Old 11-03-2019, 08:39 PM   #1
graf101
Trouble_SM
graf101's Avatar
Drives: 17' Summit White ZL1
Boosted LS3 sbe record broken
Took the car out to a private track rental this past Friday night and ran a PB, which I believe is a boosted LS3 record.
2015 1LE
RPM stage 5 4L80e
4000lbs race weight (half tank gas) and me in it
IPS twin turbo street kit wGarrett twin 61’s
Stock bottom end LS3 (stock pistons, rods, crank and heads)
https://youtu.be/0NLK2oR1FyE
graf101 is offline   Reply With Quote
Old 11-03-2019, 08:57 PM   #2
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
That's movin!!!!!
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 11-04-2019, 07:14 AM   #3
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
https://www.camaro5.com/forums/showthread.php?t=564236 ???
joshnmn is offline   Reply With Quote
Old 11-04-2019, 08:55 AM   #4
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
Originally Posted by jnmn View Post
Thats likely an iron block 6.0
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 11-04-2019, 10:35 AM   #5
graf101
Trouble_SM
graf101's Avatar
Yes, that is a 6.0
Old 11-05-2019, 08:24 PM   #6
stratman2SSRS
stratman2SSRS's Avatar
Drives: Lingenfelter Camaro
Thats wicked!!
What suspension parts are you using?
stratman2SSRS is offline   Reply With Quote
Old 11-05-2019, 08:43 PM   #7
IKILLEDSUPERMAN_ZL1
Drives: 2011 Camaro SS
Badass!!
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
IKILLEDSUPERMAN_ZL1 is offline   Reply With Quote
Old 11-05-2019, 09:55 PM   #8
graf101
Trouble_SM
graf101's Avatar
BMR, Carlyle 15” conversion and Viking coilovers.
Old 11-06-2019, 11:00 AM   #9
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
Originally Posted by graf101 View Post
Yes, that is a 6.0
Yes! It is a sbe iron 6.0.
ttshovel is offline   Reply With Quote
Old 11-08-2019, 12:45 PM   #10
hillshooter
Drives: 2015 Camaro SS commemorative
what kind of boost do you see out of those 61's?
2015 Camaro SS
hillshooter is offline   Reply With Quote
Old 11-08-2019, 12:53 PM   #11
graf101
Trouble_SM
graf101's Avatar
They are pretty much maxed out at 17-18lbs.
Old 11-15-2019, 09:05 PM   #12
perfect1
Drives: 2012 camaro ss ls3
u have viking coilovers in front an back
perfect1 is offline   Reply With Quote
Old 11-15-2019, 11:16 PM   #13
graf101
Trouble_SM
graf101's Avatar
Stock suspension up front and Viking in the rear.
Old 11-16-2019, 01:47 PM   #14
1fast
8.60 @ 157 @ 4200lbs
1fast's Avatar
Drives: 2010 Gen 5
Suspension
Good job
2010 camaro twin turbo 8.60 @ 157 full weight 4200
1fast is offline   Reply With Quote
