Old 12-11-2009, 03:49 PM   #1
Rogue Leader
Iatefiberglassinsulation
Rogue Leader's Avatar
Drives: 2010 Camaro 2SS M6
Window Indexing issue getting worse in cold weather.
So I have the window indexing issue that GM supposedly is working on a fix for. However now that its getting cold out (or maybe its just a time thing) its getting way worse. 3 or 4 times (twice today alone!) i've gotten out of the car and the window never indexed back up. Every other time I get in the car I have to re index the drivers window.
Anyone heard of this programming fix coming anytime soon? This is getting ridiculous!
2010 Chevrolet Camaro SS - was daily driver, now toy
2020 Alfa Romeo Giulia Quadrifoglio - Daily Driver
2017 Mercedes Benz GLE 350 - Wifes Car
2008 Chevy Silverado 2500 HD LT 6.0 - Tow Vehicle
1991 Alfa Romeo 164S - Project Car
1994 Volkswagen Golf - Race Car
"Like" my race team on Facebook: http://www.facebook.com/farfrumwinnin
Rogue Leader is offline   Reply With Quote
Old 12-11-2009, 03:52 PM   #2
67 Convertible
67 Convertible's Avatar
Drives: 67 Camaro Convertible
I haven't heard anything on when the fix is coming.
Actually I have just the opposite. Was having to re-index my driver side window 3-4 times a week this summer. Now that the cold weather has arrived, I haven't had a problem for weeks now.
2LT/RS RJT, Blk Rally Stripes, Beige Interior, Sunroof
Placed order at dealer 4/24/09
1100 - 4/28/09
2000 - 5/01/09
2500 - 5/05/09
3000 - 5/05/09
3300 - 5/30/09
3400 - 6/05/09
3800 - 6/18/09
4000 - 6/18/09
4B00 - 6/18/09
4200 - 6/22/09
5000 - 7/01/09
6000 - 7/01/09 It's Home!!
0000 - 7/14/11 Traded in with 24,000 miles. Currently 5th Gen less
67 Convertible is offline   Reply With Quote
Old 12-14-2009, 02:57 PM   #3
Rogue Leader
Anyone? I keep getting stuck with with window dropped, but it was a slightly warmer the past 2 days and now its not SO bad.....
Old 12-14-2009, 03:01 PM   #4
coolman
Guest
Could it be Ice?
coolman is offline   Reply With Quote
Old 12-16-2009, 09:09 AM   #5
Rogue Leader
Originally Posted by coolman View Post
Could it be Ice?
Definitely not ice. It happened again this morning, closed the door to leave and the window was stuck down, I had to get back in the car and turn it back on again and reindex the window.
Man GM needs to come up with a fix for this soon its really starting to piss me off....
Old 12-16-2009, 10:36 AM   #6
Wild Bill
Wild Bill's Avatar
Drives: Camaro 2015 RS CRM
Check out this thread and try the instructions, if you haven't already tried this. It worked for me.
http://www.camaro5.com/forums/showth...=index+windows
IOM 2SS/RS manual
1100 - 4/7/09
3000 - 5/27/09
6000 - 7/17/09
See my Thread in New York Metro Area.
http://www.camaro5.com/forums/showthread.php?t=33878
Wild Bill is offline   Reply With Quote
Old 12-16-2009, 01:01 PM   #7
Rogue Leader
I've done that 42 times and it still screws up. Dealer says new programming is not yet available :(
Old 12-16-2009, 06:30 PM   #8
SS Mike
SS Mike's Avatar
Drives: 2010 Camaro SS/RS CGM M6
I don't know if this will work or not, it's similar to what is listed in that thred that's linked above. But when I was installing my new steering wheel, I had to disconnect the battery. In doing so, the windows would not index at all. I disconnected the battery with the windows all the way up. Then when I reconnected the battery, I had to turn the car to accessory, and a message came on the DIC. Follow the instructions, which it basically says to roll the driver's side window all the way down, then roll the window all the way up (do NOT use the auto up OR down when doing this or it will not work). Then do the same for the passenger's side. After doing this the window indexed fine. The only reason I say this might work is because the window system will be reset by disconnecting the battery. But I'm not sure if this WILL fix your problem or not.
Vortech V-3 Kit, ARH LT's, Custom Exhaust, Aeromotive A1000 Fuel System, Custom Tune - 582 rwhp 533 rwtq
22" Modulare H2 Wheels, CF Hood, Trunk, Spoiler & Roof by Carbon by Design, Custom Steering Wheel from P-Factor
Brembo GT BBK, Alpine INA-900, Alpine Type-R Speakers, Hurst Shifter, APR Splitter, Custom Quad Tip Diffuser
CKS C1 Coilovers, Falken 452 Tires, 265/35/22 & 285/35/22, Custom Grille, AAC Halos, and much more to come!!
SS Mike is offline   Reply With Quote
Old 12-17-2009, 07:40 AM   #9
Rogue Leader
I am getting the instruction on the DIC when it screws up. Its not such a big deal when I am in the car, its annoying when I get out and have to get back in and re-do it.
Old 12-17-2009, 08:58 AM   #10
HeavyD
HeavyD's Avatar
Drives: 1SSRS RY L99
Yes, try to completely disconnect the battery for 15 mins. Everything is computer controlled now. Just like your home computer, your car will need a reboot some times. When you turn the key off the modules just go into sleep mode, but they never fully power down. You have to do what is called a "cold boot". This is the same as shutting down your computer and pulling the plug from the wall. In your car, each module does have an operating system and boot software, it isn't Windows XP or anything, but it still can get corrupted just like Window XP and simply needs a cold boot. All you have to do is disconnect the battery, once the it is reconnected the modules will boot up on their own in a few seconds. You will have to reprogram your radio and settings and reindex the windows again, but everything software wise will be fresh in the system! What happens is the window system remembers the timing and electrical load on the motors to get the proper window travel. The system writes a little file in memory of this information. The data can get corrupted, or the operating system that instructs the body control module to access that data gets corrupted and the system just becomes stupid! I am a tech with International Trucks, our trucks are all digital and computer controlled. When we have issues with a body controller getting stupid all the time there is usually a problem with module not getting proper power or proper grounds.
Hope this helps!!!
HeavyD is offline   Reply With Quote
Old 02-16-2010, 12:53 AM   #11
HeavyD
HeavyD's Avatar
Actually, I have had to re index my windows too, twice now, in the last week. Each time the car sat for a week. Not sure what to think about it yet.
Cold Weather Blues Prevention Magnacharger Install Specials at Livernois Motorsports! Andy@Livernois Forced Induction 4 12-09-2009 07:53 AM
Cold Weather Blues Prevention Camshaft Install Specials at Livernois Motorsports! Andy@Livernois V8 Bolt-Ons & Tunes 0 11-10-2009 06:41 PM
Indexing issue with MP3 player sigma_1966 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 3 09-15-2009 10:07 AM
Cold Weather bprange USA - Great Lakes 10 08-05-2009 02:24 PM
Window Indexing Merlin1187 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 4 07-13-2009 09:07 PM
