Old 12-13-2009, 06:35 PM   #1
kga10734
Don't Feed the Troll
Drives: 2010 Camaro 2LT/RS & 1999 Corvette
LOOK right rear side window problem
Just a heads up people...
I have a right rear side window that is loose and rattles/ vibrates @ certain RPM's. I have a video of it below. If you push on the window from the inside the rattle stops while going down the road. I have just over 4,000 miles on the car and it is vin 36614. It looks very weak when you push on it from the outside compared to the left side which seems pretty solid. The vibration inside the car is very noticeable at certain RPM's. I really couldn't tell where it was coming from, I just knew it was from the back right side of the car. So I had my son sit back there and push on panels while we went down the road till we found out what it was. I talked to somebody else and they said they had the same noise, so this could be an issue with more then just a few cars.
I did a search on the site and all I could come up with was something for the rear panel. The problem I have is with a side window.
here is the TSB for the back panel rattle
#09-08-110-010: Rattle Noise in Rear Window Panel Trim (Install Adhesive-Backed Shim Stock) - (May 6, 2009)
Does anybody else have this noise/ issue and if so what did the dealer have to do to fix it?
I'll be taking mine in to get it repaired. I'm sorry a new car with just over 4,000 miles should not have this kind of issue, because it looks like if it is left the way it is, the window will be falling out or leaking in the near future.
kga10734 is offline   Reply With Quote
Old 12-13-2009, 07:08 PM   #2
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
Watching the video, it looks like it is the exterior window trim that is loose and causing the vibration and not the window itself. Is that correct?
Old 12-13-2009, 07:14 PM   #3
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
Yeah, it sucks, but stuff happens. They will get it fixed. Thanks for the heads up.
Old 12-13-2009, 07:43 PM   #4
Dragon2U
Dragon2U's Avatar
Drives: Waiting
The video is quite shaky but near the very end you can see the entire frame and glass shaking. I would guess the glue welds did not set correctly and they will have to remove and reset the entire frame again.
Dragon2U is offline   Reply With Quote
Old 12-13-2009, 07:45 PM   #5
RedCamaroGuy
RedCamaroGuy's Avatar
Drives: 2010 Red SS2
The problem is that guy in the video that keeps pushing on your window like that. What a jerk!! I'd totally mess him up if I were you!
RedCamaroGuy is offline   Reply With Quote
Old 12-13-2009, 08:07 PM   #6
mtcwby
High on "The Camaro Life"
mtcwby's Avatar
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam
Send a message via AIM to mtcwby
The rear quarter window and trim are one piece. The whole assembly is glued in just like a windshield from the outside, with black adhesive. Just take it to the dealership, they will probably call whatever glass shop they use and have it removed and reglued.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
mtcwby is offline   Reply With Quote
Old 12-13-2009, 09:04 PM   #7
thiggin2
thiggin2's Avatar
Drives: 05/07 Chevy's
This has nothing to do with the window itself. This bulletin is for the interior trim panel between the side window and back window (C-piller).
thiggin2 is offline   Reply With Quote
Old 12-13-2009, 09:31 PM   #8
kga10734
The exterior trim piece is moving along with the window.
Sorry about the shaky video, Hard to keep the video camera still and move the trim with the other hand. What you see at the end of the video is what I was trying to capture. You can see the trim move away from the body of the car.
WOW you solved my problem. THANKS! note to self...If I don't push on the trim I won't have a vibration going down the road. Damn you a genius!
That's what I figured when I did a search, but wasn't positive. I never did find anything about the side window issue I have. I'll let the dealership take a look at it this week.
Old 12-16-2009, 09:15 PM   #9
kga10734
Here is an update.
I got the window fixed and picked it up today. Better then new. I say this because I got to talk to the guy that checked it out before they fixed it. He told me that I was lucky the window didn't fall out at some point. He said there is 3 little clips that hold the window in place and then the rest of the window is sealed/ glued in. My car didn't have a drop of sealant/ glue around that one window, just the 3 clips. I wonder if the robot or a human was supposed to take care of this area before the window is placed? I would be willing to bet, mine isn't the only one like this.
Old 12-17-2009, 09:30 AM   #10
DangerZL1
Drives: 2023 Black ZL1 Auto
This is almost the exact problem I had on a 1993 Mazda MX6. Both rear quarter windows come loose, and one of them almost fell out. They had to replace both windows. I believe the sealant was improperly applied.
DangerZL1 is offline   Reply With Quote
Old 01-01-2010, 06:25 PM   #11
Unique Auto Depot
Drives: Camaro 2010
take it to the dealer I think they have a TSB on it
Unique Auto Depot is offline   Reply With Quote
Old 01-03-2010, 11:25 AM   #12
bluman
bluman's Avatar
Drives: '10 Corvette GS/'13 Mustang
Have dealer repair it !
2010 Camaro SIM/CGM RS/2LT VIN #310 SOLD
2010 Corvette Grand Sport
bluman is offline   Reply With Quote
Old 01-03-2010, 03:55 PM   #13
thiggin2
thiggin2's Avatar
Read post #9. He already got it fixed .
HUGE problem with warped rear bumper fascia!!! camero Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 33 04-05-2012 11:20 AM
How to access rear dirvers side fender for dent repair. bbfn11 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 12 12-01-2009 02:48 PM
rear end problem at the strip????? mark_p V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 22 11-15-2009 07:26 PM
Suspension guys out there - lets talk wheel hop Crowley Suspension / Brakes / Chassis 14 10-09-2009 12:06 AM
Rear Window Heat Lines? fsuredneck 5th Gen Camaro SS LS LT General Discussions 41 03-08-2009 03:26 PM
