Love's to Detail
Drives: 2010 SS,97silverado/08crewcab Join Date: Oct 2008
Long tubes w/high flow cats,no tune...running lean?
I've decided to go with Lt's with race cats and a 3" exaust.
My question is..will I run to lean with out the tune? Is running to lean a bad thing? I dont wont to void my warranty with a tune just yet so that's why I'm concerned with this..Maybe some of you guys thats done the above can help out?.....Thanks Daniel |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
I may not know but i think that the moderator on this forum by the name of TAG UR IT has Lt's with race cats and a 3" exhaust and is not going to do a tune till his warranty is up and i will do the same till i get 30,000 mi on my car, And if i am right his car was made by Tom Henry Racing, This is his Member Car Journals http://www.camaro5.com/forums/showthread.php?t=24085
#3 | |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
Just waiting for Corsa axel back to fit ARH's |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
The problem is every car is different. You should have your car hooked up to a wide band to check its A/F. That's really the only way to know how your car is really running. One car can have a perfect A/F, while the next car with the same mods might not be.
#5 | |
In The Circle
#6 |
I agree on the A/F but there is more to that all the V8 stock cars run rich at WOT so to add LTs will only get them closer to the right A/F of 12.4-12.7 at WOT.
#7 |
But throw on a CAI and you could be running lean. Most cars with just headers seem to be just fine (a/f wise).
#8 |
Remembering those in Blue
Drives: 2010 Camaro 2SS Blk w/IOM Int Join Date: Sep 2009
I would be carefull- run it lean and run it hard, will cause it to ping and could very likely cause pre ignition, pre ignition in the Harley world will literally blow the top of a piston off. I'm sure similiar symptoms would happen in the automotive world.
Warranty would not be an issue since you could actually cause more harm due to it being to lean. My thoughts, Mike
#9 | |
My Camaro was experiencing, as described by my tuner, "some knock up top" before it was tuned for my CAI, Longtubes, high flow cats, and catback. |
#10 |
I will let you know soon or i think Tag will let us know this week hopefully on monday as he is going to VARAME and doing some dyno pulls with the A/R to be posted on the forum.
#11 | |
Love's to Detail
the same mod's and no tune also. |
#12 |
Love's to Detail
#13 | |
Love's to Detail
What would be my options? Besides a tune? |
#14 | |
A/F too high = lean - not enough fuel A/F too low - rich - too much fuel |
| Official 1/4 Mile (V8) 2010+ Camaro Fast List | Merc | Dragstrip and Launch Techniques Discussion | 3656 | 11-01-2025 01:41 PM |
| Texas Speed Long Tubes & Rumbler 5 Cat-Back Dyno Results! | Trevor @ Texas Speed | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 48 | 12-08-2018 02:37 AM |
| Great Read and Info on Oil Weight | Banshee | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 1 | 11-23-2009 09:03 PM |
| LS3 goes 11`s Bonestock! | GMRULZ | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 28 | 12-08-2008 09:10 PM |
