Old 05-18-2019, 09:16 PM   #1
Cth0225
Drives: 2010 Black SS Full Bolt ons
Cam upgrade feed back.
I have a 2010 SS manual with 60k miles. All the basic bolt ons.. longtube, intake, exhaust and tune. Looking for a camshaft upgrade now. I'm looking for some feedback on which cam brand and stage to get the most hp gains.
Cth0225 is offline   Reply With Quote
Old 05-18-2019, 10:19 PM   #2
Roader
Drives: Camaro
Go with a stage 7 cam by Brenspeed
Roader is offline   Reply With Quote
Old 05-18-2019, 10:22 PM   #3
ZOOK
ZOOK's Avatar
Drives: 2010 2ss 6 speed
cam
I have a 2010 with 80k on it and have the jannetty rough idle cam and blower and love it ,,, give Ted a call
https://jannettyracing.com/
ZOOK is offline   Reply With Quote
Old 05-20-2019, 12:02 AM   #4
weSS1LEy
weSS1LEy
weSS1LEy's Avatar
Drives: 2015 camaro 2ss/rs/1le
Do they work on camaros? I looked at their site, all Ford, few dodge, no chev
Rotofab, arh no cats, atak, elite cc, 94 octane tune, Mobil 1, phastek scoop, custom cam 230/243 .621 .604 114+4, related cam kit stuff. 470/435 rwhp/rwtq
weSS1LEy is offline   Reply With Quote
Old 05-20-2019, 07:01 AM   #5
Roader
Drives: Camaro
No lo
Old 05-20-2019, 09:14 AM   #6
Juiced1
Drives: 2012 2SS CAMARO 45th
We carry and deal with Texas Speed and Brian Tooley cams. If you need help selecting one give us a call and we can go over the options. Being a manual car we can go pretty aggressive while maintaining good street manners.
Juiced1 is offline   Reply With Quote
Old 05-20-2019, 11:36 AM   #7
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
I've been asking about their Stage 9.5 cam for a Camaro
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 05-20-2019, 12:40 PM   #8
PepeLePew
PepeLePew's Avatar
Drives: 2010 2SS Coupe; 2011 2LT Vert
The 9.5 is a great cam. If you go this route, I'd upgrade to the coyote heads and put 4 of them in there. I heard it is a simple swap on the LS3.
OP - If you're serious, take a look at the cam packages offered by the big guys like TSP, BTR, and GPI. Also, understand what your goals are with the car and how you plan to use it. If it is a DD and you're looking for the highest HP only, you may be sacrificing some low end driveability. For most of us, a Stage 1 or 2 cam is plenty as our cars rarely see track time. The difference in HP with the bigger cams usually only becomes apparent when you do the other supporting mods (trunion upgrade, intake manifold, 102mm TB, etc) to allow you to raise the redline to the mid 7k range.
2010 2SS/RS LS3 - K&N, GM Performance Axle Back, Hurst Shifter, TSP 1 7/8ths long tubes no cats, TSP Stage 2 "Bald Eagle" cam, GM 3.91, 466whp/429tq
PepeLePew is offline   Reply With Quote
Old 05-20-2019, 12:51 PM   #9
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
call an experienced custom cam designer like Cam Motion, GPI, BTR, TSP, Tick Performance, and tell them about what you wanna do. if you can have your raceweight on hand, it would be a big plus
A lot of them use cam motion 8620 cores spec'd to their relentless hours of trial and error development and will be able to get you the best package for what YOU want the car to do.
Thats the advice i got many years ago in the gen ii sbc days. Never failed then, doesnt fail now
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 05-20-2019, 12:57 PM   #10
Roader
Drives: Camaro
This is best info you’ll get but I’d argue stage 2 minimum with a manual since you don’t have to worry about converters and all that. If a DD is just go with stg 3 although I did daily my gpi ss4
Old 05-20-2019, 01:11 PM   #11
Benman
Benman's Avatar
Drives: 13 IOM 2ss RS manual
But wouldn't this require upgrading the hydrocolator valve to version 10.2.4?
Rectangular Dollars will beat Cubic Inches
Benman is offline   Reply With Quote
Old 05-20-2019, 04:18 PM   #12
PepeLePew
PepeLePew's Avatar
I agree with Roader... I didnt see you were manual!!! (thanks for pointing that out) No need to go stage 1 unless you were auto staying with stock converter. Stage 2 or 3 are definitely streetable with a solid tune.
Old 05-20-2019, 04:21 PM   #13
PepeLePew
PepeLePew's Avatar
You are correct... definitely need to upgrade the hydrocolator valve. I found a good telescoping basin wrench makes this an easy swap for any shade tree mechanic though.
Old 05-20-2019, 05:48 PM   #14
LsxDoctor
15 Year LS1Tech Member
LsxDoctor's Avatar
Drives: 2010 ss 391ci LS3
Cth0225
This is a very hard question to answer. You need to address your goals driving style, is it going to be a dd, weekend warrior, race car etc etc, future mods...
Your best bet is for YOU to do some research and find what best suits YOU. We all have our favorites and can give you all these cool names but in the end only YOU know what you want/expect.
I have a stage 4 TSP cam. It works great for how I use the car and how I like to drive. Bigger isn't always better. Look at some dyno sheets and study the power under the curve. If you're cruising around town with a big @$$ cam, don't expect to have any power down low.
GJDM
LsxDoctor is offline   Reply With Quote
