Old 07-24-2019, 06:28 PM   #1
DarkMaro1le
DarkMaro1le's Avatar
Drives: Chevy Camaro ss 1le
2015 1LE 6spd 1st and 2nd gear bog in the MM6
Hey all,
I searched for a good while to see if there happened to of been a transmission post. Sorry if i missed it and this has been discussed before.
I noticed in this car 1st and 2nd are not as snappy as other 5spd and 6spd i have driven. But my 3rd gear is like i am running on boost. Just 1st-2nd feel like torque management is on hard core.
So my question, Is this normal for these setups because its mainly for tracking autocross and road courses?
I will be building it more for doing road courses no straight line racing. But i had to do a couple pulls against the Gf's 2015 gt and was a little concerned with the lack in the first gears.
DarkMaro1le is offline   Reply With Quote
Old 07-24-2019, 07:36 PM   #2
SS Performance
SS Performance's Avatar
Drives: 02 Camaro B4C
Mine runs strong in all gears.
A man's garage is his castle
1969 Camaro SS
1970 Camaro SS
2002 Camaro B4C
2014 Camaro SS Dedicated Track Car
2015 Camaro 1SS 1LE
2008 HHR SS
1996 Silverado Crew Cab Long Bed Dual Rear Wheel
SS Performance is offline   Reply With Quote
Old 07-24-2019, 08:12 PM   #3
Silveradoss573
Banned
Drives: Camaro 1LE
Haven't noticed that on mine either.
Silveradoss573 is offline   Reply With Quote
Old 07-24-2019, 08:34 PM   #4
DarkMaro1le
Wellllll damn
Thanks i guess i have more digging to do
Old 07-24-2019, 09:14 PM   #5
Venomcustom
Hard to want.
Venomcustom's Avatar
Drives: 2020 red hot 1SS 1LE
How bad did she gap you? Lol
Venomcustom is offline   Reply With Quote
Old 07-24-2019, 09:31 PM   #6
DarkMaro1le
HA! ok honestly off the line a whole car.. It feels like boost lag till about 3200rpm in 2nd. Granted shes an auto with some work done. But rolling she gets left. Especially top end.
Old 07-24-2019, 11:46 PM   #7
Jayjellyfish212
Jayjellyfish212's Avatar
Drives: 2014 1LE
Odd yours is doing that. Mine pulls hard and is really torquey in all gears . I always feel like I’m holding the car back in city driving or stop and go traffic. Mine is very snappy in first and second and up but 1-2 really snappy even before I did any mods.
Try doing the fuse pull trick to reset the fuel tables. I’m thinking someone put crap low
end gas in there before you bought the car. Easy to do and may fix ya! Look it up on here there’s a few write ups on it. Basically you’ll pull 2 fuses and let it sit overnight then put them back in. It will reset the fuel tables. You should run a premium non ethanol fuel in the car.
If the car is still stock tuned get a tune to the ecu certainly will make a major difference also. But give the fuse pull trick a shot first.
Car mods: never enough!
Jayjellyfish212 is offline   Reply With Quote
Old 07-25-2019, 09:07 AM   #8
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
It's been several years since I owned it, but I don't ever remember my '15 1SS/1LE bogging down getting off from a start. Strange
nancygrl is offline   Reply With Quote
Old 07-25-2019, 10:22 AM   #9
Chevyjk33
Drives: 2015 Camaro 2SS 1LE
I wouldn't say it was a hard bog in mine, but I did notice a world of difference after I got mine tuned.
Chevyjk33 is offline   Reply With Quote
Old 07-25-2019, 11:37 AM   #10
Billy10mm
Billy10mm's Avatar
Drives: 2014 Camaro 2SS 1LE NPP
First gear in our cars is somewhat long and peak torque out of the LS3 comes at 4600 RPM. So while this thing does have a great mid-range, it's bottom end isn't exactly Cummins-like. If you bog off the line, you're screwed.
When I'm auto-crossing I'm typically putting the tach between 2500 and 3-grand, slipping the clutch aggressively while pushing the throttle through the firewall, and am fighting wheel-spin all the way through first until I grab second at while point I'm usually at full lateral load and trying not to put orange marks on my paint.
My thoughts on some things:
  • Driving Nannies: If I'm that far out of shape on the street, something has gone terribly wrong and by all means Mr. Computer man, come and get me.
  • G2s: Rock throwing is like like a tramp stamp; although problematic, it's a sign of good things to come.
Billy10mm is offline   Reply With Quote
Old 07-25-2019, 01:12 PM   #11
bruceffect
Drives: 2015 2SS 1LE, 1982 911SC
My recently acquired '15 1LE feels like a rocket in 1st and 2nd, but as Billy said you gotta keep the revs up.
bruceffect is offline   Reply With Quote
Old 07-25-2019, 04:26 PM   #12
DarkMaro1le
Thanks for all the advice and input. I’ve been running good premium in it and have a 91 octane tune. It was doing it before the tune. Even went back to stock to make sure.
I will be tracking it so I know it won’t matter as much in those low gears 3rd and up are very aggressive. but I just wanted to reach out and see if it was common. I’ll throw my scanner on it tonight and data log my fuel trims. Other than that I’m loving the car and excited about upcoming event at PBIR.
Old 07-25-2019, 07:56 PM   #13
Silveradoss573
Banned
Drives: Camaro 1LE
I'm just throwing this out there, but are you by chance spinning through 1-2 and activating the traction control?
Old 07-25-2019, 08:20 PM   #14
DarkMaro1le
I wish that was the problem. But I drive with traction and stabilitrac off
