Old 05-08-2019, 07:45 PM   #1
turbofreek
Drives: triple black 2ss
My searching sucks...so what is this vac gate in my mufflers?
I have a 2014 i picked up on 420.lol. 6spd 2ss and has dual outlet mufflers. Mufflers have vaccum activated cutoffs on the actual mufflers.
Is this some factory stuff or wth is it? Mufflers dont have a name to them either.
turbofreek is offline   Reply With Quote
Old 05-08-2019, 07:52 PM   #2
SynergyGreenSS
SynergyGreenSS's Avatar
Drives: 2011 2SS
Those are OEM NPP dual mode mufflers. They’re vacuum actuated like you said. If you want them to be loud all the time and never close you can pull fuse f8 in the trunk fuse box. DIY on that is here
https://www.camaro5.com/forums/showthread.php?t=268970
If you want to be able to manually control them, you have a few options. There is the mild to wild which allows them to be either open or factory operation, or you can get the forza three way exhaust controller which allows them to be open, closed, or operate normally.
Mild to wild: https://www.phastekperformance.com/2...er-mtw-zl1.htm
Forza controller: http://forzacomponenti.com/controller_e2.html
Hope this helps
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears
SynergyGreenSS is offline   Reply With Quote
Old 05-08-2019, 08:20 PM   #3
turbofreek
Thanks man. I figured it was some stock bs. As nobody would want to add that goofy vac stuff along the car. That is crazy.
I just wanna pull the mufflers and put some magnaflo or dynomax in their place and keep the similar twin tip look to it. This is just a cruiser toy anyways. But its still needing to sound amazing for sure.
Old 05-08-2019, 08:40 PM   #4
SynergyGreenSS
Drives: 2011 2SS
Throw some long tubes on there, that’ll change your mind about swapping mufflers. The npp’s sound awesome with long tunes. I had flownaster outlaws on and when I did the headers it was too loud so I put the npp mufflers on and it sounds amazing.
2011 SS L99
Old 05-08-2019, 08:42 PM   #5
Vegas Bound
Drives: 2013 Sparkly Red One
I added that goofy vac stuff along my car and programmed the remote control to my Homelink buttons. I can open and close at will.
Vegas Bound is offline   Reply With Quote
Old 05-08-2019, 08:43 PM   #6
SynergyGreenSS
Drives: 2011 2SS
Haha I did something similar. I put a vacuum pump in my trunk so I could open and close the mufflers
2011 SS L99
Old 05-08-2019, 09:00 PM   #7
christianchevell
old school chevy rodder
christianchevell's Avatar
GO ahead turbo pull it and sell it its only a $900 option a moron would hate on since it comes from a corvette..... oh yes and the new model of Camaro has the same function but with electrical controller as like the corvette; its called dual mode performance exhaust if your not built though you most likely don't appreciate what some of us paid good money for as a option. I guarantee you the aftermarket muffler guys wish theirs sounded like mine, and they make excellent decel popping and burble with a built tuned car...…
And many people over time have added and even designed the "goofy vacuum stuff" to work since it does work apparently much better for some of us than you and your opinion, of course some of us did not just buy our car, and some of us may be on not even our first gen 5 SS. And my first a triple black vert l99 sure could have used a better exhaust like the dual mode...… But still would have needed to be built.
Old 05-08-2019, 09:29 PM   #8
turbofreek
I wasnt intent to offend anyone with my "opinion" of the setup. It sounds ok but i actually dont care for the cherry bomb muffler decel sound. I am much more of a turbo whistle kinda sound guy.
I got this camaro to drive when i want to pull gears. It has been fun so far and it has gotten a few compliments on the exhaust note even. Im just not a fan of that burgling but the rest is fine. Maybe ill get used to it. After i dont intend to mod it much. Maybe some better control arms in the back, better shifter and throwout bearing over winter. Kinda wanna do some road course stuff to pass time on an off weekend im not drag racing.
Sure do wanna add a cowl hood to remove that center vent and add white stripes on the hood.
Old 05-08-2019, 10:24 PM   #9
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Trolling much? Cant be serious. Talking about turbo whistle and cherry bomb and talking shit about NPP, which is the pretty much the best.
You have much to learn/read.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 05-09-2019, 12:08 AM   #10
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
NPP flow is better than most if not all replacement mufflers. A lot of Camaro owners that dont have it wish they did. I like being able to shut mine down or open it up with the flip of a switch. Do some more research before you dismiss it as some BS
Sent from my SM-N960U using Tapatalk
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 05-09-2019, 04:05 AM   #11
2010reddevil
Drives: 2010 Camaro 2SS Victory Red 6M
That burble you dislike will be even more prevalent on other mufflers like the ones you listed. The NPP (wish I had it....) is basically the best of both worlds. Loud when wanted, stealthy when not. If you're set against it, then sell the whole system and replace it with a c/b system. Don't be ghetto and just chop it up. There's tons of people who'd buy the system for a very fair price indeed.
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19
Gone on 12/28/19 R I P
2010 2SS 6M Victory Red/Black (old ride)
CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back.
12.6 @ 115 SAR as of 9/19/15
Gone but never forgotten.
2010reddevil is offline   Reply With Quote
Old 05-09-2019, 11:20 AM   #12
turbofreek
Thank you for that reddevil and you other 2 above him. I literally know nothing about these cars. I also dont wanna be ghetto either.lol. good response made me chuckle. Ive been building a 2khp g3 hemi and just never gave a thought to anything else.
I am honestly not trying to troll if it seems that way. I have a different car and brand im wrapping its build up on this month. Ive always had turbo cars with magnaflo mufflers. So that burble wasnt there.
Im glad i dont have to change the exhaust out if they flow that well. Ill just leave it as is. Maybe just work on the suspension for handling and do some road course trips 1ce or twice a year.
Old 05-09-2019, 11:22 AM   #13
608RS
608RS's Avatar
Drives: 2015 2ss
before you decide to sell this exhaust, look up "NPP fuse pull" which will bypass the valves and make your exhaust "loud" all the time. you won't be disappointed.
608RS is offline   Reply With Quote
Old 05-09-2019, 07:47 PM   #14
turbofreek
Thanks man. I dont wanna do that. Im to old for loud at all times. Boy did i really just say that? Lol. Maybe ill do it if i ever put a rowdy cam in or if my boys want it loud all the time. Ill have to ask them. Looks simple enough for sure.
