Old 07-26-2019, 01:57 AM   #1
hunter46554
Drives: 2014 Camaro SS
Unhappy 2014 Turbo Charged problems
I currently own a 2014 Camaro SS which is turbo charged by the On3Performance Turbo Kit. I have recently ran into a problem with the car. It all started off with a notification when my car was idling for about 20 minutes. I got a message saying my power from my engine has been reduced and to service traction control. After 5 ignition cycles, all the service lights turned off. I now have problems about once a week where my car does not want to start for about 4 ignition cycles. When I plug in a code scanner, the only code I get is "ECM:P0102: Mass or Volume Air Flow A Circuit Low" The turbo kit that is installed does not have a MAF sensor, or one that I can find anyway. My AFR is now at 14-15 at idle when it usually sits around 18. AFR also bounces quite a lot when at idle. I have checked all exhaust/turbo fittings and have found nothing that could be concidered a Turbo Leak. I have not been able to find a vaccum leak either. Has anyone experienced this or know what it may be? I really dont want to have to pay someone hundreds to look at it. Thank you all in advance.
hunter46554 is offline   Reply With Quote
Old 07-26-2019, 04:18 AM   #2
HDRDTD
There has to be a MAF somewhere, otherwise how would the ecu know how to run the injectors, adjust timing, etc??
Or am I missing something??
Old 07-26-2019, 04:24 AM   #3
hunter46554
I have a MAP sensor which you can run in place of a MAF sensor... I have not been able to locate a MAF sensor on this setup. I bought the car about 2 months ago, and just recently ran into this problem.
Old 07-26-2019, 08:13 AM   #4
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
18:1 at idle seems awfully lean. I don't run a turbo, maybe there is something difference about them but on my supercharged one I bounce between 14.2 and about 15.5 at idle, it is supposed to bounce around as the O2S read the A/F and adjust accordingly back and forth. I also have a MAF and a MAP, not sure why there would be a kit that got rid of a MAF they are much more accurate than MAP alone, but again I don't know the turbo kit setups. What are you reading for A/F under boost? Should be down under 12:1 I would think, if it's higher I would suspect a tuning issue or a leak somewhere.
Greenhornet2 is offline   Reply With Quote
Old 07-26-2019, 10:15 AM   #5
Juiced1
Drives: 2012 2SS CAMARO 45th
Who tuned the car? Sounds like a defective maf sensor or something in the tune perhaps.
Juiced1 is offline   Reply With Quote
Old 07-26-2019, 10:58 AM   #6
jcaligood
jcaligood's Avatar
Drives: '18 SS 1LE
guys, i am a friend of OP
we have looked through the setup and cannot find a MAF sensor. i believe he is running "speed density" setup. unless the MAF sensor would be somewhere near the bottom towards intercooler where we need to pull bumper/more components to locate.
the wiring harness where the female side of MAF sensor would be connected, is unplugged and spliced.
i run a cammed NA FBO setup and am not familiar with boosted applications. nor have i ever owned a boosted camaro.
the few responses seem to believe MAF sensor should be connected.
the only code he is receiving is for a MAF sensor.
his numbers for AFR seem typical to me, which leads me to believe this is a sensor/tune/wiring issue.
im tempted to swap batteries, as we have all seen in the past, it throws random u related codes to save power for other components. im not confident this is the issue though.
i think its a sensor/tune/wiring problem im not familiar with.
we dont want to pull valve covers yet to check springs,rockers,etc. i dont think its that deep.
anybody familiar with this, please chime in before OP wastes money taking this beast to a dyno tuner
jcaligood is offline   Reply With Quote
Old 07-26-2019, 11:01 AM   #7
jcaligood
jcaligood's Avatar
Drives: '18 SS 1LE
https://www.on3performance.com/shop/...-turbo-system/
this is the turbo kit he is running.
Old 07-26-2019, 12:31 PM   #8
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
So.... in the pictures posted on that website for the turbo kit, there IS a MAF sensor. The pictures look nothing like the one OP posted. Looks to me like some one cut the MAF out and welded the tube back up. Something is screwy. Also, the car from the factory, has a MAP sensor on the intake already. You need both
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 07-26-2019, 01:53 PM   #9
Greenhornet2
I'd follow the MAF splice and see where it goes, maybe someone decided to relocate the MAF in the hidden ducting behind the bumper. two wires from my MAF connector were disconnected to plug into a separate AIT sensor, that may also be what you are seeing. I can't imagine not running a MAF seems counter intuitive to me. Plus you are getting codes for the MAF. If you weren't before and put miles on it without issue then this code popped up there must be something to it. With a MAF unplugged it will throw a code instantly.
Old 07-27-2019, 06:39 AM   #10
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
Just gonna throw this out that Its possible that the car is speed density tuned
Also, its a know fact that the FAST LSXR intake manifold is known to leak in boosted applications
i would check the manifold for a vacuum leak.
Sent from my SM-G975U using Tapatalk
Bone Stock
sixty9fordkiller is offline   Reply With Quote
camaro, camaro ss, engine, problems, turbo
