Old 12-11-2009, 09:54 PM   #1
eneuen1199
eneuen1199's Avatar
Drives: 2ss/rs summit white silver stripes
O2 sensors
I just installed AR LT headers and a catted x-pipe... front 02 sensors came out of the stock exhaust fine.. Rear ones a different story... half a turn out they both froze up in the stock pipe..had to heat the pipe to remove them and the threads got destroyed..! anyone else have this issue...? had to order new ones from GM...
eneuen1199 is offline   Reply With Quote
Old 12-12-2009, 03:13 PM   #2
JuicedSS
JuicedSS's Avatar
Drives: 2010 Camaro 2SS RS M6
I had the same problem with one of my rear sensors. None of auto parts stores had part numbers on 2010 Camaro yet, but luckily my dealer had one in stock (for around $60).
2010 Camaro 2SS/RS M6 Black on Black
22" Vossen CV1 Wheels, Roto-Fab CAI, Dynatech 1 7/8" Long Tubes w/ High Flow Cats, Magnaflow Tru-X Pipe,
Barton Short Throw Shifter, Vector Motorsports Tune, Ground Effects, MPD1 Spoiler
JuicedSS is offline   Reply With Quote
Old 12-12-2009, 07:20 PM   #3
Longhorn SS
Longhorn SS's Avatar
Drives: 2010 IOM Camaro SSRS L99
Me too. Just bought one at the stealership.
2010 Camaro 2SS/RS - Roto-Fab CAI, ARH 1-3/4" LTs w/cats, LMR tune, KW V3 coilovers, Pfadt F&R sway bars, end links, rear trailing arms, tie rods, solid subframe bushings, HPS brake pads
Longhorn SS is offline   Reply With Quote
Old 12-12-2009, 07:21 PM   #4
alex33x
Drives: 2013 Camaro ZL1
The same thing happened to me though nothing happened to the sensors, it was still hell getting them out though.
Devliered July 20, 2012
alex33x is offline   Reply With Quote
Old 04-09-2011, 05:43 PM   #5
midrange1
midrange1's Avatar
Drives: 2010 Camaro 2SS Victory Red
Performance shop just called me to tell me that the O2 sensors were cross threaded and they would have to order new ones. WTF??
midrange1 is offline   Reply With Quote
Old 04-09-2011, 05:46 PM   #6
KnightRiderSS
Voodoo Medicine Man
KnightRiderSS's Avatar
Drives: Black 2SS with RS package
I used PB blaster and let it soak in...then used an O2 sensor socket to remove them...no problems here...you just have to be delicate when trying to break them loose...
KnightRiderSS is offline   Reply With Quote
Old 04-09-2011, 05:51 PM   #7
Cal 20112SS
Drives: 2019 C7 Stingray
The threads on these 02's are horrible. I had the same problem. Here is an ad from a header install
Cal 20112SS is offline   Reply With Quote
Old 04-10-2011, 10:26 PM   #8
greenmachinedriver
greenmachinedriver's Avatar
Drives: white 2010 ss and 2011 6.2 silvy
Mine both stuck but I was able to get them out working them back and fourth.and then using a thread file to clean up the threads, they went in ok. I think its really common.
greenmachinedriver is offline   Reply With Quote
Old 04-10-2011, 10:33 PM   #9
cdn2usa
cdn2usa's Avatar
Drives: 2010 2SS
Same here. Just finished. I installed Kooks LTH, had 26k on the 2010 SS. Took the exhaust manifold off complete with cats, sprayed PB blaster on, let them sit for 15 to 30 minutes, came out with no problems.
Aqua Blue 2SS c/w factory white strips, MT.
Installed options;Tinted Windows, De-badged,
Hurst Shifter,CAI,Vmax throttle body, Kooks LT Headers, High Flow Cats,Borla Touring Axle Back, ADM Scoop, Washwater relocation,Diablo Predator(c/w Ted's Magic), Custom start defeat switch, painted engine cover, shark fin & bow ties, ABL lighting, Rear Camera.
cdn2usa is offline   Reply With Quote
Old 04-10-2011, 10:34 PM   #10
RobSS
Drives: 2011 SS/RS
stealership charged me 145 for a primary 02 sensor,
RobSS is offline   Reply With Quote
Old 04-10-2011, 10:52 PM   #11
RonboSS
RonboSS's Avatar
Drives: 2011 RJT 2SS/RS
Just installed Solo HF cats & Mach XL w/ J-pipes exhaust. 2 hour install turned into 6.5 hour clusterf... 3 of the 4 oxygen sensors were seized up. Had to use PB blaster and then carefully use die to recut the threads. 50 miles on the exhaust and no code. Love the sound hated the "easy" install. Tim "the toolman" Taylor's got nothing on me!
RonboSS is offline   Reply With Quote
Old 04-11-2011, 12:24 AM   #12
dk818
Drives: not yet
i thought it was going to be a 3 hour job, turned into 5. the passanger side is difficult compared to the drivers side
dk818 is offline   Reply With Quote
Old 04-11-2011, 02:22 AM   #13
fourmz
Fourmz
fourmz's Avatar
Drives: 2010 2SS/RS 1968 Firebird 1994 Z28
I was one of the lucky ones who was able to get all four out with liquid wrench and an end wrench. My friends however .... Not so lucky he went 2 for 4. What a pain.
Black-in-Black/Blue out 2010 2SS/RS LS-3 -Magnacharger TVS2300,OD cog belt drive, 3.4" pulley, Janetty smooth idle blower cam,ID-850 injectors,ZL1 fuel pump,MSD boost a pump, ADM FPCM Janetty custom tune,Doug Thorley long tube headers, Corsa catback,C.A.I. Intake, Roto-Fab Big Gulp Scoop, Monster LT1/SC Clutch assembly,Eibach pro kit plus, BMR cradle/diff bushings, Barton Shifter,JRE 3.91 Eaton Tru-Trac rear diff,Barton Short Throw SHifter, Boss 339 20" wheels,Painted heritage grille, Sparks Restoration Inverted blue/black SS emblems, Seibon BB carbon fiber hood, ZL1 front bumper conversion.
fourmz is offline   Reply With Quote
Old 04-11-2011, 09:25 AM   #14
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
13 posts and noone mentions heating them up I thought everyone knew that you need to heat the exhaust bung with a torch before removing them... Then they come out like butter. You can get a little butane torch at lowes for $15.
then put antisieze on the sensors before reinstalling them.
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Tire Monitoring System monevz28 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 11-22-2009 04:42 PM
Question if people who ordered camaros before 8/31 will have backup sensors? diecast17 5th Gen Camaro SS LS LT General Discussions 6 10-01-2009 09:02 PM
TPMS sensors question Teddydog Wheels and Tires Talk Sponsored by The Tire Rack 2 09-25-2009 09:40 PM
Sensors in tires? ladysman07 Wheels and Tires Talk Sponsored by The Tire Rack 5 09-12-2009 09:41 PM
