Old 10-18-2019, 10:18 PM   #1
vs_pete
Drives: VEII MY12 Sportwagon 3.6L LFX V6
Brake Fluid Cap Leaking
Has anybody had their V6 LFX brake fluid cap leaking?
Like this link.
https://www.camaro5.com/forums/showthread.php?t=367329
https://www.dormanproducts.com/p-26046-42072.aspx
I`d like to get a Dorman gasket but I can`t put my Aussie car in the drop down box. So don`t know the part number for a 2012 V6 LFX USA car.
vs_pete is offline   Reply With Quote
Old 10-19-2019, 05:11 PM   #2
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
Bought a replacement from the dealership when mine started to leak.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 10-19-2019, 07:42 PM   #3
vs_pete
Yes I did too but would like to try a Dorman gasket for a Camaro 2012 V6 LFX.
But can`t get a part number
Old 10-19-2019, 08:46 PM   #4
hammdo
'It's an experiment'
hammdo's Avatar
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I used this also...
-Don
747 RWHP 794 RWTQ
Old 10-20-2019, 04:38 AM   #5
vs_pete
Thanks -Don,
I think I`ll get that one.
And see how it goes.
Old 10-20-2019, 07:12 PM   #6
KillboyPowerhead
Drives: 2015 Z/22
I've had two V6 Camaros and the cap leaked on both. I ended up making my own gasket with some rubbery sheets I had lying around (the kind of sheets you'd use for a shoe mat, know what I mean?). Just cut out a ring-shaped gasket to fit in the cap and has been fine since.
KillboyPowerhead is offline   Reply With Quote
Old 10-26-2019, 04:28 PM   #7
vs_pete
I might try that.
The OEM gasket has a slit and the Dorman does not.
So the ring gasket you made makes sense.
Old 10-29-2019, 12:23 AM   #8
Tony-8
Tony-8's Avatar
Drives: 2014 Camaro RRM 2SS RS, M6 LS3 Vert
I had this issue as well and had the dealership replace the entire reservoir and cap, at my expense. The leaking brake fluid bubbled the paint under the reservoir, onto the outer wheel well inside the engine compartment. Dealership blamed an aftermarket billet cap I had installed that contained the OEM gasket, so it is interesting that others have had this problem. I am facing an additional $300 cost to repaint the wheel well area under the hood.
Dream it - drive it!
Tony-8 is offline   Reply With Quote
Old 10-30-2019, 03:21 AM   #9
vs_pete
Sorry to hear Tony,
God after they sell you a car don`t want to know you.
Same in aussie.
Old 11-03-2019, 11:36 AM   #10
MjrStfy
MjrStfy's Avatar
Drives: 2015 Chevy Camaro V6 2LT RS
Had mentioned it to the service advisor last time I took my car in for another issue all they did was wipe down the brake fluid and said they didn’t see a issue.
Tried the mod of adding a piece of plastic cut out to fit inside the cap it still leaked.
Replaced the gasket still leaked.
Bought aftermarket cnc’d aluminum brake reservoir cap it’s been over a year no more leaking.
MjrStfy is offline   Reply With Quote
Old 01-11-2020, 05:02 AM   #11
BRZN
BRZN's Avatar
Drives: 2012 1LT
Just had to replace ours, brake fluid was weeping out continuously. Bought the cap with the gasket from the local Chevy dealer; they couldn't get just the gasket I was told. The OEM gasket appeared fine, as does the top of the brake fluid reservoir.
BRZN is offline   Reply With Quote
Old 01-11-2020, 06:46 AM   #12
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
Thanks for the links I have this problem and was wondering what it was
Amazon says it doesn’t fit my car, have people used it and fit there cars?
https://www.amazon.com/Dorman-42072-...ype=automotive
Bigdumogre is offline   Reply With Quote
Old 01-11-2020, 07:04 PM   #13
BLU DUCE
BLU DUCE's Avatar
BLU DUCE AKA=Spike III Build
Mind started to leak in my 2011 1SS/RS a year after I got it. I took the rubber gasket out of the resivor. Got me a empty milk bottle and traced the rubber gasket on the bottle,cut it out put both pieces back in the resivor screwed the cap back on and has not leaked or been replaced since 9 years.
Didn't cost me a penny. And a lot of guys I know did this to.
Old 01-11-2020, 07:41 PM   #14
Bigdumogre
Bigdumogre's Avatar
Kk I bought the new one at autozone by me it was $6. I’ll add the plastic if need be
Thanks so much
