Old 12-11-2009, 02:25 PM   #1
Jakefeb3
Drives: 2010 camaro 1ss
Check engine light: error code. Help please
I'm getting the "check engine light" turning on, and the error code is :
"p1133" bank 1 fuel control shifted lean (faosc) (see p2096).
I'm also getting a 2nd one, that's the exact same error, except it's "p1153" and it's for bank 2 fuel. Any thoughts on what the problem is? Could it be the headers? Is it the o2 sensors? Thanks for any advice
Jakefeb3 is offline   Reply With Quote
Old 12-11-2009, 02:30 PM   #2
GMRULZ
GMRULZ's Avatar
Drives: 2010 SS & 2008 C6
What headers do you have? I am having the same problem. Hopefully somebody can help. I`ve checked wires, nothing burnt, no exhaust leaks but for good measure retorqued everything and i still get these 2 codes. If we both have I`m sure others have as well.
2010 SS L99, 536rwhp 10.843@126.72. Whipple Supercharger stock pulley, ARH 1 7/8 longtubes w/ catted xpipe, magnaflow 3" mufflers, ADM Race CAI, 3:70 gears, lightweight wheels and nitto drag radials. Stock internal L99, stock converter.
Bolt on best before blower 12.22@113.29 w/ nothing but ARH headers, catted x-pipe, ADM CAI and a tune on stock Pzero`s!
Other car 2008 C6 Ls3, z51, A6, Npp Exhaust, best bonestock pass 11.80@118.82, Number 2 on the Corvette Forums Bonestock fastest list..
GMRULZ is offline   Reply With Quote
Old 12-11-2009, 02:36 PM   #3
Jakefeb3
dynatech headers with the cats. I get this error if its really cold out and if I go really slow. I get the error about 5-10 minutes after i start the car from cold. If I drive moderately after I start, I wont get the error. I have gotten these errors about 3 times over the last 3 weeks
Old 12-11-2009, 03:44 PM   #4
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
did you tune the ecm after the header install, if not you will need a tune to correct the issue
also your code description is wrong,, these are the actual gm descrition for those codes:
DTC P1133: HO2S Insufficient Switching Bank 1 Sensor 1
DTC P1153: HO2S Insufficient Switching Bank 2 Sensor 1
very common after long tube install,, your tuner should be able to fix it.
Old 12-11-2009, 04:37 PM   #5
Badassbird
LSX Tuner at Cincy Speed
Drives: 1988 GTA Trans Am
Needs a good tune man. Nothing more.
Tracey Scott
Lead GM Tech and Tuner -Cincy Speed
513-821-2221
Badassbird is offline   Reply With Quote
Old 12-11-2009, 05:08 PM   #6
NAHURRY
Love's to Detail
NAHURRY's Avatar
Drives: 2010 SS,97silverado/08crewcab
Or if you are concerned with your warranty, you could try re-setting the
ECM like "Tag" did.
NAHURRY is offline   Reply With Quote
Old 12-11-2009, 05:45 PM   #7
Jakefeb3
It has been tuned. the error still is happening
Old 12-11-2009, 05:46 PM   #8
Jakefeb3
Well then the diablo trinity's description is wrong.... that is word for word on the trinity
Old 12-11-2009, 05:48 PM   #9
Jakefeb3
if you would like to explain in more detail how to tune it out, that would be nice
Old 12-13-2009, 08:53 PM   #10
GMRULZ
GMRULZ's Avatar
The rear o2`s are tured off by the tuner, these codes are the fronts, obviously you do nt want to turn them off, so how to you adjust the tune to get rid of the code happening?
Old 12-13-2009, 09:29 PM   #11
full of days
full of days's Avatar
Drives: Camaro GT
just ordered a set of dynatech supermaxx long headers w/ catted midpipe and am bummed to see this. Keep us posted as to the status of resolution.
full of days is offline   Reply With Quote
Old 12-13-2009, 10:43 PM   #12
tjbusa
Serious Sleeper
tjbusa's Avatar
Drives: 2010 CGM 2SS/RS M6
SLP has and answer to code problems with headers....
http://www.slponline.com/view_produc...T&BIG=27022T-1
SLP DiabloSport Predator will come equipped with a modified custom tune for SLP Long Tube Headers and/or full X-Pipes. "SLP Custom Header Tune" adjusts for fueling and re-calibrates oxygen sensors.
Drive-by
Fact of Life:
After Monday and Tuesday
even the calendar reads...
W T F
tjbusa is offline   Reply With Quote
Old 12-14-2009, 07:09 AM   #13
GMRULZ
GMRULZ's Avatar
It`s probably talking about the rear o2`s. Those won`t work properly no matter what after the long tubes. The fronts well I`m not sure a tune could fix this, I`m thinking the o2 extensions may be too long causing this. Hopefully somebody has found a resolutuion and will pipe up.
Old 12-14-2009, 08:11 AM   #14
Jakefeb3
I logged data for jannetty (Ted) and he's going to see if he can get rid of the error in the tune(using the trinity)
g5cr cai system anybody install or looking at one "pics" camarossrs2150 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 07-14-2011 08:26 PM
List of Intakes that will work with the TVS-2300 MagnaCharger JJ2010 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 03-19-2010 02:11 AM
Check Engine Light :( Abygale Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 19 10-25-2009 07:17 PM
L99 engine specifications Tran Wiki 0 10-19-2008 11:40 AM
Voice Your Comments/Suggestions/Input for Focus Group on 2010 Camaro Mr. Wyndham 5th Gen Camaro SS LS LT General Discussions 235 04-22-2008 12:43 AM
