Old 10-10-2019, 09:35 AM   #1
NastyNate'sZ28
Drives: Chevy Camaro Z28
Issues getting it into 1st & 2nd gear when cold
Hey guys my z/28 has around 3900 miles now and since I got it around 2400 miles I have been having a small issue of getting it into 1st & 2nd gear the first couple times I start to drive it after it has sat and cooled down. I'll get in and warm the engine and then a lot of times I'll shift it into like 3rd or 4th gear a couple times before trying to get 1st. It is almost like the clutch isn't fully disengaging or the syncro isn't messing just right like its tight when cold. Anyone else had this issue?
NastyNate'sZ28 is offline   Reply With Quote
Old 10-10-2019, 09:53 AM   #2
G8One2
Drives: 2014 Camaro 2SS
You sure it's not the skip shift feature? That gets me occasionally, but it could be that you need to ad a little fluid to the trans. If it's a new vehicle though, you shouldn't have to do that. I do notice my M6 SS does the same thing when cold, I just go easy on her till she gets up to temp. But the issue is not exagerated much as you see to be saying yours does. I never really have to cram her into gear, just drive her easily till she's warmed up.
G8One2 is offline   Reply With Quote
Old 10-10-2019, 10:50 AM   #3
Mark_Z28
Drives: Black 2015 Z28 #457
68000 miles and no have not seen this. FYI, I usually cold start it and put it into reverse to get out of the garage and then into first but and even under 40F it still has no issue getting into gear. On some cold days I notice the movement of the shifter isn't as slick but I've never had an issue going into gear.
Do you have a stock clutch?
Mark_Z28 is offline   Reply With Quote
Old 10-10-2019, 10:59 AM   #4
NastyNate'sZ28
Not the Skip shift I'm well aware of skip shift that was shut off using HPtuners day one!! LOL
Fluid level is up I checked that when I did my Heads, cam, and header install as I too wondered about the level
Thanks
Old 10-10-2019, 11:00 AM   #5
NastyNate'sZ28
Yeah all stock trans, shifter , and clutch at this time
Old 10-10-2019, 11:04 AM   #6
608RS
608RS's Avatar
Drives: 2015 2ss
one of the many quirks about the TR6060 transmission. i would recommend by swapping your trans fluid with AMSOIL. that's a good start
608RS is offline   Reply With Quote
Old 10-10-2019, 11:11 AM   #7
NastyNate'sZ28
I've kicked around the idea of switching fluids to another brand but just wasn't ready to blame it all on a fluid just odd it gets better when warm. I guess the fluid could thin out and work better once warm but my thought was why 1st and 2nd gear only. I've tried clutching in a couple times to see if it was like the clutch was sticking and parts were still moving but that also doesn't make since why it would also only be 1st and 2nd gear
Old 10-10-2019, 02:20 PM   #8
pzero
pzero's Avatar
Drives: 2015 Camaro Z/28 #968 Silver Ice M
Change the the trans fluid to red line or other high performance name brand. That's the cheapest way to go first. If that doesn't work look into master clutch cylinder. If that doesn't work look into the main clutch itself. After I changed my fluid to red line, it's smooth as butter.
Check with your dealer if they can cover the last two.
pzero is offline   Reply With Quote
Old 10-10-2019, 03:29 PM   #9
G8One2
I agree, i plan on putting amsoil or redline in mine when i get around to it.
Old 10-10-2019, 04:19 PM   #10
NastyNate'sZ28
Red Line D4 ATF?
I bleed out the Master cylinder fluid it is fresh no change there.
Old 10-10-2019, 04:27 PM   #11
69L48Z27
69L48Z27's Avatar
Drives: 2015 Z/28; 1969 Camaro SS
Mine is like that when its ice cold, sitting overnight. First is tough to engage when moving. No real issue with 2nd however. Its all better after the first mile or two.
69L48Z27 is offline   Reply With Quote
Old 10-10-2019, 08:14 PM   #12
MIKZ28
Drives: 2019 Camaro ZL1 2004 Pontiac GTO
Mine has a problem popping out of second on occasion. Usually I notice it when I am going around a slow corner. I downshift into second and sometimes it pops back into neutral. I used to think it was me not pulling the shifter all the way into gear but it has happened so often I'm not sure now. After it pops out if I try to put it back into second it just grinds. I must put in into 3rd to keep going. I have pissed off some drivers behind me on occasion when this happens. Other times it works just fine and I don't have the problem. I'm not sure if I should take it to the dealer or not. I hate taking my car to dealers you never know if you can trust them.
MIKZ28 is offline   Reply With Quote
Old 10-10-2019, 11:27 PM   #13
lemontwist
lemontwist's Avatar
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled
redline amazon prime free shipping 47.90 shipped
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
lemontwist is offline   Reply With Quote
Old 10-11-2019, 07:53 AM   #14
NastyNate'sZ28
Basically the same concern it sounds like. 2nd gear isn't as bad or as often in mine.
