Old 09-29-2019, 09:51 PM   #1
johnjohn
johnjohn's Avatar
Drives: 2010 ss
Trans temperature sensor Th400 swap
I have the tr6060 trans sensor, what wires are you guys using in the stock Harness to make the stock gauge work???
Thanks
2010ss L99 to a ls3 s480 turbo lil john cam tuned by james short
johnjohn is offline   Reply With Quote
Old 09-29-2019, 11:05 PM   #2
Vegas Bound
Drives: 2013 Sparkly Red One
Drill and weld a bung on your th400 pan and use the tr6060 sensor. That's what I did with my 4L80e.
Vegas Bound is offline   Reply With Quote
Old 09-30-2019, 02:40 AM   #3
Bo White
Bo White's Avatar
Buy a Summit aluminum deep pan and drill and tap it.
Old 09-30-2019, 04:32 AM   #4
johnjohn
johnjohn's Avatar
Drives: 2010 ss
Got ya! What do you hook the wires up to so the factory gauge will work?
Old 09-30-2019, 06:52 PM   #5
Vegas Bound
The same as the TR6060.
Old 09-30-2019, 07:11 PM   #6
johnjohn
johnjohn's Avatar
Drives: 2010 ss
My car was a 6l80 trans
Old 09-30-2019, 09:03 PM   #7
Vegas Bound
Did your 6L80 have a trans temp sensor and the 4 gauge? If so, use the same sensor and wiring. Just install a bung or plug in the new pan.
Old 10-01-2019, 08:40 AM   #8
johnjohn
johnjohn's Avatar
Drives: 2010 ss
It didn’t have one. No sensor anywhere. I guess it’s built I’m the harness
Old 02-09-2022, 12:55 PM   #9
PFL
PFL's Avatar
Drives: Camaro SS
Hi Bro, did it work? I swapped th400 and didn't identify temp sensor on 6l80? did you find a pin on the harness? could anyone help with the answer?
PFL is offline   Reply With Quote
