com/Retainer-Fast...97137823&psc=1
Old 03-31-2019, 12:57 PM   #13
TooCool5
TooCool5's Avatar
Put stainless on front, don't like the look on the rears.
Old 03-31-2019, 02:54 PM   #14
Jimmy Hot-Wheels
I really don’t know. Is it the “same body”? Did Chevy engineer the holes/tabs for the splash guards on the 2010 a couple years before the first 2012 ZL1? Remove the wheel well liner screws and look??
guard, rock, shield, splash
