Old 12-05-2009, 11:19 PM   #1
jhutch
Drives: 2010 2SS ABM -Sold
HELP amp install no sound
I have everything hooked up, thought I spliced into the correct wires but I guess I didn't. I have power to the amp, just no sound....
What is the EXACT colored wires I must splice into?????????
My amp has the low level inputs on it also I have a 2SS if that helps
ps. bought a scosche converter thinking that would help....it didnt
Looks like the wires I spliced into are as follows, blue, drk/blue, blue white, light blue... is this correct?
2016 Hyper Blue 2SS M6 White Interior Mag Ride NPP GFX
jhutch is offline   Reply With Quote
Old 12-05-2009, 11:38 PM   #2
CASTIG 2010SS
Drives: 2010 CGM Camaro SS\RS
check your amp settings, make sure they are turned up. Most new amps have them turned all the way down.
2SS CGM, IO Interior
BAD 2SS
West Chester, PA
CASTIG 2010SS is offline   Reply With Quote
Old 12-06-2009, 12:23 PM   #3
deljaso
deljaso's Avatar
Drives: 2010 1LT/RS
I spliced into the plug mentioned here:
http://www.camaro5.com/forums/showthread.php?t=33592
I used the one labeled Audio Amplifier X3, white for remote turn on, then tan/dk blue for right side signal and brown/brown-white for left side signal.
I didn't use any kind of adapter, just cut off one side of my RCA's, then stripped the cut end and spliced into the wires.
If looks like you used Audio Amplifier X2, which has the outputs from the amp.
I'm seeing the following wires needing to be tapped:
lightblue-black (right rear -)
lightblue (right rear +)
darkblue-white (left rear -)
darkblue (left rear +)
Do you have the factory amp in your system? Or are you actually tapping into the wires behind the radio. If it's behind the radio, let us know and we'll look for the right wires. Above is for the upgraded BA system, which has the amp in the trunk.
deljaso is offline   Reply With Quote
Old 12-06-2009, 02:29 PM   #4
jhutch
yes I have the BA system, tapping into the trunk, so I must use Audio Amplifier X3?
Old 12-12-2009, 12:13 AM   #5
jhutch
bump!
Amp install - how to (w/pics) ASTEDA Camaro DIY & HOW-TO instructions & discussions 31 10-16-2019 12:14 AM
Amp install- how to (w/pics) ASTEDA Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 63 02-27-2017 02:27 PM
V6 Corsa Exhaust Pics, Video and Sound bond2 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 176 10-08-2015 06:45 AM
STEP BY STEP VIDEO INSTALL OF MGW SHORT THROW SHIFTER>> MGW Camaro DIY & HOW-TO instructions & discussions 39 12-02-2011 11:25 AM
ZZ Motorsports - Audio Install ZZcamaro Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 3 07-21-2009 06:06 PM
